EmbDev.net
Forum: FPGA, VHDL & Verilog Vhdl project: mini-router
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Lucy (Guest)
Rate this post
useful
not useful
I have a project about a mini router, I wrote the source code and the
testbech and it seems to work, but I'm not sure everything is correct
because I'm new in vhdl codes. Could someone please check it? I ll share
my codes and the test of the project.
von Dr. Emmett L. Brown (Guest)
Rate this post
useful
not useful
For debug/verifying purposes, it woulde be fine to have an additional
output whichs tells the sourceport (Link1 or link2) of the routed data.
von Luciana (luciana)
Rate this post
useful
not useful
1:So you think my work is ok, right? You are just suggesting me how to
improve it?
2: Should I add the 2 output ports to the entity of the mini router?
Rate this post
useful
not useful
> improve it?
No, not to improve it, just to make it test-able.
See Design for test: https://en.wikipedia.org/wiki/Design_for_testing
Test coverage is also important, and have a look to UVVM:
https://emlogic.no/uvvm/
von vancouver (Guest)
Rate this post
useful
not useful
use IEEE.std_logic_unsigned.all;
use IEEE.numeric_std.all;
Never use both of them. Numeric is suffcient.
Besides that, I don't see any problems (assuming to simulation results
are correct). But get used to write source code comments in english, so
everybody can understand them :-)
Rate this post
useful
not useful
thank you very much
von Broccoliliving B. (Company: word wipe) (broccoliliving)
Rate this post
useful
not useful
>> improve it?
https://drivemad.io/home
I agree with you, it is best to choose one or the other and never
combine them. The use of numbers is adequate.
von Cat B. (catbosy)
Rate this post
useful
not useful
It's great that you've completed your mini-router project in VHDL. If
you're new to VHDL, it's understandable to have some doubts about your
code.
Rate this post
useful
not useful
I recommend asking for feedback on forums dedicated to VHDL or digital
design. There, experienced users can review your code and testbench to
ensure everything is correct.
If you need help accessing your Airtel router settings for any reason,
you can refer to this guide at
https://routerctrl.com/airtel-router-login/. It provides step-by-step
instructions on how to log in and make changes to your router settings.
Good luck with your project!
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
