Lattice MachxO3 - LVDS invertieren
OP #6186679
lvds-chef schrieb:
> In Hardware nicht, aber in Logik:
> internal_signal <= not external_lvds_signal;
Leider mak diamond dies nicht:
ERROR - PAD signal LVDS_OUT_DATA_7 has illegal connections to block rgblvds_i/LVDS_OUT_DATA_7__I_0_1_lut. IO buffer is expected.
ERROR - PAD signal LVDS_OUT_DATA_6 has illegal connections to block rgblvds_i/LVDS_OUT_DATA_6__I_0_1_lut. IO buffer is expected.
ERROR - PAD signal LVDS_OUT_DATA_5 has illegal connections to block rgblvds_i/LVDS_OUT_DATA_5__I_0_1_lut. IO buffer is expected.
ERROR - PAD signal LVDS_OUT_DATA_4 has illegal connections to block rgblvds_i/LVDS_OUT_DATA_4__I_0_1_lut. IO buffer is expected.
ERROR - PAD signal LVDS_OUT_DATA_3 has illegal connections to block rgblvds_i/LVDS_OUT_DATA_3__I_0_1_lut. IO buffer is expected.
ERROR - PAD signal LVDS_OUT_DATA_2 has illegal connections to block rgblvds_i/LVDS_OUT_DATA_2__I_0_1_lut. IO buffer is expected.
ERROR - PAD signal LVDS_OUT_DATA_1 has illegal connections to block rgblvds_i/LVDS_OUT_DATA_1__I_0_1_lut. IO buffer is expected.
ERROR - PAD signal LVDS_OUT_DATA_0 has illegal connections to block rgblvds_i/LVDS_OUT_DATA_0__I_0_1_lut. IO buffer is expected.
INFO - Errors found in user's design.  Output files not written. Check map report for more details.
  • [vhdl]VHDL-Code[/vhdl]
