(V) Spannungsregler, Logik, MCUs,
OP #5889271
Ich bin am Ausmisten und habe einige Teile abzugeben:
THT:
L7805CV,   TO220, Positive voltage regulators
L7905CV,   TO220, Negative voltage regulators
L78M12CV,  TO220, Precision 500 mA regulators
MCT7824CT, TO220, Three Terminal Positive Voltage Regulators
MC7805CT,  TO220, 1.0A Positive VoltageRegulators
MC78L05A,  TO92,  100mA Fixed Output Linear Regulator
LM79L05,   TO92,  3 Terminal Negative Regulators
LM337,     TO220, 3 Terminal Adjustable Negative Regulators
74HC14,    DIL14, Hex Schmitt Inverter
CD4051,    DIL16, 8-channel analog multiplexer/demultiplexer
74HC4051,  DIL16, 8-channel analog multiplexer/demultiplexer
74HC245,   DIL20, Octal bus transceiver; 3-state
DM74165,   DIL16, 8-BIT PARALLEL-TO-SERIALSHIFT REGISTER (DM8590)
74LS165,   DIL16, 8-BIT PARALLEL-TO-SERIALSHIFT REGISTER
HCF4010,   DIL16, Hex buffer/converter (non-inverting)
SN74HC240, DIL20, OCTAL BUFFERS AND LINE DRIVERS WITH 3 STATE OUTPUTS
TIP31C,    TO220, Power transistors
TSOP1738,          Photo Modules for PCM Remote Control Systems
23
TB2901H,   HZIP25, Power 47 W BTL × 4-ch Audio Power IC
24
MAX130CPL, PDIP40, LCD-Treiber 3 1/2 Digit ADC with Bandgap Reference
25
26
ATTINY13V-10PU, DIL8, 1K Flash
27
ATTINY44V-10PU, DIL14, 4K Flash
28
ATTINY84,       DIL14, 8K Flash
29
ATMEGA88-20PU,  DIL28, 8K Flash
30
ATMEGA168-20PU, DIL28, 16K Flash
31
32
SMT:
33
LM217,   TO263,  1.2V to 37V adjustable voltage regulators
34
LM317,   TO263,  1.5A Adjustable Output, Positive Voltage Regulator
35
78L05,   SO8,    100mA Fixed Output Linear Regulator
36
78M05,   DPAK,   Precision 500 mA regulators
37
78M15,   DPAK,   Precision 500 mA regulators
38
39
MIC5801, SO24,   8-Bit Parallel-Input Latched Drivers
40
41
AT90CAN128-15AZ, TQFP64, 128K Flash
42
PIC16F628, SSOP20
43
LPC1766, LQFP100, ARM Cortex-M3, 100MHz, 256K Flash
SST 49LF020A (habe ich mal für ein Epox Mainboard gebraucht, kommen wohl
auch in der XBOX zum Einsatz)
Kingbright 5-/7-Segment-Anzeigen (datecode Ende 2001), ausgelötet,
müssten gemeinsame Kathode haben
FC56-11PGWA
SC56-11PGWA
Rafi-Taster, weiße Fläche, mit LEDs, ausgelötet
Nokia-Akkus BL-4C und BL-5B
2x Quecksilber-Schalter
YARD-IR-Empfänger rev. 2 mit PIC16F628, PDIP18 und MAX232
Mini-ICE mit ATMEGA16-16AU und FT232RL
Xilinx programmer by martiniman, LPT-Port
Schreibt mir einfach welche Teile euch interessieren und was sie euch
wert sind.
OP #5890453
Muss ich? In erster Linie freue ich mich wenn jemand die Teile brauchen
kann. D.h. das meiste davon ist zu verschenken.
Für die folgenden Teile würde ich 50% des Reichelt- bzw. Digikey-Preises
ansetzen, d.h.
ATTINY13V-10PU,  0,50
ATTINY44V-10PU,  1,-
ATTINY84,        0,60
ATMEGA88-20PU,   1,10
ATMEGA168-20PU,  1,30
MIC5801,         1,20
AT90CAN128-15AZ, 2,70
PIC16F628,       1,00
LPC1766,         4,00
YARD-IR-Empfänger rev. 2 mit PIC16F628, PDIP18 und MAX232,  1,20
Mini-ICE mit ATMEGA16-16AU und FT232RL,  2,60
Beitrag #5894251 wurde von einem Moderator gelöscht.
OP #5896759
Lukas E. schrieb:
> Die Spannungsregler, 7 Segment-Anzeigen und RAFI Taster könnte ich
> brauchen, was soll das mich kosten?
Hast du noch Interesse? Hab dir am Sonntag eine PN geschrieben.
Die Logik-ICs sind komplett weg und die ATtinys auch. Von den
5-/7-Segmentanzeigen und den THT-Spannungsreglern sind es weniger
geworden. Der Rest ist noch verfügbar.
Neu dazu gekommen sind:
Neutrik-Buchse
2 Potis
2 IF5961 induktive Sensoren von IFM
2 DIL-Adapterplatinen
3 Bungard-Platinen
Sharp LM64148Z, VGA LCD
diverse CCFL, teils mit, teils ohne Inverter
diverse Lüfter
