Rocket IO TXUSRCLK
Gast #2152635
Liebe Kollegen!
Ich habe einen Xlinx Rocket IO in meinem Design. Er funktioniert in der
Simulation (sendet mit der richtigen Rate) aber leider sendet er nur 7
von 20 Bits. Ich vermute ich habe bei der CLK etwas falsch gemacht. Kann
mir vielleicht jemand helfen?
Senderate: 1,5 Gbps
RefClk (im Core Generator eingestellt): 75MHz
SysClk: 100 MHZ
die 150 MHz kommen von 1,5Gbps/10=150MHz.
D A N K E ! ! !
Harald
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
library UNISIM;
use UNISIM.VCOMPONENTS.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity Top is
  port (
   Reset              : in   std_logic;
   clk                : in   std_logic;
   TILE0_TXN0_OUT                          : out  std_logic;
    TILE0_TXN1_OUT                          : out  std_logic;
23
    TILE0_TXP0_OUT                          : out  std_logic;
24
    TILE0_TXP1_OUT                          : out  std_logic;
25
   TILE0_RXN0_IN             : in   std_logic;
26
    TILE0_RXN1_IN             : in   std_logic;
27
    TILE0_RXP0_IN             : in   std_logic;
28
    TILE0_RXP1_IN             : in   std_logic
29
30
end Top;
31
32
architecture Behavioral of Top is
33
34
35
  signal s_TILE0_RXDATA0_OUT                       :   std_logic_vector(19 downto 0);
36
  signal s_TILE0_RXDATA1_OUT                       :   std_logic_vector(19 downto 0);
37
  signal s_TILE0_PLLLKDET_OUT                      :   std_logic;
38
  signal s_TILE0_REFCLKOUT_OUT                     :   std_logic;
39
  signal s_TILE0_RESETDONE0_OUT                    :   std_logic;
40
  signal s_TILE0_RESETDONE1_OUT                    :   std_logic;
41
  signal s_TILE0_TXOUTCLK0_OUT                     :   std_logic;
42
  signal s_TILE0_TXOUTCLK1_OUT                     :   std_logic;
43
  signal s_TILE0_TXDATA0_IN                        :   std_logic_vector(19 downto 0);
44
  signal s_TILE0_TXDATA1_IN                        :   std_logic_vector(19 downto 0);
45
  signal s_clk_75                                  :   std_logic;
46
  signal s_clk_150                                 :   std_logic;
47
48
49
50
component R_IO
51
generic
52
53
    -- Simulation attributes
54
    WRAPPER_SIM_GTPRESET_SPEEDUP    : integer   := 0; -- Set to 1 to speed up sim reset
55
    WRAPPER_SIM_PLL_PERDIV2         : bit_vector:= x"14d" -- Set to the VCO Unit Interval time
56
57
port
58
59
60
    --_________________________________________________________________________
61
62
    --TILE0  (Location)
63
64
    --------------- Receive Ports - Comma Detection and Alignment --------------
65
    TILE0_RXENPCOMMAALIGN0_IN               : in   std_logic;
66
    TILE0_RXENPCOMMAALIGN1_IN               : in   std_logic;
67
    ------------------- Receive Ports - RX Data Path interface -----------------
68
    TILE0_RXDATA0_OUT                       : out  std_logic_vector(19 downto 0);
69
    TILE0_RXDATA1_OUT                       : out  std_logic_vector(19 downto 0);
70
    TILE0_RXUSRCLK0_IN                      : in   std_logic;
71
    TILE0_RXUSRCLK1_IN                      : in   std_logic;
72
    TILE0_RXUSRCLK20_IN                     : in   std_logic;
73
    TILE0_RXUSRCLK21_IN                     : in   std_logic;
74
    ------- Receive Ports - RX Driver,OOB signalling,Coupling and Eq.,CDR ------
75
76
77
78
    TILE0_RXP1_IN                           : in   std_logic;
79
    --------------------- Shared Ports - Tile and PLL Ports --------------------
80
    TILE0_CLKIN_IN                          : in   std_logic;
81
    TILE0_GTPRESET_IN                       : in   std_logic;
82
    TILE0_PLLLKDET_OUT                      : out  std_logic;
83
    TILE0_REFCLKOUT_OUT                     : out  std_logic;
84
    TILE0_RESETDONE0_OUT                    : out  std_logic;
85
    TILE0_RESETDONE1_OUT                    : out  std_logic;
86
    ------------------ Transmit Ports - TX Data Path interface -----------------
87
    TILE0_TXDATA0_IN                        : in   std_logic_vector(19 downto 0);
88
    TILE0_TXDATA1_IN                        : in   std_logic_vector(19 downto 0);
89
    TILE0_TXOUTCLK0_OUT                     : out  std_logic;
90
    TILE0_TXOUTCLK1_OUT                     : out  std_logic;
91
    TILE0_TXUSRCLK0_IN                      : in   std_logic;
92
    TILE0_TXUSRCLK1_IN                      : in   std_logic;
93
    TILE0_TXUSRCLK20_IN                     : in   std_logic;
94
    TILE0_TXUSRCLK21_IN                     : in   std_logic;
95
    --------------- Transmit Ports - TX Driver and OOB signalling --------------
96
    TILE0_TXDIFFCTRL0_IN                    : in   std_logic_vector(2 downto 0);
97
    TILE0_TXDIFFCTRL1_IN                    : in   std_logic_vector(2 downto 0);
98
99
100
101
102
    TILE0_TXPREEMPHASIS0_IN                 : in   std_logic_vector(2 downto 0);
103
    TILE0_TXPREEMPHASIS1_IN                 : in   std_logic_vector(2 downto 0)
104
105
106
107
end component;
108
109
  COMPONENT clk_wiz
110
  PORT(
111
    CLKIN1_IN : IN std_logic;
112
    RST_IN : IN std_logic;
113
    CLKOUT0_OUT : OUT std_logic;
114
    CLKOUT1_OUT : OUT std_logic
115
116
  END COMPONENT;
117
118
component Data
119
    Port ( clk : in  STD_LOGIC;
120
           reset : in  STD_LOGIC;
121
           txdata0 : out  STD_LOGIC_VECTOR (19 downto 0);
122
           txdata1 : out  STD_LOGIC_VECTOR (19 downto 0);
123
           rxdata0 : in  STD_LOGIC_VECTOR (19 downto 0);
124
           rxdata1 : in  STD_LOGIC_VECTOR (19 downto 0));
125
end component;
126
127
begin
128
129
----------------------------- The GTP Wrapper -----------------------------
130
131
132
    r_io_i : R_IO
133
    generic map
134
135
        WRAPPER_SIM_GTPRESET_SPEEDUP    =>      1,
136
        WRAPPER_SIM_PLL_PERDIV2         =>      x"14d"
137
138
    port map
139
140
141
142
        --TILE0  (X0Y0)
143
144
145
        TILE0_RXENPCOMMAALIGN0_IN       =>      '0',
146
        TILE0_RXENPCOMMAALIGN1_IN       =>      '0',
147
148
        TILE0_RXDATA0_OUT               =>      s_TILE0_RXDATA0_OUT,
149
        TILE0_RXDATA1_OUT               =>      s_TILE0_RXDATA1_OUT,
150
      TILE0_RXUSRCLK0_IN              =>      '0',
151
        TILE0_RXUSRCLK1_IN              =>      '0',
152
        TILE0_RXUSRCLK20_IN             =>      '0',
153
        TILE0_RXUSRCLK21_IN             =>      '0',
154
155
        TILE0_RXN0_IN                   =>      TILE0_RXN0_IN,
156
        TILE0_RXN1_IN                   =>      TILE0_RXN1_IN,
157
        TILE0_RXP0_IN                   =>      TILE0_RXP0_IN,
158
        TILE0_RXP1_IN                   =>      TILE0_RXP1_IN,
159
160
        TILE0_CLKIN_IN                  =>      s_clk_75,
161
        TILE0_GTPRESET_IN               =>      reset,
162
        TILE0_PLLLKDET_OUT              =>      s_TILE0_PLLLKDET_OUT,
163
        TILE0_REFCLKOUT_OUT             =>      s_TILE0_REFCLKOUT_OUT,
164
        TILE0_RESETDONE0_OUT            =>      s_TILE0_RESETDONE0_OUT,
165
        TILE0_RESETDONE1_OUT            =>      s_TILE0_RESETDONE1_OUT,
166
167
        TILE0_TXDATA0_IN                =>      s_TILE0_TXDATA0_IN,
168
        TILE0_TXDATA1_IN                =>      s_TILE0_TXDATA1_IN,
169
        TILE0_TXOUTCLK0_OUT             =>      s_TILE0_TXOUTCLK0_OUT,
170
        TILE0_TXOUTCLK1_OUT             =>      s_TILE0_TXOUTCLK1_OUT,
171
        TILE0_TXUSRCLK0_IN              =>      s_clk_150,
172
        TILE0_TXUSRCLK1_IN              =>      s_clk_150,
173
        TILE0_TXUSRCLK20_IN             =>      s_clk_150,
174
        TILE0_TXUSRCLK21_IN             =>      s_clk_150,
175
176
        TILE0_TXDIFFCTRL0_IN            =>      "000",
177
        TILE0_TXDIFFCTRL1_IN            =>      "000",
178
        TILE0_TXN0_OUT                  =>      TILE0_TXN0_OUT,
179
        TILE0_TXN1_OUT                  =>      TILE0_TXN1_OUT,
180
        TILE0_TXP0_OUT                  =>      TILE0_TXP0_OUT,
181
        TILE0_TXP1_OUT                  =>      TILE0_TXP1_OUT,
182
        TILE0_TXPREEMPHASIS0_IN         =>      "000",
183
        TILE0_TXPREEMPHASIS1_IN         =>      "000"
184
185
186
187
188
Inst_clk_wiz: clk_wiz PORT MAP(
189
    CLKIN1_IN => clk,
190
    RST_IN => reset,
191
    CLKOUT0_OUT => s_clk_75,
192
      CLKOUT1_OUT => s_clk_150
193
194
195
Inst_data : data Port Map(
196
        clk => s_clk_75,
197
           reset => reset,
198
           txdata0 => s_TILE0_TXDATA0_IN,
199
           txdata1 => s_TILE0_TXDATA1_IN,
200
           rxdata0 => s_TILE0_RXDATA0_OUT,
201
           rxdata1 => s_TILE0_RXDATA1_OUT
202
203
204
end Behavioral;
