1-Wire - Wie schreibe ich 0xE3?
OP #2579935
Hallo Zusammen,
Ich habe ein Problem mit dem Baustein DS2480
(http://pdf1.alldatasheet.com/datasheet-pdf/view/58621/DALLAS/DS2480.html).
Und zwar möchte ich die Hexzahl 0xE3 (227) in den Speicher meines 1-Wire
EEPROMs schreiben. Dies ist allerdings der Ausdruck, dass das schreiben
beendet ist.
Gibt es da irgendeine Möglichkeit diese Zahl trotzdem zu schreiben? Muss
doch irgendwie möglich sein...
Gruss Dexter
#2579953
Der wichtige Abschnitt des Datenblatts ist dieser hier:
"While being in the Data Mode the DS2480 checks each
byte received from the host for the reserved code that is
used to switch back to Command Mode. To be able to
write any possible code (including the reserved one) to
the 1–Wire bus, the transition to the Command Mode is
as follows: After having received the code for switching
to Command Mode, the device temporarily enters the
Check Mode where it waits for the next byte. If both
bytes are the same, the byte is sent once to the 1–Wire
bus and the device returns to the Data Mode. If the
second byte is different from the reserved code, it will be
executed as command and the device finally enters the
Command Mode. As a consequence, if the reserved
code that normally switches to Command Mode is to be
written to the 1–Wire bus, this code byte must be sent
twice (duplicated). This detail must be considered carefully
when developing software drivers for the DS2480."
D.h. um 0xE3 in den Speicher zu Schreiben musst du das Byte zweimal
senden. Dadurch erkennt der DS2480 dass es sich nicht um einen Befehl
sondern um Daten handelt.
Viele Grüsse,
Michael
#2579954
Steht doch im Datenblatt:
"To be able to write any possible code (including the reserved one) to
the 1-Wire bus, the transition to the Command Mode is as follows: After
having received the code for switching to Command Mode, the device
temporarily enters the Check Mode where it waits for the next byte. If
both bytes are the same, the byte is sent once to the 1-Wire bus and the
device returns to the Data Mode. If the second byte is different from
the reserved code, it will be executed as command and the device finally
enters the Command Mode. As a consequence, if the reserved code that
normally switches to Command Mode is to be written to the 1-Wire bus,
this code byte must be sent twice (duplicated)."
Peter
