LED tunable white setup
OP #6023720
I am searching for a solution to control an existing dual white /
tunable white / dynamic white LED lamp (a luminaire with one cold white
and one warm white LED string).
The two LED strings are currently driven by two LED drivers for each
string (each string is broken down into two substrings and one driver
drives a substring with 165V 300mA CC). It would be feasible to divide
the strings down into six substrings with a forward voltage of 55V each
and drive them with lower voltage LED drivers (55V 300mA CC).
The current drivers have a 0-10V dimming input.
I am looking for an easy, affordable solution to wirelessly control
brightness and CCT of this luminaire. The setup should comprise:
  - Remote control or android app to control a tunable white luminaire
(brightness and CCT)
  - Wireless to 0-10V bridge to control the existing drivers or replace
existing drivers with new drivers that can directly be controlled
wirelessly.
So far I am considering these two setups:
Zigbee setup:
  - Android app that works with Philips Hue bridge
  - Philipps Hue bridge (40Eur)
  - 2x China Zigbee to 0-10V from ebay (50Eur)
Total 90Eur, medium risk of making devices from different manufacturers
work together.
Osram DALI/Bluetooth setup:
  - Osram Bluetooth lighting control app
  - Osram DALI acu bt bluetooth to DALI bridge (55Eur)
  - 2x Osram OTI DALI 35/220-240/400D NFC TW LED drivers (68Eur)
Total 123Eur, should work out of the box as everything is made by Osram
LED strings will have to be cut into two seperate strings as Osram
driver is not isolated.
Anyone knows something better than this?
Thank you
Antworten gerne auch auf deutsch, danke.
