[V] 2 Industrie-PC Boards, neu, originalverpackt, unbenutzt, für 250 statt 800
OP (Firma: ANSTEC) #4702054
wegen Geschäftsauflösung günstig zu verkaufen:
2 Industrie-PC Boards, neu, originalverpackt, unbenutzt (1 wurde mal
kurz zum testen ausgepackt), incl. jede Menge Zubehör, Kabel und
Adapter,
Stückpreis normalerweise ca. 400 Euro,
hier supergünstig (nur beide zusammen)
für Gesamtpreis 250 Euro incl. Versand.
Beschreibung des Herstellers:
Industrial Single Board Computer
3.5 inches Miniboard, LE-374
Intel Atom processor, Onboard VGA, LVDS,
DVI, Giga LAN, Mini PCI, USB2.0, SATA
AC97 Audio and Compact Flash socket.
Form Factor:  3.5 inches Miniboard,
CPU:  Intel Atom N270 processor 1.6GHz,
Package type: FCBGA8 , Front side bus: 533MHz,
Memory:  One 200-pin DDR2 400/533 SO-DIMM SDRAM up to 2GB,
Non-ECC, unbuffered memory supported,
Chipset:  Intel 945GSE & ICH7M,
Real Time Clock:  Chipset integrated RTC with onboard lithium battery,
Watchdog Timer:  Generates a system reset with internal timer for
1min(sec) ~ 255min(sec),
Power Management:  ACPI 1.0 compliant, supports power saving mode,
VGA Interface:  Intel integrated extreme GMA 950(Graphic Media
Accelerator) Technology,
Video Memory:  Up to 224MB shared with system memory,
LVDS interface:  Onboard 18/ 24-bit dual channel LVDS connector,
SATA interface:  2 x serial ATA interface with 150MB/s transfer rate,
IDE interface:  IDE supports 44-Pin Disk On Module with +5V power
supply,
Flash interface: One Compact Flash Type II socket,
DVI Interface:  Onboard Chrontel CH7307C DVI Transmitter for DVI
interface,
Audio Interface:  Intel ICH7-M integrated with Realtek ALC655 5.1CH AC97
Codec,
LAN Interface:  1 x Intel 82574L Gigabit Ethernet controllers,
GPIO interface:  Onboard programmable 8-bit Digital I/O interface,
Extended Interface:  1 x Mini-PCI socket,
Internal I/O Ports:  1 x IrDA, 1 x GPIO, 1 x AUDIO, 1 x CDIN, 1 x LVDS,
2 x USB2.0, 1 x DVI
1 x RS232/RS422/485, 1 x LCD Inverter, 2 x SATA, 1 x HDTV,
External I/O Ports:  1 x COM, 1 x VGA, 1 x RJ45, 2 x USB2.0, 1 x PS2,
Power Requirement:  9~24V full range DC Input,
Dimension:  146mm x 101mm,
possible OS:  Windows embedded (incl on CD), LINUX.
