Datenblatt zum Motorola OF80B gesucht!
OP #2798163
Hallo Forum,
kann mir bitte jemand zum o.g. IC im 28 Pin SOWB Gehäuse
ein Link zu einem Datenblatt nennen.
Auf dem Motorola IC steht der Aufdruck SATMODUL.01
darunter OF80B und in der dritten Zeile LLEV9624.
IC ist aus dem TV/SAT Bereich.
Leider gibt das Googeln keine hilfreichen Infos her.
Danke im Voraus!
Markus
DL8MBY
OP
Hallo Hinz,
das einzige, was ich gefunden Habe ist:
Der zugehörige Link aufs DB zeigl leider ins Leere.
Markus
DL8MBY
OF80B
The CDR often includes a loss-of-lock (LOL) alarm, which monitors
whether the PLL is locked to the received data stream. The CDR's serial
stream of regenerated data and the recovered clock signal are usually
fed to a deserializer, whose conversion ratio depends on the data's bit
rate and the interface capability (speed) of the CMOS system components
The OF80B/OF80B combine four 12-bit, voltage-output digital-to-analog
converters (DACs) and four precision output amplifiers in a space-saving
16-pin package. Offset, gain, and linearity are factory calibrated to
provide the OF80Bs 1LSB total unadjusted error. The OF80B operates with
5V supplies, while the OF80B uses -5V and +12V to +15V supplies. Each
DAC has a double-buffered input, organized as an input register followed
by a DAC register. A 16-bit serial word is used to load data into each
input/DAC register. The serial interface is compatible with either
SPI/QSPI™ or Microwire™, and allows the input and DAC registers to be
updated independently or simulta- neously with a single software
command. The DAC reg- isters can be simultaneously updated with a
hardware LDAC pin. All logic inputs are TTL/CMOS compatible.
