I2C atmega328p Problem
OP #4141114
Ich versuche mittels I2C/TWI eine Kommunikation zwischen Arduino Uno und
atmega328p herzustellen. Auf dem Arduino läuft die Wire Library mit
Beispielcode und am atmega die I2C Master library.
Code:
#include <avr/io.h>
#include <i2cmaster.h>
#ifndef F_CPU
#define F_CPU 16000000UL
#endif
#include <util/delay.h>
int main (void) {
   DDRB |= (1<<PB0);
   //PORTB = (1 << PB0);
   i2c_init();
   while(1){
       int err = i2c_start( 2 + I2C_WRITE );
     if ( !err ){
       i2c_write('0');
       i2c_stop();
       _delay_us(500);
     }else{
         PORTB = (1 << PB0);
         i2c_stop();
23
24
25
   return 0;
26
Es geschieht jedoch nichts und die LED an PB0 geht an.
Woran könnte das liegen?
#4141692
zusammen mit dem letzten Satz aus der Arduino Doku
Note
There are both 7- and 8-bit versions of I2C addresses. 7 bits identify
the device, and the eighth bit determines if it's being written to or
read from. The Wire library uses 7 bit addresses throughout. If you have
a datasheet or sample code that uses 8 bit address, you'll want to drop
the low bit (i.e. shift the value one bit to the right), yielding an
address between 0 and 127. However the addresses from 0 to 7 are not
used because are reserved so the first address that can be used is 8.
Du verwendest die 7-Bit Adresse 1
