Compilerfehlermeldungen DCF77 Uhr
Gast #3623964
Hi
Ich habe diese Funkuhr gebaut:
http://www.mikrocontroller.net/articles/DCF77-Funkwecker_mit_AVR
Wenn ich den Code nun im Atmel Studio kompilieren will kommen diese
Fehlermeldungen:
Warning  1  #warning "This header file is obsolete.  Use <avr/interrupt.h>." [-Wcpp]  e:\atmel toolchain\avr8 gcc\native\3.4.1051\avr8-gnu-toolchain\avr\include\avr\signal.h  36  2  GccApplication1
Error  2  attempt to use poisoned "SIG_INTERRUPT0"  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\dcf77.h  26  9  GccApplication1
Error  3  attempt to use poisoned "SIG_OVERFLOW0"  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\dcf77.h  27  9  GccApplication1
Error  4  attempt to use poisoned "SIG_OVERFLOW1"  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\timerfunctions.h  27  9  GccApplication1
Error  5  attempt to use poisoned "SIG_OVERFLOW2"  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\timerfunctions.h  28  9  GccApplication1
Error  6  attempt to use poisoned "SIG_OVERFLOW1"  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\timerfunctions.c  3  9  GccApplication1
Warning  7  'SIG_OVERFLOW1' appears to be a misspelled signal handler [enabled by default]  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\timerfunctions.c  3  9  GccApplication1
Error  8  attempt to use poisoned "SIG_OVERFLOW2"  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\timerfunctions.c  59  9  GccApplication1
Warning  9  'SIG_OVERFLOW2' appears to be a misspelled signal handler [enabled by default]  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\timerfunctions.c  59  9  GccApplication1
Warning  10  pointer targets in passing argument 2 of 'itoa' differ in signedness [-Wpointer-sign]  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\dcf77.c  108  2  GccApplication1
Message  11  expected 'char *' but argument is of type 'unsigned char *'  e:\atmel toolchain\avr8 gcc\native\3.4.1051\avr8-gnu-toolchain\avr\include\stdlib.h  418  7  GccApplication1
Warning  12  pointer targets in passing argument 2 of 'itoa' differ in signedness [-Wpointer-sign]  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\dcf77.c  167  2  GccApplication1
Message  13  expected 'char *' but argument is of type 'unsigned char *'  e:\atmel toolchain\avr8 gcc\native\3.4.1051\avr8-gnu-toolchain\avr\include\stdlib.h  418  7  GccApplication1
Error  14  attempt to use poisoned "SIG_INTERRUPT0"  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\dcf77.c  196  9  GccApplication1
Warning  15  'SIG_INTERRUPT0' appears to be a misspelled signal handler [enabled by default]  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\dcf77.c  196  9  GccApplication1
Error  16  attempt to use poisoned "SIG_OVERFLOW0"  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\dcf77.c  206  9  GccApplication1
Warning  17  'SIG_OVERFLOW0' appears to be a misspelled signal handler [enabled by default]  D:\Dokumente\AVR\Funkuhr\GccApplication1\GccApplication1\dcf77.c  206  9  GccApplication1
lgd
Persönliche Seite #3623971
Und?
Hast Du schon mal versucht, zu lesen, was da steht?
Fang mit der ersten Fehlermeldung an.
Warning  1  #warning
Du verwendest Code, in dem #include <signal.h> steht.
Gast #3624028
Die Source die Du verwendest ist für die alte Toolchain geschrieben!
Informiere Dich mal im Netz bzw. in den Helpfiles. Es hat sich einiges
an den Schreibweisen, bspw. der Interrupt-Vektorbezeichner, geändert!
