ATM32 - Einbindung - stm32f10x.h -
#7306868
Die Include-Datei stm32f10x.h ist für verschiedene Varianten (eben das "x") geschrieben. Damit nun genau die richtigen Definitionen gemacht werden, benötigt sie einen Hinweis, welchen Controller Du genau benutzt, also z.B. ob es ein STM32f103 oder STM32f107 ist.
Das macht man normalerweise durch die Zuweisung eines entsprechenden Macros bzw. Konstanten.
Die Includedatei sieht an der Stelle vermutlich so aus:
#if !defined (STM32F10X_LD) && !defined (STM32F10X_LD_VL) && !defined (STM32F10X_MD) && !defined (STM32F10X_MD_VL) && !defined (STM32F10X_HD) && !defined (STM32F10X_HD_VL) && !defined (STM32F10X_XL) && !defined (STM32F10X_CL)
  /* #define STM32F10X_LD */     /*!< STM32F10X_LD: STM32 Low density devices */
  /* #define STM32F10X_LD_VL */  /*!< STM32F10X_LD_VL: STM32 Low density Value Line devices */
  /* #define STM32F10X_MD */     /*!< STM32F10X_MD: STM32 Medium density devices */
  /* #define STM32F10X_MD_VL */  /*!< STM32F10X_MD_VL: STM32 Medium density Value Line devices */
  /* #define STM32F10X_HD */     /*!< STM32F10X_HD: STM32 High density devices */
  /* #define STM32F10X_HD_VL */  /*!< STM32F10X_HD_VL: STM32 High density value line devices */
  /* #define STM32F10X_XL */     /*!< STM32F10X_XL: STM32 XL-density devices */
  /* #define STM32F10X_CL */     /*!< STM32F10X_CL: STM32 Connectivity line devices */
#endif
/*  Tip: To avoid modifying this file each time you need to switch between these
        devices, you can define the device in your toolchain compiler preprocessor.
 - Low-density devices are STM32F101xx, STM32F102xx and STM32F103xx microcontrollers
   where the Flash memory density ranges between 16 and 32 Kbytes.
 - Low-density value line devices are STM32F100xx microcontrollers where the Flash
 - Medium-density devices are STM32F101xx, STM32F102xx and STM32F103xx microcontrollers
   where the Flash memory density ranges between 64 and 128 Kbytes.
 - Medium-density value line devices are STM32F100xx microcontrollers where the
 - High-density devices are STM32F101xx and STM32F103xx microcontrollers where
23
   the Flash memory density ranges between 256 and 512 Kbytes.
24
 - High-density value line devices are STM32F100xx microcontrollers where the
25
26
 - XL-density devices are STM32F101xx and STM32F103xx microcontrollers where
27
   the Flash memory density ranges between 512 and 1024 Kbytes.
28
 - Connectivity line devices are STM32F105xx and STM32F107xx microcontrollers.
29
Du musst nun entweder die richtige Zeile durch entfernen der Kommentarzeilen aktivieren (blöd, da man die Includefiles meistens für verschiedene Projekte verwendet), oder (besser) Du definierst in Deiner IDE den entsprechenden Wert.
Wenn Du z.B. einen STM32F103 hättest, müsstest Du
definieren. Wenn Du den gcc per Hand oder Makefile aufrufst, z.B. mit "-D STM32F10X_LD" (das sagt dem gcc er soll diesen Wert definieren mit einem leeren Inhalt, das reicht hier).
