A6 GSM Modem - At Befehle für SMS empfang
OP #5179660
Hallo, ich beiße mir seit einigen Tagen die Zähne an diesem Modem aus.
Senden klappt und auch andere Funktionen, nur mit dem empfangen hab ich
einfach keinen Erfolg. Hat jemand damit Erfahrung?
Here are my AT Commands (maybe someone has same expirences)
Issuing command: AT&F
REPLY:
OK
Reply in 56ms. Reply OK. <
OK
Issuing command: ATE0
REPLY: ATE0Å
OK
Reply in 55ms. Reply OK. <ATE0Å
OK
Issuing command: AT+CLIP=1
REPLY:
OK
Reply in 1055ms. Reply OK. <
OK
Issuing command: AT+CMGF=1
REPLY:
OK
OK
Issuing command: AT+CNMI=1,0
REPLY:
OK
Reply in 144ms. Reply OK. <
OK
Issuing command: AT+CPMS=ME,ME,ME
REPLY:
+CPMS: 21,2521,25,1,25
Reply in 202ms. Reply OK. <
OK
Issuing command: AT+CSCS="UCS2"
REPLY:
⸮OK
⸮OK
Issuing command: AT+CSDH=1
REPLY:
OK
Reply in 58ms. Reply OK. <
OK
          Waiting for module to be ready...
Issuing command: AT+CMGL="ALL"
REPLY:
+CMGL:1,"REC READ",+4366306",,"2017/10/16,09:10:01+02",J⸮⸮⸮⸮⸮⸮Z⸮
Reply in 173ms. Reply OK. <
+CMGL:1,"REC READ",+4366306800",,"2017/10/16,09:10:01+02",J⸮⸮⸮⸮⸮⸮Z⸮>
OP
Leider klappts immer noch nicht.
Hab das im Manual gefunden
_____________________________________________________________________
 AT Commands and Response Description
AT+CMGF=1 Text mode
OK
AT+CSDH=1 Show the values in result codes
OK
AT+CMGL= " REC UNREAD " Receive unread message
+CMGL: 15,"REC
UNREAD","10658223",,"2008/4/1,10:53:4+32" List unread message
OK
AT+CMGL=”ALL” All message
+CMGL: 2,"STO UNSENT","1365125588"
testing
+CMGL: 3,"STO UNSENT","1365125588"
testing
+CMGL: 4,"STO UNSENT","1365125588"
testing
+CMGL: 5,"STO UNSENT","1365125588"
testing
+CMGL: 13,"REC
READ","13800138000",,"2008/3/28,16:17:18+32"
+CMGL: 14,"REC
READ","13800138000",,"2008/3/28,16:17:17+32"
+CMGL: 15,"REC
Show all of message
OK
und umegsetzt:
void loop() {
    int SMSbuffer[30]={0};
    SMSmessage actSMS;
    delay (3000);
 char buffer[20];
  String response;
  String command;
  A6command("AT+CMGF=1", "OK", "yy", A6_CMD_TIMEOUT, 2, NULL);
  A6command("AT+CSDH=1", "OK", "yy", A6_CMD_TIMEOUT, 2, NULL);
  A6command("AT+CMGL=\"ALL\"", "+CMGL", "yy", 15000, 2, &response);
  A6command("AT+CNMI=1,2,0,0,0", "OK", "yy", 5000, 2, NULL);
  A6command("AT+CMGR=1", "OK", "yy", 20000, 2, NULL);
  return;
Was klappt nicht?
Zeige ein Protokoll der Kommunikation und markiere dort, was Dir nicht
gefällt. Beschreibe, welches Ergebnis du stattdessen erwartet hast.
Eine Frage zum nachdenken: Wo speichert dein AT+CMGR Kommando seine
Ausgabe?
OP
Code:
Ausgabe:
REPLY:
REPLY:
OK
OK
REPLY:
REPLY:
OK
Reply in 54ms. Reply OK. <
OK
REPLY:
REPLY:
+CMGL: 1,"RECREAD",+4366380",,"2017/10/16,09:10:01+02"⸮ZbL⸮⸮⸮⸮z⸮⸮b
6)⸮ʒb
Reply in 192ms. Reply OK. <
+CMGL: 1,"RECREAD",+4343663880",,"2017/10/16,09:10:01+02"⸮ZbL⸮⸮⸮⸮z⸮⸮b
6)⸮ʒb>
Issuing command: AT+CNMI=1,2,0,0,0
REPLY: J
6Ӓj4⸮⸮
REPLY: J
6Ӓj4⸮⸮⸮
⸮⸮⸮zҊ⸮
REPLY: J
6Ӓj4⸮⸮⸮
⸮⸮⸮zҊ⸮
REPLY: J
6Ӓj4⸮⸮⸮
⸮⸮⸮zҊ⸮
⸮⸮⸮⸮⸮⸮⸮⸮(⸮⸮⸮z⸮⸮
REPLY: J
6Ӓj4⸮⸮⸮
⸮⸮⸮zҊ⸮
⸮⸮⸮⸮⸮⸮⸮⸮(⸮⸮⸮z⸮⸮
1I⸮Z⸮⸮⸮⸮⸮
REPLY: J
6Ӓj4⸮⸮⸮
⸮⸮⸮zҊ⸮
⸮⸮⸮⸮⸮⸮⸮⸮(⸮⸮⸮z⸮⸮
1I⸮Z⸮⸮⸮⸮⸮
REPLY: J
6Ӓj4⸮⸮⸮
⸮⸮⸮zҊ⸮
⸮⸮⸮⸮⸮⸮⸮⸮(⸮⸮⸮z⸮⸮
1I⸮Z⸮⸮⸮⸮⸮
OK
Reply in 356ms. Reply OK. <J
6Ӓj4⸮⸮⸮
⸮⸮⸮zҊ⸮
⸮⸮⸮⸮⸮⸮⸮⸮(⸮⸮⸮z⸮⸮
1I⸮Z⸮⸮⸮⸮⸮
OK
Issuing command: AT+CMGR=1
REPLY:
+CMGR: "REC )⸮⸮⸮","+436638⸮800",,"2017/10/16,09:10:01+02"&1,ʢ
REPLY:
REPLY:
REPLY:
REPLY:
Reply in 20303ms. Timed out.
OP
Damit ist nix anzufangen.
Bevorzugter Speicher:
REPLY:
REPLY:
+CPS*'⸮⸮b⸮⸮b⸮⸮b⸮⸮b⸮⸮b⸮⸮j
REPLY:
REPLY:
OK
Reply in 174ms. Reply OK. <
OK
Es scheint, als ob deine Empfangsroutine durcheinander kommt. Es könnte
auch an leicht abweichenden Bitraten an der seriellen Schnittstelle
liegen.
Schließe das Ding mal an deinen PC an und wiederhole die Kommandos in
einem Terminalprogramm. Empfängt dieses den selben Käse?
> ich denke
Genügt offensichtlich nicht. Überlege Dir, wie du das Problem gezielt
einkreisen kannst.
Du hast ein Modem, bei dem Du noch nicht sicher weist, dass es in
Ordnung ist. Teste es mit einem Computer und einem Adapter der erprobt
ist also ganz sicher nicht defekt und mit einem Programm das ebenfalls
erprobt ist.
Du hast eine serielle Kommunikation, die wahrscheinlich nicht korrekt
funktioniert. Hinterfrage, ob das Modem was falsches sendet oder ob dein
µC falsch empfängt.
Du hast ein teilweise selbst geschriebenes Programm, das möglicherweise
fehlerhaft ist (oder die verwendete Library). Tausche dieses also gegen
ein minimales Programm aus, dem du trauen kannst bzw. das du untersuchen
kannst. Dazu brauchst du vielleicht einen Debugger, ein bis zwei weitere
USB-UART Adapter oder einen Logicanalyzer.
OP
wenn ich mir die Reply´s ansehe, ist die Kommunikation und auch die Art,
wie ich Befehle sende ja in Ordnung:
REPLY:
REPLY:
OK
Reply in 64ms. Reply OK. <OK>
REPLY:
REPLY:
OK
Reply in 66ms. Reply OK. <OK>
Issuing command: AT+CMGL=?
REPLY:
REPLY:
+CMGL: ("REC UNREAD","REC READ","STO UNSENT","STO SENT","ALL")
Reply in 136ms. Reply OK. <+CMGL: ("REC UNREAD","REC READ","STO
NSENT","STO SENT","ALL")>
Issuing command: AT+CNMI?
REPLY:
REPLY:
OK
Reply in 13ms. Reply OK. <OK>
Issuing command: AT+CNMI=0,2,0,1,0
REPLY:
REPLY: +CNMI: 0,2,0,1,0
OK
Reply in 80ms. Reply OK. <+CNMI: 0,2,0,1,0OK>
REPLY:
REPLY: OK
REPLY: OK
REPLY: OKOK
REPLY: OKOK
Reply in 5063ms. Timed out.
REPLY ist was ich empfange. Somit klappen die Kommunikation und die
Befehlesform. und wie gesagt - senden ist auch kein Problem..
gerade mal beim Issuing command: AT+CMGL="ALL"
habe ich das Problem, nur ein OK zu erhalten....
Das sehe ich auch so. Aber irgendwann empfängst Müll. Zum beispiel die
vielen OK's am Ende oder bei deinem vorherigen Protokoll die unlesbaren
zeichen.
Aber immerhin reagiert das Modem und antwortet mit OK, also empfängt es
wohl die Kommandos. Konzentriere dich daher auch die Leitung und
Programmteile, welche die Antworten empfangen.
OP
Mal klappt die Antwort vom Modul nun, mal nicht. Es kann an den
Leitungen liegen, oder aber an den Anschlüßen. Leider hab ich keine
ahnung was ich machen kann, ausser die leitungen zu verdrillen und alle
gegen GND zu schließen was nötig ist.
Merkwürdig nur, dass nach dem abhängen der versorgung über GND vom
Controller Restspannung kommt. (Power Led am GSM Modul leuchtet schwach
weiter).
