8266+dht11mit 12000mAh 3,7V Batterie
OP #5294588
Guten Tag,
ich weiss nicht ob das eine dumme Frage ist aber ich versuche es einfach
mal.
Ich habe mir folgendes gekauft:
https://www.ebay.de/itm/ESP8266-DHT11-Temperature-Humidity-WiFi-Module-Wireless-Module-ESP-01-01S-Shiled/162835085549?hash=item25e9ba38ed:g:lk4AAOSwI59aTebZ
und dazu den folgenden Code draufgemacht:
#include <ESP8266WiFi.h>
#include <DHT11.h>
const char* ssid     = "ssid"; // Your ssid
const char* password = "password"; // Your Password
int pin = 2;
WiFiServer server(80);
DHT11 dht11(pin);
double Fahrenheit(double celsius) {
return ((double)(9 / 5) * celsius) + 32;
double Kelvin(double celsius) {
return celsius + 273.15;
void setup() {
Serial.begin(115200);
delay(10);
23
Serial.println();
24
25
// Connect to WiFi network
26
WiFi.mode(WIFI_STA);
27
Serial.println();
28
Serial.println();
29
Serial.print("Connecting to ");
30
Serial.println(ssid);
31
32
WiFi.begin(ssid, password);
33
34
while (WiFi.status() != WL_CONNECTED) {
35
delay(500);
36
Serial.print(".");
37
38
Serial.println("");
39
Serial.println("WiFi connected");
40
41
// Start the server
42
server.begin();
43
Serial.println("Server started");
44
45
// Print the IP address
46
Serial.println(WiFi.localIP());
47
48
49
void loop() {
50
int err;
51
float temp, humi;
52
if ((err = dht11.read(humi, temp)) == 0)
53
54
Serial.print("temperature:");
55
Serial.print(temp);
56
Serial.print(" humidity:");
57
Serial.print(humi);
58
Serial.println();
59
60
else
61
62
Serial.println();
63
Serial.print("Error No :");
64
Serial.print(err);
65
Serial.println();
66
67
WiFiClient client = server.available();
68
client.println("HTTP/1.1 200 OK");
69
client.println("Content-Type: text/html");
70
client.println("Connection: close");  // the connection will be closed after completion of the response
71
client.println("Refresh: 5");  // refresh the page automatically every 5 sec
72
client.println();
73
client.println("<!DOCTYPE html>");
74
client.println("<html xmlns='http://www.w3.org/1999/xhtml'>");
75
client.println("<head>\n<meta charset='UTF-8'>");
76
client.println("<title>ESP8266 Temperature & Humidity DHT11 Sensor</title>");
77
client.println("</head>\n<body>");
78
client.println("<H2>ESP8266 & DHT11 Sensor</H2>");
79
client.println("<H3>Humidity / Temperature</H3>");
80
client.println("<pre>");
81
client.print("Humidity (%)         : ");
82
client.println((float)humi, 2);
83
client.print("Temperature (°C)  : ");
84
client.println((float)temp, 2);
85
client.print("Temperature (°F)  : ");
86
client.println(Fahrenheit(temp), 2);
87
client.print("Temperature (°K)  : ");
88
client.println(Kelvin(temp), 2);
89
client.println("</pre>");
90
client.println("<H3>www.elec-cafe.com</H3>");
91
client.print("</body>\n</html>");
92
delay(DHT11_RETRY_DELAY); //delay for reread
93
das funktioniert auch super aber wenn ich eine 1200mAh 3,7V Batterie
dranhänge läuft das höchstens einen Tag. Kann man die Laufzeit irgendwie
verlängern z.B. dadurch das nur alle halbe Stunde einmal gemessen wird
o.ä.?
Danke im voraus für Antworten
