Unused Pins of a Microcontroller
OP #4541271
What should be done with the unused pins of a microcontroller? Can they
be left just soldered (unconnected) or something additional has to be
done?
For example, in case of this microcontroller what needs to be done with
pins with a status:
''I(pull-up)''
or
''O(Hi-Z)''
or
Datasheet:
http://www.epsondevice.com/webapp/docs_ic/DownloadServlet?id=ID002599
#4541393
Yes, the pins you don't need can left free, just soldered.
Also the pins with I/O can be free.
The "-" means that they haven't an input or output and no status. In
your case its always for the  power supply. They should be connected.
#4541433
You should on most devices either configure them as an output or, if
they are configured as input, enable build in pull-up/-down resistors.
This reduces unnecessary currents caused by the undefined state of the
input gates.
