JTAG /SWD Verbindungsproblem zu TM4C129ENCPDT
Gast #4553724
JLinkExe -device TM4C129ENCPDT -if SWD -speed 4000
SEGGER J-Link Commander V5.12c (Compiled Apr 21 2016 16:22:45)
DLL version V5.12c, compiled Apr 21 2016 16:22:40
Connecting to J-Link via USB...O.K.
Firmware: J-Link V9 compiled Mar 29 2016 18:46:37
Hardware version: V9.30
License(s): FlashBP, GDB
OEM: SEGGER-EDU
VTref = 3.280V
Type "connect" to establish a target connection, '?' for help
J-Link>connect
Device "TM4C129ENCPDT" selected.
Found SWD-DP with ID 0x2BA01477
Found Cortex-M4 r0p1, Little endian.
FPUnit: 6 code (BP) slots and 2 literal slots
CoreSight components:
ROMTbl 0 @ E00FF000
ROMTbl 0 [0]: FFF0F000, CID: B105E00D, PID: 000BB00C SCS
ROMTbl 0 [1]: FFF02000, CID: B105E00D, PID: 003BB002 DWT
ROMTbl 0 [2]: FFF03000, CID: B105E00D, PID: 002BB003 FPB
ROMTbl 0 [3]: FFF01000, CID: B105E00D, PID: 003BB001 ITM
ROMTbl 0 [4]: FFF41000, CID: B105900D, PID: 000BB9A1 TPIU
ROMTbl 0 [5]: FFF42000, CID: B105900D, PID: 000BB925 ETM
Cortex-M4 identified.
Es sieht ja so aus als ob die Verbindung klappt, aber dann beim Starten
des GDB servers:
JLinkGDBServer -device TM4C129ENCPDT -if JTAG -speed 1000
SEGGER J-Link GDB Server V5.12c Command Line Version
JLinkARM.dll V5.12c (DLL compiled Apr 21 2016 16:22:40)
-----GDB Server start settings-----
GDBInit file:                  none
GDB Server Listening port:     2331
SWO raw output listening port: 2332
Terminal I/O port:             2333
Accept remote connection:      yes
Generate logfile:              off
Verify download:               off
Init regs on start:            off
Silent mode:                   off
Single run mode:               off
Target connection timeout:     0 ms
------J-Link related settings------
J-Link Host interface:         USB
J-Link script:                 none
J-Link settings file:          none
------Target related settings------
Target device:                 TM4C129ENCPDT
Target interface:              JTAG
Target interface speed:        1000kHz
Target endian:                 little
Connecting to J-Link...
J-Link is connected.
Hardware: V9.30
OEM: SEGGER-EDU
Feature(s): FlashBP, GDB
Checking target voltage...
Target voltage: 3.28 V
Listening on TCP/IP port 2331
Connecting to target...
J-Link found 1 JTAG device, Total IRLen = 4
JTAG ID: 0x4BA00477 (Cortex-M4)
WARNING: CPU could not be halted
ERROR: Could not connect to target.
Target connection failed. GDBServer will be closed...Restoring target
state and closing J-Link connection...
Shutting down...
Please check power, connection and settings.
Ich würde das ganze mal aus dem Ti Code Composer heraus Probieren nur da
scheitert die Installation komplett
Gast #4553874
Ja,
J-Link>halt
J-Link>reset
Unknown command. '?' for help.
J-Link>r
Reset delay: 0 ms
Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET
bit.
J-Link>
Gast #4554384
Ich hab das ganze nochmal unter Windows probiert.
Selbes Problem. was mir aber auffällt wenn ich erst ein "r" für reset in
die JLinkExe.exe eingebe dann funktioniert auch ein halt.
