vom Atmega 8 zum Atmega 168
Gast #1809467
Hallo!
Habe soeben von Reichelt µC geliefert bekommen und wollte sofort mit AVR
Studio loslegen. Leider funktioniert es nicht. Hier mal der obere teil
des Code. Hat jemand eine Idee?????  Daaaaanke!
.include  "m168def.inc"
.cseg
.org 0
; Reset and Interrupt vector             ;VNr.  Beschreibung
.org 0x000
       rjmp main
.org INT0addr                 ; External Interrupt0 Vector Address
     reti
.org INT1addr                 ; External Interrupt1 Vector Address
     reti
.org OC2addr                  ; Output Compare2 Interrupt Vector Address
     reti
.org OVF2addr                 ; Overflow2 Interrupt Vector Address
     reti
.org ICP1addr                 ; Input Capture1 Interrupt Vector Address
     reti
.org OC1Aaddr                 ; Output Compare1A Interrupt Vector
Address
       rjmp  TIMER
.org OC1Baddr                 ; Output Compare1B Interrupt Vector
Address
       reti
.org OVF1addr                 ; Overflow1 Interrupt Vector Address
       reti
.org OVF0addr                 ; Overflow0 Interrupt Vector Address
       reti
.org SPIaddr                  ; SPI Interrupt Vector Address
     reti
.org URXCaddr                 ; USART Receive Complete Interrupt Vector
Address
       reti
.org UDREaddr                 ; USART Data Reg. Empty Interr. Vector
Address
       reti
.org UTXCaddr                 ; USART Transmit Complete Interrupt Vector
Address
       reti
.org ADCCaddr                 ; ADC Interrupt Vector Address
       reti
.org ERDYaddr                 ; EEPROM Interrupt Vector Address
       reti
.org ACIaddr                  ; Analog Comparator Interrupt Vector
Address
     reti
.org TWIaddr                  ; Irq. vector address for Two-Wire
Interface
       reti
.org INT_VECTORS_SIZE
.equ    XTAL  =  3686400;H
; Start, Power ON, Reset
main:    ldi       r16, LOW(RAMEND)     ; Stackpointer initialisieren
          out       SPL, r16
          ldi       r16, HIGH(RAMEND)
          out       SPH, r16
      ldi       r16, high( 7200 - 1 )
           out       OCR1AH, r16
          ldi       r16, low( 7200 - 1 )
          out       OCR1AL, r16
          ldi       r16, ( 1 << WGM12 ) | ( 1 << CS12 )
          out       TCCR1B, r16
          ldi       r16, 1 << OCIE1A  ; OCIE1A: Interrupt bei Timer
Compare
          out       TIMSK, r16
      sei
Gast #1809474
Ja, tut mir leid. 4 Errors beim versuch zu assemblieren
I:\Elektro\AVR Studio
Projekte\Laufzeitueberwachung_Futterautomat_07.asm(15): Including file
'C:\Programme\Atmel\AVR Tools\AvrAssembler2\Appnotes\m168def.inc'
Projekte\Laufzeitueberwachung_Futterautomat_07.asm(85): error: Operand 1
out of range: 0x89
Projekte\Laufzeitueberwachung_Futterautomat_07.asm(87): error: Operand 1
out of range: 0x88
Projekte\Laufzeitueberwachung_Futterautomat_07.asm(89): error: Operand 1
out of range: 0x81
Projekte\Laufzeitueberwachung_Futterautomat_07.asm(92): error: Undefined
symbol: TIMSK
Projekte\Laufzeitueberwachung_Futterautomat_07.asm(331): No EEPROM data,
deleting I:\Elektro\AVR Studio
Projekte\Laufzeitueberwachung_Futterautomat_07.eep
Gast #1809518
Hab jetzt selbst probiert:
.cseg
.org 0
.org 0x000
       rjmp main
;.org INT0addr                 ; External Interrupt0 Vector Address
     reti
;.org INT1addr                 ; External Interrupt1 Vector Address
     reti
;.org OC2addr                  ; Output Compare2 Interrupt Vector
Address
     reti
;.org OVF2addr                 ; Overflow2 Interrupt Vector Address
     reti
;.org ICP1addr                 ; Input Capture1 Interrupt Vector Address
     reti
     reti
     reti
     reti
     reti
     reti
;.org OC1Aaddr                 ; Output Compare1A Interrupt Vector
Address
       rjmp  TIMER
;.org OC1Baddr                 ; Output Compare1B Interrupt Vector
Address
        reti
;.org OVF1addr                 ; Overflow1 Interrupt Vector Address
     reti
;.org OVF0addr                 ; Overflow0 Interrupt Vector Address
     reti
;.org SPIaddr                  ; SPI Interrupt Vector Address
     reti
;.org URXCaddr                 ; USART Receive Complete Interrupt Vector
Address
     reti
;.org UDREaddr                 ; USART Data Reg. Empty Interr. Vector
Address
     reti
;.org UTXCaddr                 ; USART Transmit Complete Interrupt
Vector Address
     reti
;.org ADCCaddr                 ; ADC Interrupt Vector Address
     reti
;.org ERDYaddr                 ; EEPROM Interrupt Vector Address
     reti
;.org ACIaddr                  ; Analog Comparator Interrupt Vector
Address
     reti
;.org TWIaddr                  ; Irq. vector address for Two-Wire
Interface
     reti
     reti
     reti
     reti
          out       SPL, r16
          out       SPH, r16
           out       OCR1AH, r16
          out       OCR1AL, r16
          out       TCCR1B, r16
Compare
          out       TIMSK0, r16
      sei
das kommt dabei raus:
Projekte\Laufzeitueberwachung_Futterautomat_07.asm(79): error: Operand 1
out of range: 0x89
Projekte\Laufzeitueberwachung_Futterautomat_07.asm(81): error: Operand 1
out of range: 0x88
Projekte\Laufzeitueberwachung_Futterautomat_07.asm(83): error: Operand 1
out of range: 0x81
Projekte\Laufzeitueberwachung_Futterautomat_07.asm(86): error: Operand 1
out of range: 0x6e
Projekte\Laufzeitueberwachung_Futterautomat_07.asm(325): No EEPROM data,
Gast #1809528
Hi
Also zu Mitschreiben:
>error: Operand 1 out of range: 0x89
bezieht sich auf
>           out       OCR1AH, r16
OCR1AH liegt aber beim ATMega168 in einem Adressbereich, der mit 'out'
nicht mehr erreichbar ist. Deshalb muss auf OCR1AH zum Schreiben mit
'sts' zugegriffen werden.
-> sts OCR1AH,r16
>Undefined symbol: TIMSK
Der ATMega168 hat kein TIMSK-Register. Hier hat jeder Timer ein eigenes
TIMSK-Register.Also wird für Timer1 aus TIMSK  TIMSK1.
Außerdem stimmt deine Interruptvektortabelle nicht. Der ATMega168 hat
mehr Interrupts.
Findest du aber alles in der oben verlinkten AppNote.
MfG Spess
