valgrind, finde den Fehler nicht
OP #7600504
Hallo. Ein kleines Problem bei einem Programm. Habe valgrind mal laufen lassen und folgenden Fehler, bei dem ich nicht ganz verstehe, was er meint. “Invalid read/write of size 8”. Vermutlich eine double Variable? Was genau habe ich falsch gemacht? Das Programm selbst läuft wie es sollte.
valgrind ./a.out --leak-check=yes
==29373== Memcheck, a memory error detector
==29373== Copyright (C) 2002-2022, and GNU GPL'd, by Julian Seward et al.
==29373== Using Valgrind-3.20.0 and LibVEX; rerun with -h for copyright info
==29373== Command: ./a.out --leak-check=yes
==29373==
Array 1
==29373== Invalid read of size 8
==29373==    at 0x4007F0: shift_array (in /home/michael/Documents/test/a.out)
==29373==    by 0x400A5B: main (in /home/michael/Documents/test/a.out)
==29373==  Address 0x4a6e090 is 0 bytes after a block of size 0 alloc'd
==29373==    at 0x4838744: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==29373==    by 0x400A01: main (in /home/michael/Documents/test/a.out)
==29373==
==29373== Invalid write of size 8
==29373==    at 0x40086A: shift_array (in /home/michael/Documents/test/a.out)
==29373==  Address 0x4a6e088 is 8 bytes before a block of size 0 alloc'd
==29373==
23
24
Shift Array 1 left by 1
25
26
Array 2 average
27
==29373==
28
==29373== HEAP SUMMARY:
29
==29373==     in use at exit: 0 bytes in 0 blocks
30
==29373==   total heap usage: 5 allocs, 5 frees, 1,056 bytes allocated
31
==29373==
32
==29373== All heap blocks were freed -- no leaks are possible
33
==29373==
34
==29373== For lists of detected and suppressed errors, rerun with: -s
35
==29373== ERROR SUMMARY: 2 errors from 2 contexts (suppressed: 0 from 0)
Hier das Beispiel unter Ubuntu:
gcc main.c -g -o main
valgrind ./main 0
Ergibt (Auszug):
==31658== Invalid read of size 8
==31658==    at 0x109317: shift_array (main.c:30)
==31658==    by 0x1095A9: main (main.c:85)
Die Codestelle ist:
double array_first_pos = a->data[0];
(Diese Codestelle hätte ich jetzt auch erwartet, dies ist offensichtlich: Bei 0 Einträgen ist dies 'out of range'.
OP #7600544
Niklas G. schrieb:
Kompilier mit Debug-Informationen, dann sind die Ausgaben von valgrind hilfreicher.
Das mache ich wie? Bin unter Linux mit gcc noch nicht so ganz fit. Kompiliert hat es ohne Fehler.
Andreas B. schrieb:
shift_array crasht wenn das Array die grösse 0 hat.
Welche Parameter hast du verwendet?
Andreas B. schrieb:
Die Codestelle ist:double array_first_pos = a->data[0]; (Diese Codestelle hätte ich jetzt auch erwartet, dies ist offensichtlich: Bei 0 Einträgen ist dies 'out of range'.
Du hast recht. Ohne Argument hat es 0.
Alexander S. schrieb:
Du hast beim Aufruf von valgrind das Argument für a.out vergessen.
schreibe es sovalgrind --leak-check=yes ./a.out 64
So hatte ich es anfangs, hatte aber nicht funktioniert. Vermutlich vertippt und danach den Parameter vergessen. Danke nochmal an Alle.
