Der Download wurde ja im Mai 2011 aktualisiert. Ist denn da der Delay-Bug behoben oder immer noch nicht? Ich wüßte das gerne vorher, ehe ich umsonst >600MB downloade und installiere. Peter
Kann man denn die leidige AVR-Toolchain nicht separat von diesem riesigen AVR-Studio-Klumpen runterladen?
Peter Dannegger schrieb: > Ist denn da der Delay-Bug behoben Gabs da was? Wie sieht der aus?
AVR 8-bit GNU Toolchain: Release 3.3.0.364 The AVR 8-bit GNU Toolchain supports all AVR 8-bit devices. The AVR 8-bit Toolchain is based on the free and open-source GCC compiler. The toolchain includes compiler, assembler, linker and binutils (GCC and Binutils), source code libraries (AVRLibC), and debugger (GDB). Downloading and Installing The package comes in several forms. • As part of a standalone installer (avr-toolchain-installer) • As part of AVR Studio 5 Installer It can be downloaded from Atmel's website at http://www.atmel.com http://www.atmel.com/forms/software_download.asp?category_id=163&family_id=607&subfamily_id=760&fn=dl_avr-toolchain-installer-3.3.0.710-win32.win32.x86.exe Installing on Windows When installing as a part of AVR Studio 5 you do not have to do anything. See Release Notes for AVR Studio 5 for more details. The AVR Toolchain Installer can be downloaded from the website as noted above. After downloading, doubleclick the installer executable file to install. If you wish to specify the location where the AVR Studio 5 software is installed, choose "Custom Installation". Installing on Linux When installing as a part of AVR Studio 5 you do not have to do anything. See Release Notes for AVR Studio 5 for more details. On Linux AVR 32-bits GNU Toolchain is also available as a TAR.GZ archive which can be extracted using the 'tar' utility. Simply extract to the location where you want the application to run from.
p.s.: Peter, wenn's dir nur um den delay-Bug geht, dann genügt es natürlich völlig, wenn du eine aktuelle <util/delay.h> über die alte drüber installierst.
Lothar Miller schrieb: >> Ist denn da der Delay-Bug behoben > Gabs da was? Wie sieht der aus? Siehe hier http://www.mikrocontroller.net/topic/goto_post/2405329
