[V] 1TB-HDD Samsung ST1000DM005
OP #6569042
ich verkaufe meine alte Backupfestplatte, da sie mir zu klein wurde.
Backupfestplatte heißt: Alle paar Wochen hochfahren, Image von SSD auf
HDD speichern, runterfahren.
Preisvorstellung meinerseits: 35€ inkl. Versand nach D, ansonsten auch
gerne Abholung in 073xx oder 922xx für 30€.
SMART-Werte:
smartctl 5.41 2011-06-09 r3365 [x86_64-linux-3.2.0-53-generic] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model:     ST1000DM005 HD103SJ
Serial Number:    S246J90C35xxxx
LU WWN Device Id: 5 0004cf 207290e7c
Firmware Version: 1AJ10001
User Capacity:    1.000.204.886.016 bytes [1,00 TB]
Sector Size:      512 bytes logical/physical
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 6
Local Time is:    Sat Jan 30 17:16:46 2021 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)  Offline data collection activity
23
          was never started.
24
          Auto Offline Data Collection: Disabled.
25
Self-test execution status:      (   0)  The previous self-test routine completed
26
          without error or no self-test has ever
27
          been run.
28
Total time to complete Offline
29
data collection:     ( 9240) seconds.
30
31
capabilities:        (0x5b) SMART execute Offline immediate.
32
          Auto Offline data collection on/off support.
33
          Suspend Offline collection upon new
34
          command.
35
          Offline surface scan supported.
36
          Self-test supported.
37
          No Conveyance Self-test supported.
38
          Selective Self-test supported.
39
SMART capabilities:            (0x0003)  Saves SMART data before entering
40
          power-saving mode.
41
          Supports SMART auto save timer.
42
Error logging capability:        (0x01)  Error logging supported.
43
          General Purpose Logging supported.
44
Short self-test routine
45
recommended polling time:    (   2) minutes.
46
Extended self-test routine
47
recommended polling time:    ( 154) minutes.
48
SCT capabilities:          (0x003f)  SCT Status supported.
49
          SCT Error Recovery Control supported.
50
          SCT Feature Control supported.
51
          SCT Data Table supported.
52
53
SMART Attributes Data Structure revision number: 16
54
Vendor Specific SMART Attributes with Thresholds:
55
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
56
  1 Raw_Read_Error_Rate     0x002f   100   100   051    Pre-fail  Always       -       0
57
  2 Throughput_Performance  0x0026   252   252   000    Old_age   Always       -       0
58
  3 Spin_Up_Time            0x0023   070   068   025    Pre-fail  Always       -       9366
59
  4 Start_Stop_Count        0x0032   099   099   000    Old_age   Always       -       1498
60
  5 Reallocated_Sector_Ct   0x0033   252   252   010    Pre-fail  Always       -       0
61
  7 Seek_Error_Rate         0x002e   252   252   051    Old_age   Always       -       0
62
  8 Seek_Time_Performance   0x0024   252   252   015    Old_age   Offline      -       0
63
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       2577
64
 10 Spin_Retry_Count        0x0032   252   252   051    Old_age   Always       -       0
65
 11 Calibration_Retry_Count 0x0032   252   252   000    Old_age   Always       -       0
66
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1509
67
191 G-Sense_Error_Rate      0x0022   100   100   000    Old_age   Always       -       2
68
192 Power-Off_Retract_Count 0x0022   252   252   000    Old_age   Always       -       0
69
194 Temperature_Celsius     0x0002   064   056   000    Old_age   Always       -       18 (Min/Max 3/44)
70
195 Hardware_ECC_Recovered  0x003a   100   100   000    Old_age   Always       -       0
71
196 Reallocated_Event_Count 0x0032   252   252   000    Old_age   Always       -       0
72
197 Current_Pending_Sector  0x0032   252   252   000    Old_age   Always       -       0
73
198 Offline_Uncorrectable   0x0030   252   252   000    Old_age   Offline      -       0
74
199 UDMA_CRC_Error_Count    0x0036   200   200   000    Old_age   Always       -       0
75
200 Multi_Zone_Error_Rate   0x002a   100   100   000    Old_age   Always       -       1
76
223 Load_Retry_Count        0x0032   252   252   000    Old_age   Always       -       0
77
225 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1518
78
79
SMART Error Log Version: 1
80
No Errors Logged
81
82
SMART Self-test log structure revision number 1
83
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
84
# 1  Short offline       Completed without error       00%        34         -
85
86
Note: selective self-test log revision number (0) not 1 implies that no selective self-test has ever been run
87
SMART Selective self-test log data structure revision number 0
88
Note: revision number not 1 implies that no selective self-test has ever been run
89
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
90
    1        0        0  Completed [00% left] (0-65535)
91
    2        0        0  Not_testing
92
    3        0        0  Not_testing
93
    4        0        0  Not_testing
94
    5        0        0  Not_testing
95
Selective self-test flags (0x0):
96
  After scanning selected spans, do NOT read-scan remainder of disk.
97
If Selective self-test is pending on power-up, resume after 0 minute delay.
