1 |
swapnil@swapnil-HP-Z440:/var/log$ cat gpu-manager.log
2 |
log_file: /var/log/gpu-manager.log
3 |
last_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
4 |
new_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
5 |
can't access /run/u-d-c-nvidia-was-loaded file
6 |
can't access /opt/amdgpu-pro/bin/amdgpu-pro-px
7 |
Looking for nvidia modules in /lib/modules/5.4.0-150-generic/updates/dkms
8 |
Looking for amdgpu modules in /lib/modules/5.4.0-150-generic/updates/dkms
9 |
Is nvidia loaded? no
10 |
Was nvidia unloaded? no
11 |
Is nvidia blacklisted? no
12 |
Is intel loaded? no
13 |
Is radeon loaded? no
14 |
Is radeon blacklisted? no
15 |
Is amdgpu loaded? no
16 |
Is amdgpu blacklisted? no
17 |
Is amdgpu versioned? no
18 |
Is amdgpu pro stack? no
19 |
Is nouveau loaded? no
20 |
Is nouveau blacklisted? no
21 |
Is nvidia kernel module available? no
22 |
Is amdgpu kernel module available? no
23 |
Vendor/Device Id: 1002:6808
24 |
BusID "PCI:2@0:0:0"
25 |
Is boot vga? yes
26 |
Error: can't access /sys/bus/pci/devices/0000:02:00.0/driver
27 |
The device is not bound to any driver.
28 |
Error : Failed to open /dev/dri
29 |
30 |
31 |
32 |
Does it require offloading? no
33 |
last cards number = 1
34 |
Has amd? yes
35 |
Has intel? no
36 |
Has nvidia? no
37 |
How many cards? 1
38 |
Has the system changed? No
39 |
Single card detected
40 |
Nothing to do
41 |
42 |
swapnil@swapnil-HP-Z440:/var/log$ cat Xorg.0.log
43 |
[ 59.158] (--) Log file renamed from "/var/log/Xorg.pid-2109.log" to "/var/log/Xorg.0.log"
44 |
[ 59.158]
45 |
X.Org X Server 1.20.8
46 |
X Protocol Version 11, Revision 0
47 |
[ 59.158] Build Operating System: Linux 5.4.0-139-generic x86_64 Ubuntu
48 |
[ 59.158] Current Operating System: Linux swapnil-HP-Z440 5.4.0-150-generic #167~18.04.1-Ubuntu SMP Wed May 24 00:51:42 UTC 2023 x86_64
49 |
[ 59.158] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4.0-150-generic root=UUID=0506146e-8bdb-44b3-bbed-9c77d4da6981 ro recovery nomodeset dis_ucode_ldr
50 |
[ 59.158] Build Date: 29 March 2023 01:26:59PM
51 |
[ 59.158] xorg-server-hwe-18.04 2:1.20.8-2ubuntu2.2~18.04.11 (For technical support please see http://www.ubuntu.com/support)
52 |
[ 59.158] Current version of pixman: 0.34.0
53 |
[ 59.158] Before reporting problems, check http://wiki.x.org
54 |
to make sure that you have the latest version.
55 |
[ 59.158] Markers: (--) probed, (**) from config file, (==) default setting,
56 |
(++) from command line, (!!) notice, (II) informational,
57 |
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
58 |
[ 59.158] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Aug 16 17:36:40 2026
59 |
[ 59.159] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
60 |
[ 59.160] (==) No Layout section. Using the first Screen section.
61 |
[ 59.160] (==) No screen section available. Using defaults.
62 |
[ 59.160] (**) |-->Screen "Default Screen Section" (0)
63 |
[ 59.160] (**) | |-->Monitor "<default monitor>"
64 |
[ 59.160] (==) No monitor specified for screen "Default Screen Section".
65 |
Using a default monitor configuration.
66 |
[ 59.160] (==) Automatically adding devices
67 |
[ 59.160] (==) Automatically enabling devices
68 |
[ 59.160] (==) Automatically adding GPU devices
69 |
[ 59.160] (==) Automatically binding GPU devices
70 |
[ 59.160] (==) Max clients allowed: 256, resource mask: 0x1fffff
71 |
[ 59.160] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
72 |
[ 59.160] Entry deleted from font path.
73 |
[ 59.160] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
74 |
75 |
[ 59.160] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
76 |
77 |
[ 59.160] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
78 |
79 |
[ 59.160] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
80 |
81 |
[ 59.160] (==) FontPath set to:
82 |
/usr/share/fonts/X11/misc,
83 |
/usr/share/fonts/X11/Type1,
84 |
built-ins
85 |
[ 59.160] (==) ModulePath set to "/usr/lib/xorg/modules"
86 |
[ 59.160] (II) The server relies on udev to provide the list of input devices.
87 |
If no devices become available, reconfigure udev or disable AutoAddDevices.
88 |
[ 59.160] (II) Loader magic: 0x56090ea49020
89 |
[ 59.160] (II) Module ABI versions:
90 |
[ 59.160] X.Org ANSI C Emulation: 0.4
91 |
[ 59.160] X.Org Video Driver: 24.1
92 |
[ 59.160] X.Org XInput driver : 24.1
93 |
[ 59.160] X.Org Server Extension : 10.0
94 |
[ 59.161] (++) using VT number 1
95 |
96 |
[ 59.162] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c2
97 |
[ 59.167] (--) PCI:*(2@0:0:0) 1002:6808:1002:030c rev 0, Mem @ 0xe0000000/268435456, 0xf0000000/262144, I/O @ 0x00001000/256, BIOS @ 0x????????/131072
98 |
[ 59.168] (II) LoadModule: "glx"
99 |
[ 59.168] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
100 |
[ 59.170] (II) Module glx: vendor="X.Org Foundation"
101 |
[ 59.170] compiled for 1.20.8, module version = 1.0.0
102 |
[ 59.170] ABI class: X.Org Server Extension, version 10.0
103 |
[ 59.170] (==) Matched ati as autoconfigured driver 0
104 |
[ 59.170] (==) Matched modesetting as autoconfigured driver 1
105 |
[ 59.170] (==) Matched fbdev as autoconfigured driver 2
106 |
[ 59.170] (==) Matched vesa as autoconfigured driver 3
107 |
[ 59.170] (==) Assigned the driver to the xf86ConfigLayout
108 |
[ 59.170] (II) LoadModule: "ati"
109 |
[ 59.170] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
110 |
[ 59.171] (II) Module ati: vendor="X.Org Foundation"
111 |
[ 59.171] compiled for 1.20.5, module version = 19.1.0
112 |
[ 59.171] Module class: X.Org Video Driver
113 |
[ 59.171] ABI class: X.Org Video Driver, version 24.0
114 |
[ 59.231] (II) LoadModule: "radeon"
115 |
[ 59.231] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
116 |
[ 59.234] (II) Module radeon: vendor="X.Org Foundation"
117 |
[ 59.234] compiled for 1.20.5, module version = 19.1.0
118 |
[ 59.234] Module class: X.Org Video Driver
119 |
[ 59.234] ABI class: X.Org Video Driver, version 24.0
120 |
[ 59.234] (II) LoadModule: "modesetting"
121 |
[ 59.234] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
122 |
[ 59.235] (II) Module modesetting: vendor="X.Org Foundation"
123 |
[ 59.235] compiled for 1.20.8, module version = 1.20.8
124 |
[ 59.235] Module class: X.Org Video Driver
125 |
[ 59.235] ABI class: X.Org Video Driver, version 24.1
126 |
[ 59.235] (II) LoadModule: "fbdev"
127 |
[ 59.235] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
128 |
[ 59.235] (II) Module fbdev: vendor="X.Org Foundation"
129 |
[ 59.235] compiled for 1.20.1, module version = 0.5.0
130 |
131 |
[ 59.235] ABI class: X.Org Video Driver, version 24.0
132 |
[ 59.235] (II) LoadModule: "vesa"
133 |
[ 59.236] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
134 |
[ 59.236] (II) Module vesa: vendor="X.Org Foundation"
135 |
[ 59.236] compiled for 1.20.1, module version = 2.4.0
136 |
[ 59.236] Module class: X.Org Video Driver
137 |
[ 59.236] ABI class: X.Org Video Driver, version 24.0
138 |
[ 59.236] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
139 |
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
140 |
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
141 |
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
142 |
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
143 |
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
144 |
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
145 |
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
146 |
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
147 |
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
148 |
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
149 |
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
150 |
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
151 |
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
152 |
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
153 |
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
154 |
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
155 |
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
156 |
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
157 |
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
158 |
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
159 |
ATI Radeon 9800PRO, ATI Radeon 9800XT,
160 |
ATI Radeon Mobility 9600/9700 (M10/M11),
161 |
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
162 |
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
163 |
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
164 |
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
165 |
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
166 |
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
167 |
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
168 |
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
169 |
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
170 |
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
171 |
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
172 |
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
173 |
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
174 |
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
175 |
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
176 |
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
177 |
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
178 |
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
179 |
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
180 |
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
181 |
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
182 |
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
183 |
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
184 |
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
185 |
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
186 |
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
187 |
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
188 |
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
189 |
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
190 |
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
191 |
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
192 |
ATI FireGL V3350, ATI Mobility Radeon X1450,
193 |
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
194 |
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
195 |
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
196 |
ATI FireGL V3400, ATI Mobility FireGL V5250,
197 |
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
198 |
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
199 |
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
200 |
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
201 |
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
202 |
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
203 |
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
204 |
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
205 |
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
206 |
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
207 |
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
208 |
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
209 |
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
210 |
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
211 |
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
212 |
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
213 |
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
214 |
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
215 |
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
216 |
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
217 |
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
218 |
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
219 |
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
220 |
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
221 |
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
222 |
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
223 |
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
224 |
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
225 |
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
226 |
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
227 |
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
228 |
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
229 |
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
230 |
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
231 |
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
232 |
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
233 |
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
234 |
ATI FireGL V3600, ATI Radeon HD 2600 LE,
235 |
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
236 |
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
237 |
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
238 |
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
239 |
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
240 |
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
241 |
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
242 |
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
243 |
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
244 |
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
245 |
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
246 |
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
247 |
AMD Radeon HD 6300 Series Graphics,
248 |
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
249 |
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
250 |
AMD Firestream 9350, ATI Radeon HD 5800 Series,
251 |
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
252 |
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
253 |
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
254 |
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
255 |
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
256 |
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
257 |
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
258 |
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
259 |
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
260 |
MULLINS, KAVERI, HAWAII
261 |
[ 59.238] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
262 |
[ 59.238] (II) FBDEV: driver for framebuffer: fbdev
263 |
[ 59.238] (II) VESA: driver for VESA chipsets: vesa
264 |
[ 59.238] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
265 |
[ 59.238] (II) [KMS] drm report modesetting isn't supported.
266 |
[ 59.238] (EE) open /dev/dri/card0: No such file or directory
267 |
[ 59.238] (WW) Falling back to old probe method for modesetting
268 |
269 |
[ 59.238] (II) Loading sub module "fbdevhw"
270 |
[ 59.238] (II) LoadModule: "fbdevhw"
271 |
[ 59.239] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
272 |
[ 59.239] (II) Module fbdevhw: vendor="X.Org Foundation"
273 |
[ 59.239] compiled for 1.20.8, module version = 0.0.2
274 |
[ 59.239] ABI class: X.Org Video Driver, version 24.1
275 |
[ 59.239] (**) FBDEV(2): claimed PCI slot 2@0:0:0
276 |
[ 59.239] (II) FBDEV(2): using default device
277 |
[ 59.239] (EE) Screen 0 deleted because of no matching config section.
278 |
[ 59.239] (II) UnloadModule: "radeon"
279 |
280 |
[ 59.239] (II) UnloadModule: "modesetting"
281 |
[ 59.239] (II) FBDEV(0): Creating default Display subsection in Screen section
282 |
"Default Screen Section" for depth/fbbpp 24/32
283 |
[ 59.239] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
284 |
[ 59.239] (==) FBDEV(0): RGB weight 888
285 |
[ 59.239] (==) FBDEV(0): Default visual is TrueColor
286 |
[ 59.239] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
287 |
[ 59.239] (II) FBDEV(0): hardware: EFI VGA (video memory: 5120kB)
288 |
[ 59.239] (II) FBDEV(0): checking modes against framebuffer device...
289 |
[ 59.239] (II) FBDEV(0): checking modes against monitor...
290 |
[ 59.239] (II) FBDEV(0): Virtual size is 1280x1024 (pitch 1280)
291 |
[ 59.239] (**) FBDEV(0): Built-in mode "current": 131.1 MHz, 80.3 kHz, 76.6 Hz
292 |
[ 59.239] (II) FBDEV(0): Modeline "current"x0.0 131.09 1280 1312 1472 1632 1024 1028 1032 1048 -hsync -vsync -csync (80.3 kHz b)
293 |
[ 59.239] (==) FBDEV(0): DPI set to (96, 96)
294 |
[ 59.239] (II) Loading sub module "fb"
295 |
[ 59.239] (II) LoadModule: "fb"
296 |
[ 59.239] (II) Loading /usr/lib/xorg/modules/libfb.so
297 |
[ 59.240] (II) Module fb: vendor="X.Org Foundation"
298 |
[ 59.240] compiled for 1.20.8, module version = 1.0.0
299 |
[ 59.240] ABI class: X.Org ANSI C Emulation, version 0.4
300 |
[ 59.240] (**) FBDEV(0): using shadow framebuffer
301 |
[ 59.240] (II) Loading sub module "shadow"
302 |
[ 59.240] (II) LoadModule: "shadow"
303 |
[ 59.240] (II) Loading /usr/lib/xorg/modules/libshadow.so
304 |
[ 59.241] (II) Module shadow: vendor="X.Org Foundation"
305 |
[ 59.241] compiled for 1.20.8, module version = 1.1.0
306 |
[ 59.241] ABI class: X.Org ANSI C Emulation, version 0.4
307 |
[ 59.241] (II) UnloadModule: "vesa"
308 |
[ 59.241] (II) Unloading vesa
309 |
[ 59.241] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
310 |
[ 59.243] (==) FBDEV(0): Backing store enabled
311 |
[ 59.244] (==) FBDEV(0): DPMS enabled
312 |
[ 59.244] (II) Initializing extension Generic Event Extension
313 |
[ 59.244] (II) Initializing extension SHAPE
314 |
[ 59.244] (II) Initializing extension MIT-SHM
315 |
[ 59.244] (II) Initializing extension XInputExtension
316 |
[ 59.245] (II) Initializing extension XTEST
317 |
[ 59.245] (II) Initializing extension BIG-REQUESTS
318 |
[ 59.245] (II) Initializing extension SYNC
319 |
[ 59.245] (II) Initializing extension XKEYBOARD
320 |
[ 59.245] (II) Initializing extension XC-MISC
321 |
[ 59.245] (II) Initializing extension SECURITY
322 |
[ 59.245] (II) Initializing extension XFIXES
323 |
[ 59.245] (II) Initializing extension RENDER
324 |
[ 59.245] (II) Initializing extension RANDR
325 |
[ 59.245] (II) Initializing extension COMPOSITE
326 |
[ 59.245] (II) Initializing extension DAMAGE
327 |
[ 59.246] (II) Initializing extension MIT-SCREEN-SAVER
328 |
[ 59.246] (II) Initializing extension DOUBLE-BUFFER
329 |
[ 59.246] (II) Initializing extension RECORD
330 |
[ 59.246] (II) Initializing extension DPMS
331 |
[ 59.246] (II) Initializing extension Present
332 |
[ 59.246] (II) Initializing extension DRI3
333 |
[ 59.246] (II) Initializing extension X-Resource
334 |
[ 59.246] (II) Initializing extension XVideo
335 |
[ 59.246] (II) Initializing extension XVideo-MotionCompensation
336 |
[ 59.246] (II) Initializing extension SELinux
337 |
[ 59.246] (II) SELinux: Disabled on system
338 |
[ 59.246] (II) Initializing extension GLX
339 |
[ 59.246] (II) AIGLX: Screen 0 is not DRI2 capable
340 |
[ 59.364] (II) IGLX: Loaded and initialized swrast
341 |
[ 59.364] (II) GLX: Initialized DRISWRAST GL provider for screen 0
342 |
[ 59.364] (II) Initializing extension XFree86-VidModeExtension
343 |
[ 59.364] (II) Initializing extension XFree86-DGA
344 |
[ 59.364] (II) Initializing extension XFree86-DRI
345 |
[ 59.365] (II) Initializing extension DRI2
346 |
[ 59.408] (II) config/udev: Adding input device Power Button (/dev/input/event1)
347 |
[ 59.408] (**) Power Button: Applying InputClass "libinput keyboard catchall"
348 |
[ 59.408] (II) LoadModule: "libinput"
349 |
[ 59.408] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
350 |
[ 59.410] (II) Module libinput: vendor="X.Org Foundation"
351 |
[ 59.410] compiled for 1.20.1, module version = 0.28.1
352 |
[ 59.410] Module class: X.Org XInput Driver
353 |
[ 59.410] ABI class: X.Org XInput driver, version 24.1
354 |
[ 59.410] (II) Using input driver 'libinput' for 'Power Button'
355 |
[ 59.411] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 22 paused 0
356 |
[ 59.411] (**) Power Button: always reports core events
357 |
[ 59.411] (**) Option "Device" "/dev/input/event1"
358 |
[ 59.411] (**) Option "_source" "server/udev"
359 |
[ 59.411] (II) event1 - Power Button: is tagged by udev as: Keyboard
360 |
[ 59.411] (II) event1 - Power Button: device is a keyboard
361 |
[ 59.411] (II) event1 - Power Button: device removed
362 |
[ 59.411] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
363 |
