Hi, From the Word A : 11 1101 1101 1101 0111 1101 00 with prescaler Value N = 256 and Frequency 16 Mhz the result should be calculated. Can somebody help me?
Anzeige
Calculate the result
Hi, From the Word A : 11 1101 1101 1101 0111 1101 00 with prescaler Value N = 256 and Frequency 16 Mhz the result should be calculated. Can somebody help me? Assuming A is a divider, and 111101110111010111110100 represents a 24-bit divider value of 0xF775F4 = 16,217,588 16,000,000 : 256 : 16,217,588 = 0.00385384065744 Hz Not sure if this is the result you're expecting... Antwort schreiben |
Anzeige
