PIC18F14k50 USB & Sleep will nicht -> Expertenrat gesucht
Gast #2302248
Hallo Leute,
Will bei einem PIc18F14k50 den USB Interruptbetrieb und den Sleep mode
gmeinsam nutzen.
Leider funktioniert das nicht so richtig. Hier mein Quellcode:
sub procedure Interrupt()
   USB_Interrupt_Proc()
   if (HID_Read() > 0) then
      Led = 1
      if CheckSystemCommand = 0 then
         Read_Sht
         Convert_Data_to_text
      end if
      while(HID_Write(@USB_writebuf,42) = 0)
         NOP
      wend
      Led = 0
   end if
end sub
main:
  InitConfig 'Set input,Outputs,...
  ReadEEpromDatas 'Offsets,serial,...
  HID_Enable(@USB_readbuf,@USB_writebuf)
  delay_ms(1500)
  Led = 0
  while TRUE
    sleep
    nop  'Some Operations to starting up the OSC
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
  wend
Weis jemand, wie ich das Problem umgehen kann?
Gast #2302339
Bedingung wird schon gesetzt.
Sub Procedure InitConfig
    Intcon.GIE = 0 'All Interrupts off
    ADCON0 = 0
    ADCON1 = 0
    ANSEL = 0
    ANSELH = 0
    CCP1CON = 0
    RCON.IPEN = 0 'Disable Interrupt priority
    INTCON.PEIE = 1  'PIR is on
    INTCON2.rabpu = 1 'Pullups disabled
    PIE2.USBIE = 1    'Enable USB Interrupt
    'Pins, that will be always high:
    PortC.5 = 1 'Dummy Pin
    TrisC.5 = 0 'Dummy Pin
    PortC.7 = 1 'Led
    TrisC.7 = 0 'Led
    PortB.7 = 1 'Vdd from SHT
    TrisB.7 = 0 'Vdd from SHT
    'Pins, taht will be always low:
    PortC.4 = 0 'Dummy Pin
    TrisC.4 = 0 'Dummy Pin
    PortC.3 = 0 'Dummy Pin
    TrisC.3 = 0 'Dummy Pin
    PortC.6 = 0 'Dummy Pin
    TrisC.6 = 0 'Dummy Pin
    PortC.0 = 0 'Dummy Pin
    TrisC.0 = 0 'Dummy Pin
    PortC.1 = 0 'Dummy Pin
    TrisC.1 = 0 'Dummy Pin
    PortC.2 = 0 'Dummy Pin
    TrisC.2 = 0 'Dummy Pin
    PortB.4 = 0 'Dummy Pin
    TrisB.4 = 0 'Dummy Pin
    'Pins that would be an Input
    TrisB.5 = 1
    TrisB.6 = 1
    Intcon.GIE = 1 'Enables Global Interrupt
end sub
Wegen dem funktioniert es noch immer nicht :-(
Gast #2302391
Funktioniert :-D
while TRUE
    Pir2.USBIE = 1 'Set the Interrupt on
    UIE.SOFIE = 1  'Set the Interrupt on
    OSCCON.IDLEN = 1 'Switch to internal Oscillator
    sleep
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
  wend
