STM32: Probleme mit I²C
OP #2207938
Hallo Leute, ich bins wieder.
Hab diesmal ein Problem mit I²C. Ich versuche einen Bl-Ctrl 2.0 Regler
anzusprechen, es funktioniert jedoch nicht. Die Konfiguration der I²C
Schnittstelle sollte passen, der Programmcode ebenso. Pull - Ups sind
auch vorhanden. Hier mal die Konfiguration der I²C Schnittstelle:
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStructure.I2C_OwnAddress1 = 0x52;
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_InitStructure.I2C_ClockSpeed = 400000;
I2C_Init(I2C1, &I2C_InitStructure);
/* I2C1 SDA and SCL configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
I2C_Cmd(I2C1, ENABLE);
Und das ist der Programmcode (gleich mal sorry für die Länge, weis nicht
was davon relevant ist):
Timeout = 0xFFFF;
        myprint2("\r\nEnter...");
        I2C_GenerateSTART(I2C1, ENABLE);
        myprint2("\r\nStart");
        while ((!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT)) && (!stop))
          if(Timeout == 0)
            lEvent = I2C_GetLastEvent(I2C1);
            myprint2("\r\n   Error Occured: Code %u", lEvent);
            if(IS_I2C_EVENT(lEvent)){
              myprint2("\r\n       Is I2C Event");
            stop = 1;
          Timeout--;
        stop = 0;
        Timeout = 0xFFFF;
        myprint2("\r\nEvent 1");
23
        Delay_ms(20);
24
        I2C_Send7bitAddress(I2C1, 0x52, I2C_Direction_Transmitter);
25
26
        myprint2("\r\n7b Address");
27
28
            I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)) && (!stop))
29
30
          if(Timeout == 0)
31
32
33
34
35
36
37
38
            stop = 1;
39
40
          Timeout--;
41
42
        stop = 0;
43
        Timeout = 0xFFFF;
44
        myprint2("\r\nEvent 2");
45
        I2C_SendData(I2C1, 100);
46
        myprint2("\r\nSend Data");
47
        while ((!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED)) && (!stop))
48
49
          if(Timeout == 0)
50
51
52
53
54
55
56
57
            stop = 1;
58
59
          Timeout--;
60
61
        stop = 0;
62
        Timeout = 0xFFFF;
63
        myprint2("\r\nEvent 3");
64
        I2C_GenerateSTOP(I2C1, ENABLE);
65
        myprint2("\r\nStop");
und die Ausgabe davon in Putty:
Enter...
Start
Event 1
7b Address
   Error Occured: Code 536870944
Event 2
Send Data
Event 3
Stop
Ich sitze jetzt hier schon ein paar Stunden und versuche Das Problem zu
lösen. Ich hoffe ihr könnt mir helfen.
Danke schon im vorraus!
mfg,
TDK29
