Hallo..
Ich habe folgendes Problem:
Ich will das MI0283qt mit dem XC164 ansteuern.
Die Kommunikation sollte funktionieren, da ich eine vorgefertigte datei
verwendet habe..Leider zeigt das Display nichts an. Nur die
Hintergrundbeleutung leuchtet. Ich weis auch nicht genau, was ich ans
Diplay schicken muss, dass z.B. ein Strich oder ein Viereck zusehen ist.
Hier mein Programm Code:
main.c
#include <XC164.h>
#include <intrins.h>
#include "main.h"
#include "spi.h"
#include "display.h"
#include "touch.h"
void delay(unsigned long i)
while(i--)
_nop_();
void main()
DP1L |= 0x03; // init Reset and /CS_LCD
P1L |= 0x03; // disable Reset and /CS_LCD
init_spi();
init_touch();
lcd_reset();
while(!PEN_DETECT());
//lcd_clear(RGB(0x00,0x00,0x00));
lcd_clear(RGB(0xFF,0x00,0x00));
//lcd_clear(RGB(0x00,0xFF,0x00));
//lcd_clear(RGB(0x00,0x00,0xFF));
while (1)
_nop_();
dsiplay.c
#include <XC164.h>
#include "main.h"
#include "spi.h"
void lcd_drawstop(void)
LCD_CS_DISABLE();
return;
void lcd_drawstart(void)
LCD_CS_ENABLE();
write_spi(LCD_REGISTER);
write_spi(0x22);
LCD_CS_DISABLE();
LCD_CS_ENABLE();
write_spi(LCD_DATA);
return;
void lcd_area(unsigned int x0, unsigned int y0, unsigned int x1,
unsigned int y1)
lcd_cmd(0x03, (x0>>0)); //set x0
lcd_cmd(0x02, (x0>>8)); //set x0
lcd_cmd(0x05, (x1>>0)); //set x1
lcd_cmd(0x04, (x1>>8)); //set x1
lcd_cmd(0x07, (y0>>0)); //set y0
lcd_cmd(0x06, (y0>>8)); //set y0
lcd_cmd(0x09, (y1>>0)); //set y1
lcd_cmd(0x08, (y1>>8)); //set y1
return;
void lcd_cursor(unsigned int x, unsigned int y)
lcd_area(x, y, x, y);
return;
void lcd_cmd(unsigned int reg, unsigned int param)
LCD_CS_ENABLE();
write_spi(reg);
LCD_CS_DISABLE();
LCD_CS_ENABLE();
write_spi(param);
LCD_CS_DISABLE();
return;
void lcd_data(unsigned int c)
LCD_CS_ENABLE();
write_spi(c>>8);
write_spi(c);
LCD_CS_DISABLE();
return;
void lcd_reset(void)
//reset
LCD_CS_DISABLE();
LCD_RST_ENABLE();
delay(10000);
LCD_RST_DISABLE();
delay(10000);
//driving ability
lcd_cmd(0xEA, 0x0000);
lcd_cmd(0xEB, 0x0020);
lcd_cmd(0xEC, 0x000C);
lcd_cmd(0xED, 0x00C4);
lcd_cmd(0xE8, 0x0040);
lcd_cmd(0xE9, 0x0038);
lcd_cmd(0xF1, 0x0001);
lcd_cmd(0xF2, 0x0010);
lcd_cmd(0x27, 0x00A3);
//power voltage
lcd_cmd(0x1B, 0x001B);
lcd_cmd(0x1A, 0x0001);
lcd_cmd(0x24, 0x002F);
lcd_cmd(0x25, 0x0057);
//VCOM offset
lcd_cmd(0x23, 0x008D); //for flicker adjust
//power on
lcd_cmd(0x18, 0x0036);
lcd_cmd(0x19, 0x0001); //start osc
lcd_cmd(0x01, 0x0000); //wakeup
lcd_cmd(0x1F, 0x0088);
delay(10000);
lcd_cmd(0x1F, 0x0080);
delay(10000);
lcd_cmd(0x1F, 0x0090);
delay(10000);
lcd_cmd(0x1F, 0x00D0);
delay(10000);
//color selection
lcd_cmd(0x17, 0x0005); //0x0005=65k, 0x0006=262k
//panel characteristic
lcd_cmd(0x36, 0x0000);
delay(10000);
//lcd_cmd(0x3c, 0x00FF);
//lcd_cmd(0x3d, 0x0004);
//lcd_cmd(0x3f, 0x00FF);
//display on
lcd_cmd(0x28, 0x0038);
delay(10000);
lcd_cmd(0x28, 0x003C);
//display options
#ifdef LCD_MIRROR
lcd_cmd(0x16, 0x0068); //MY=0 MX=1 MV=1 ML=0 BGR=1
#else
lcd_cmd(0x16, 0x00A8); //MY=1 MX=0 MV=1 ML=0 BGR=1
#endif
lcd_area(0, 0, (LCD_WIDTH-1), (LCD_HEIGHT-1));
return;
void lcd_clear(unsigned int color)
unsigned int i;
lcd_cursor(40,40);
//lcd_area(0, 0, (LCD_WIDTH-1), (LCD_HEIGHT-1));
lcd_drawstart();
//for(i=0;i<(LCD_WIDTH*LCD_HEIGHT);i++)
lcd_data(color);
lcd_drawstop();
spi.c
#include <XC164.h>
#include "spi.h"
void init_spi(void) {
// Enable access to control bits
SSC0_CON_EN = 0;
SSC0_CON = 0xC037;
SSC0_BR = 0; // full speed
/* _bfld_() sets bits via bit mask of the specified SFR
* void bfld ( unsigned int sfr, // the SFR name
* int mask, // the data bits mask
* int data); // the data value
_bfld_(ALTSEL0P3,0x2300,0x2200); /* Select alternate functions SCLK
and MTSR */
_bfld_(P3,0x2300,0x2200); /* Must set Port 3 latch due to "AND"
configuration */
_bfld_(DP3,0x2300,0x2200); /* Set input/output directions */
SSC0_CON_EN = 1;
unsigned char write_spi(unsigned char byte)
SSC0_TB = byte; // write byte to transmit
buffer
while(SSC0_CON_BSY);
return (SSC0_RB & 0xFF); //return received
value
touch.c
#include <XC164.h>
#include "spi.h"
#include "touch.h"
void init_touch(void) {
DP1L |= 0x80; // init /CS_TOUCH
P1L |= 0x80; // disable /CS_TOUCH
DP9 &= 0xFC; // BUSY and IRQ as input
INTRINS.H
Intrinsic functions
for C166/EC++ Version 5.
Copyright (c) 1992-2004 Keil Elektronik GmbH and Keil Software, Inc.
All rights reserved.
#ifndef _INTRINS_H_
#define _INTRINS_H_
#ifdef __cplusplus // EC++
extern "C" {
#endif
void nop (void);
void idle (void);
void srvwdt (void);
void pwrdn (void);
void diswdt (void);
void einit (void);
void bfld (unsigned int sfr_, unsigned mask1, unsigned mask2);
void trap (int intno);
void atomic (int n_instr);
void endatomic (void);
#if (_MODEL_ != 0) /* if not tiny model */
unsigned int sof (void huge *adr);
#else
unsigned int sof (void *adr);
#endif
bit testclear (bit);
bit testset (bit);
extern unsigned char crol (unsigned char v, int cnt);
extern unsigned int irol (unsigned int v, int cnt);
extern unsigned long lrol (unsigned long v, int cnt);
extern unsigned char cror (unsigned char v, int cnt);
extern unsigned int iror (unsigned int v, int cnt);
extern unsigned long lror (unsigned long v, int cnt);
extern int prior (int v);
extern int priord (long v);
extern int pop (void);
extern void push (int v);
extern unsigned int chkfloat (float x);
extern unsigned int chkdouble (double x);
#endif
#endif
main.h
#ifndef MAIN_H
#define MAIN_H
void delay(unsigned long i);
#endif
spi.h
#ifndef SPI_H
#define SPI_H
void init_spi(void);
unsigned char write_spi(unsigned char byte);
#endif
display.h
#ifndef _DISPLAY_H_
#define _DISPLAY_H_
//#define LCD_MIRROR //define to mirror the display
#define LCD_WIDTH (320)
#define LCD_HEIGHT (240)
#define RGB(r,g,b) (((r&0xF8)<<8)|((g&0xFC)<<3)|((b&0xF8)>>3))
//5 red | 6 green | 5 blue
#define LCD_ID (0)
#define LCD_DATA ((0x72)|(LCD_ID<<2))
#define LCD_REGISTER ((0x70)|(LCD_ID<<2))
#define LCD_RST_DISABLE() (P1L |= 0x02)
#define LCD_RST_ENABLE() (P1L &= 0xFD)
#define LCD_CS_DISABLE() (P1L |= 0x01)
#define LCD_CS_ENABLE() (P1L &= 0xFE)
//void delay(unsigned long i);
void lcd_clear(unsigned int color);
void draw_rectangle(unsigned int color, unsigned int x0, unsigned int
y0, unsigned int x1, unsigned int y1);
void draw_rectangle_notfilled(unsigned int color, unsigned int width,
unsigned int x0, unsigned int y0, unsigned int x1, unsigned int y1);
void lcd_draw(unsigned int color);
void lcd_drawstop(void);
void lcd_drawstart(void);
unsigned int y1);
void lcd_cursor(unsigned int x, unsigned int y);
void lcd_cmd(unsigned int reg, unsigned int param);
void lcd_data(unsigned int c);
void lcd_reset(void);
#endif /* _DISPLAY_H_ */
Ich hoffe ihr könnt mir sagen, was ich falsch mache..
Danke im Voraus
