errorcode = HAL_BUSY
Gast #4821989
Ich generiere Code mit der CubeMX-Software für den STM32f030/STM32f103
um einen WIFI-Chip(nRF24L01+) via SPI anzusprechen.
Dummerweise erhalte ich permanent den
 errorcode = HAL_BUSY;
beim Versuch das SPI zum Senden zu "überreden".
HAL_SPI_TransmitReceive_DMA(&hspi1,TxPointer,DummyDataPointer,1))
Wofür steht denn jetzt eigentlich dieses HAL_BUSY  und warum tritt es
genau auf?
Gast #4822025
Vermutlich:
Busy flag (BSY)
The BSY flag is set and cleared by hardware (writing to
 this flag has no effect).When BSY is set, it indicates th
at a data transfer is in progress on the SPI (the SPI bus is
busy).The BSY flag can be used in certain modes to detect the end of a
transfer so that the
software can disable the SPI or its peripheral
clock before entering a low-power mode which
does not provide a clock for the peripheral.
This avoids corrupting the last transfer.
The BSY flag is also useful for preventing
write collisions in a multimaster system. The BSY flag is cleared
 under any one of the following conditions:
-When the SPI is correctly disabled
-When a fault is detected in Master -mode (MODF bit set to 1)
-In Master mode, when it finishes a data transmission and no new data is
ready to be sent
-In Slave mode, when the BSY flag is set to
 '0' for at least one SPI clock cycle between
  each data transfer.
