FNIRSI DPOX180H
#7820625
Aus der Bedienungsanleitung:
USB connection to the computer to share pictures: First connect the oscilloscope to the computer with a Type-C USB cable, click【MENU】, a menu will pop up, use ↑↓ to the System settings column, and then click【MOD】/OK】, use ↑↓ to the USB sharing mode column, and then click【MOD/OK】to enter the USB sharing mode.
Beitrag #7820627 wurde von einem Moderator gelöscht.
OP #7820633
Danke Stefan, ich hatte [Charging Mode] gelesen :-/
Egal, auf zwei Linux Rechnern das selbe:
2025-01-30T14:50:33.023462+01:00 T440s kernel: [764249.693367] sd 3:0:0:0: [sdb] Attached SCSI removable disk
2025-01-30T14:51:03.943636+01:00 T440s kernel: [764280.613777] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
2025-01-30T14:51:04.095469+01:00 T440s kernel: [764280.766377] sd 3:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_TIME_OUT driverbyte=DRIVER_OK cmd_age=30s
2025-01-30T14:51:04.095490+01:00 T440s kernel: [764280.766386] sd 3:0:0:0: [sdb] tag#0 CDB: Read(10) 28 00 00 00 01 10 00 00 f0 00
2025-01-30T14:51:04.095493+01:00 T440s kernel: [764280.766389] I/O error, dev sdb, sector 272 op 0x0:(READ) flags 0x80700 phys_seg 30 prio class 2
2025-01-30T14:51:04.227509+01:00 T440s kernel: [764280.897881] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
2025-01-30T14:51:04.523511+01:00 T440s kernel: [764281.193865] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
2025-01-30T14:51:04.827513+01:00 T440s kernel: [764281.497780] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
2025-01-30T14:51:05.127509+01:00 T440s kernel: [764281.797824] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
2025-01-30T14:51:05.419523+01:00 T440s kernel: [764282.089842] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
2025-01-30T14:51:05.723514+01:00 T440s kernel: [764282.393866] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
2025-01-30T14:51:06.023541+01:00 T440s kernel: [764282.693982] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
2025-01-30T14:51:06.171492+01:00 T440s kernel: [764282.842587] sd 3:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=1s
2025-01-30T14:51:06.171513+01:00 T440s kernel: [764282.842602] sd 3:0:0:0: [sdb] tag#0 CDB: Read(10) 28 00 00 00 01 10 00 00 08 00
2025-01-30T14:51:06.171515+01:00 T440s kernel: [764282.842607] I/O error, dev sdb, sector 272 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
2025-01-30T14:51:06.171517+01:00 T440s kernel: [764282.842624] Buffer I/O error on dev sdb, logical block 34, async page read
2025-01-30T14:51:06.175765+01:00 T440s systemd-udevd[3089229]: sdb: Process '/usr/bin/unshare -m /usr/bin/snap auto-import --mount=/dev/sdb' failed with exit code 1.
2025-01-30T14:51:06.317701+01:00 T440s kernel: [764282.989752] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
2025-01-30T14:51:06.471491+01:00 T440s kernel: [764283.142477] sd 3:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
2025-01-30T14:51:06.471506+01:00 T440s kernel: [764283.142484] sd 3:0:0:0: [sdb] tag#0 CDB: Read(10) 28 00 00 00 74 3f 00 00 08 00
2025-01-30T14:51:06.471508+01:00 T440s kernel: [764283.142486] I/O error, dev sdb, sector 29759 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
2025-01-30T14:51:06.599455+01:00 T440s kernel: [764283.269977] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
23
2025-01-30T14:51:06.895534+01:00 T440s kernel: [764283.565752] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
24
2025-01-30T14:51:07.187540+01:00 T440s kernel: [764283.857944] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
25
2025-01-30T14:51:07.483544+01:00 T440s kernel: [764284.153902] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
26
2025-01-30T14:51:07.787483+01:00 T440s kernel: [764284.457840] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
27
2025-01-30T14:51:08.079483+01:00 T440s kernel: [764284.749769] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
28
2025-01-30T14:51:08.227457+01:00 T440s kernel: [764284.898132] sd 3:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=1s
29
2025-01-30T14:51:08.227479+01:00 T440s kernel: [764284.898140] sd 3:0:0:0: [sdb] tag#0 CDB: Read(10) 28 00 00 00 74 3f 00 00 01 00
30
2025-01-30T14:51:08.227481+01:00 T440s kernel: [764284.898142] I/O error, dev sdb, sector 29759 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
31
2025-01-30T14:51:08.227483+01:00 T440s kernel: [764284.898150] Buffer I/O error on dev sdb1, logical block 29696, async page read
32
2025-01-30T14:51:08.355480+01:00 T440s kernel: [764285.025801] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
33
2025-01-30T14:51:08.651626+01:00 T440s kernel: [764285.322016] usb 2-2: reset high-speed USB device number 48 using xhci_hcd
