Programmer mit avrdude mag nicht (mehr) Tipps?
OP #2533607
Ich brannte bisher meine AVRs unter Kubuntu und mit avrdude und einem
Diamex Programmer ohne Probleme, jetzt plötzlich geht nichts mehr.
Hat jemand einen Tipp wo ich nach dem Fehler suchen kann?
Die ersten Kommandos scheinen zu gehen, was fuer ein Kommando ist das
was failed ergibt?
Die Ausgabe von avrdude ist:
avrdude -p t45 -P /dev/ttyACM0 -c stk500v2 -B 4 -n -vvvv
avrdude: Version 5.10, compiled on Mar 23 2010 at 15:03:00
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/etc/avrdude.conf"
         User configuration file is "/home/walt/.avrduderc"
         User configuration file does not exist or is not a regular
file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : stk500v2
         Setting bit clk period        : 4.0
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv: . [1b]
avrdude: Recv: . [01]
avrdude: Recv: . [00]
avrdude: Recv: . [0b]
avrdude: Recv: . [0e]
avrdude: Recv: . [08]
avrdude: Recv: A [41]
avrdude: Recv: V [56]
avrdude: Recv: R [52]
avrdude: Recv: I [49]
avrdude: Recv: S [53]
avrdude: Recv: P [50]
avrdude: Recv: _ [5f]
avrdude: Recv: 2 [32]
avrdude: Recv: t [74]
avrdude: stk500v2_getsync(): found AVRISP programmer
avrdude: Send: . [1b] . [02] . [00] . [02] . [0e] . [03] . [98] . [8e]
avrdude: Recv: . [02]
avrdude: Recv: . [03]
avrdude: Recv: . [14]
avrdude: Send: . [1b] . [03] . [00] . [03] . [0e] . [02] . [98] . [04] .
[8b]
avrdude: Recv: . [16]
         AVR Part                      : ATtiny45
         Chip Erase delay              : 4500 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page
Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages
MinW  MaxW   ReadBack
           eeprom        65     6     4    0 no        256    4      0
4000  4500 0xff 0xff
                                  Block Poll               Page
Polled
MinW  MaxW   ReadBack
           flash         65     6    32    0 yes      4096   64     64
4500  4500 0xff 0xff
                                  Block Poll               Page
Polled
MinW  MaxW   ReadBack
           signature      0     0     0    0 no          3    0      0
0     0 0x00 0x00
                                  Block Poll               Page
Polled
MinW  MaxW   ReadBack
           lock           0     0     0    0 no          1    0      0
9000  9000 0x00 0x00
                                  Block Poll               Page
Polled
MinW  MaxW   ReadBack
           lfuse          0     0     0    0 no          1    0      0
9000  9000 0x00 0x00
                                  Block Poll               Page
Polled
MinW  MaxW   ReadBack
           hfuse          0     0     0    0 no          1    0      0
9000  9000 0x00 0x00
                                  Block Poll               Page
Polled
MinW  MaxW   ReadBack
           efuse          0     0     0    0 no          1    0      0
9000  9000 0x00 0x00
                                  Block Poll               Page
Polled
MinW  MaxW   ReadBack
           calibration    0     0     0    0 no          2    0      0
0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: AVRISP
avrdude: Send: . [1b] . [04] . [00] . [02] . [0e] . [03] . [90] . [80]
avrdude: Recv: . [04]
avrdude: Recv: . [0f]
avrdude: Recv: . [1e]
avrdude: Send: . [1b] . [05] . [00] . [02] . [0e] . [03] . [91] . [80]
avrdude: Recv: . [05]
avrdude: Recv: . [12]
avrdude: Send: . [1b] . [06] . [00] . [02] . [0e] . [03] . [92] . [80]
avrdude: Recv: . [06]
avrdude: Recv: . [0a]
avrdude: Recv: . [19]
         Hardware Version: 15
         Firmware Version Master : 2.10
avrdude: Send: . [1b] . [07] . [00] . [02] . [0e] . [03] . [94] . [87]
avrdude: Recv: . [07]
         Vtarget         : 0.0 V
         SCK period      : 0.1 us
avrdude: Send: . [1b] . [08] . [00] . [0c] . [0e] . [10] . [c8] d [64] .
[19]   [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00] ; [3b]
avrdude: Recv: . [10]
avrdude: Recv: . [c0]
avrdude: Recv: . [cf]
avrdude: stk500v2_command(): command failed
avrdude: Send: . [1b] . [09] . [00] . [01] . [0e] . [0d] . [10]
avrdude: ser_recv(): programmer is not responding
avrdude: stk500_2_ReceiveMessage(): timeout
avrdude: Send: . [1b] . [09] . [00] . [01] . [0e] . [01] . [1c]
avrdude: Recv: . [09]
avrdude: Recv: | [7c]
avrdude: stk500v2_program_enable(): bad STK600 connection status:
Unknown (0x64)
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: Send: . [1b] . [0a] . [00] . [03] . [0e] . [11] . [01] . [01] .
[0d]
avrdude: Recv: . [11]
avrdude: Recv: . [0c]
avrdude done.  Thank you.
