Drop Down zusammenfassen - ESP8266
OP #5494803
Hallo
Gibt es eine Möglichkeit, diesen Codebatzen zusammenzufassen:
 webpage += "<select name='Line_01'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_02'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_03'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_04'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_05'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_06'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_07'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_08'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_09'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_10'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_11'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_12'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_13'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_14'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_15'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_16'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_17'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
  webpage += "<select name='Line_18'><option value='000'>aus</option><option value='100'>rot</option><option value='010'>gruen</option><option value='001'>blau</option></select>\n";
also alle Parameter auslagern, sodass ich diese nur einmal ändern muss?
Und wäre das dann auch platzsparender?
Danke und Gruß
Gast #5494828
Die Codezeilen unterscheiden sich doch sowieso nur durch die beiden
Ziffern hinter "Line_". Damit ist das doch prädestiniert für eine
Schleife.
OP #5494994
Danke, so gehts:
  for (int j = 1; j <= 18; j++) {
    webpage += "<select name='Line_";
    webpage += j;
    webpage += "'><option value='000'>aus</option><option
OP #5494999
Mist, hier funktioniert es nicht so wie oben:
      if (server.argName(i) == "Line_1") {
        int R = server.arg(i).substring(0, 1).toInt() * 400;
        int G = server.arg(i).substring(1, 2).toInt() * 400;
        int B = server.arg(i).substring(2, 3).toInt() * 400;
        setPWM(0, R, G, B);
      if (server.argName(i) == "Line_2") {
        setPWM(1, R, G, B);
      if (server.argName(i) == "Line_3") {
        setPWM(2, R, G, B);
Noch n guter Hinweis?
Gast #5495031
Die ersten drei Zeilen jedes if-blocks sind doch identisch, also pack
sie oben drüber und mache in den if-blöcken nur den jeweiligen setPwm
aufruf. oder setze dort nur eine variable auf den jeweiligen wert und
setz die in den setpwm aufruf an erster stelle ein, dann ist nichts
dupliziert.
Für dein erstes problem: schau dir trotzdem nochmal sprintf an, dein
zeilenweises zusammenstöpseln ist nicht unbedingt schön
