PIC32_DMA_CodeExample/uart_echo.c von Microchip PIC32
Gast #2679711
Hallo Zusammen
Kennt jemand das Beispiel PIC32_DMA_CodeExample/uart_echo.c von
Microchip es funktioniert nicht. Es gibt ein Problem bei folgender Zeile
im Programm
DmaChnEnable(chn);
über dies Funktion kommt das Programm nicht drüber.
Ich habe mir die Variable chn angesen, in der steht immer
DMA_CHANNEL0
obwohl der Kanal 1 ausgewählt wird
DmaChannel  chn=DMA_CHANNEL1;  // DMA channel to use for our example
Kann mir jemand helfen. Bitte. Danke.
 *                  DMA Uart echo example file
 * FileName:        uart_echo.c
 * Dependencies:  plib.h
 * Processor:       PIC32MX
 * Complier:        MPLAB C32 v1 or higher
 *                  MPLAB IDE v8 or higher
 * Company:         Microchip Technology Inc.
 * Software License Agreement
 * The software supplied herewith by Microchip Technology Incorporated
 * (the “Company”) for its PIC Microcontroller is intended
 * and supplied to you, the Company’s customer, for use solely and
 * exclusively on Microchip PIC Microcontroller products.
 * The software is owned by the Company and/or its supplier, and is
 * protected under applicable copyright laws. All rights are reserved.
 * Any use in violation of the foregoing restrictions may subject the
 * user to criminal sanctions under applicable laws, as well as to
 * civil liability for the breach of the terms and conditions of this
 * license.
 * THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
 * WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
 * TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
 * PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
 * IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
 * CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
 * Author               Date        Comment
 * $Id: dma_api_example.c 4261 2007-08-22 16:32:28Z aura $
#include <stdlib.h>
#include <time.h>
#include <plib.h>
// prototypes
void  DmaDoUartEchoExample(int pbClk);
// some local data
int    DmaIntFlag;      // flag used in interrupts
// Configuration Bit settings
#pragma config FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FPLLODIV = DIV_1,
FWDTEN = OFF
#pragma config POSCMOD = HS, FNOSC = PRIPLL, FPBDIV = DIV_2
#if defined (_32MX460F512L_) || defined (_32MX360F512L_) || defined
(_32MX795F512L_)
#define SYS_FREQ (80000000L)
#elif defined (_32MX220F032D_) || defined (_32MX250F128D_)
#define SYS_FREQ (40000000L)
#endif
#define  BAUDRATE  57600  // serial baudrate
 * Function:        int main(void)
 * PreCondition:    None
 * Input:      None
 * Output:          None
 * Side Effects:    None
 * Overview:    Examples for the usage of the DMA Peripheral Lib
 * Note:            None.
int  main(void)
  int  pbClk;    // the PB frequency
  // Configure the device for maximum performance but do not change the
PBDIV
  // Given the options, this function will change the flash wait states,
RAM
  // wait state and enable prefetch cache but will not change the PBDIV.
  // The PBDIV value is already set via the pragma FPBDIV option above..
  pbClk=SYSTEMConfig(SYS_FREQ, SYS_CFG_WAIT_STATES | SYS_CFG_PCACHE);
  // receive some data from the UART port and echo it back
  DmaDoUartEchoExample(pbClk);
  return 1;
 * Function:        void DmaDoUartEchoExample(int pbClk)
 * Input:      pbClk  - the PB frequency
 * Output:          None
 * Overview:    Examples for receiving some data from the UART and
echoing it back using the DMA Peripheral Lib.
 *           The received data is expected to end with a CR and has to
be less than DmaGetMaxTxferSize() bytes in length.
 *           We'll enable the DMA interrupts to signal us when the
transfer is done.
 * Note:            None.
  unsigned char ucTest;
  char     dmaBuff[256+1];    // we'll store the received data here
  //DmaChannel  chn=DMA_CHANNEL1;  // DMA channel to use for our example
  int chn = 1;
            // NOTE: the ISR setting has to match the channel number
  OpenUART2(UART_EN, UART_RX_ENABLE|UART_TX_ENABLE,
pbClk/16/BAUDRATE-1);     // selected baud rate, 8-N-1
  putsUART2("\r\nType up to 256 characters long string followed by Enter
key...\r\n\r\n");
  // configure the channel
  DmaChnOpen(chn, DMA_CHN_PRI2, DMA_OPEN_MATCH);
  DmaChnSetMatchPattern(chn, '\r');  // set \r as ending character
  // set the events: we want the UART2 rx interrupt to start our
transfer
  // also we want to enable the pattern match: transfer stops upon
detection of CR
  DmaChnSetEventControl(chn,
DMA_EV_START_IRQ_EN|DMA_EV_MATCH_EN|DMA_EV_START_IRQ(_UART2_RX_IRQ));
  // set the transfer source and dest addresses, source and dest sizes
and the cell size
  DmaChnSetTxfer(chn, (void*)&U2RXREG, dmaBuff, 1, sizeof(dmaBuff), 1);
  DmaChnSetEvEnableFlags(chn, DMA_EV_BLOCK_DONE);    // enable the
transfer done interrupt: pattern match or all the characters transferred
  // enable system wide multi vectored interrupts
  INTConfigureSystem(INT_SYSTEM_CONFIG_MULT_VECTOR);
  INTEnableInterrupts();
  INTSetVectorPriority(INT_VECTOR_DMA(chn), INT_PRIORITY_LEVEL_5);    //
set INT controller priority
  INTSetVectorSubPriority(INT_VECTOR_DMA(chn),
INT_SUB_PRIORITY_LEVEL_3);    // set INT controller sub-priority
  INTEnable(INT_SOURCE_DMA(chn), INT_ENABLED);    // enable the chn
interrupt in the INT controller
  DmaIntFlag=0;        // clear the interrupt flag
  ucTest = chn;
  // enable the chn
  DmaChnEnable(chn);
  // let the user know that he has to enter a string
  // for example, you could do something like:
  // printf("\r\nType a string less than 256 characters followed by
Enter key...Will echo it using the DMA\r\n\r\n");
  // wait for the data to come in
  while(!DmaIntFlag);      // just block here. In a real application you
can do some other stuff while the DMA transfer is taking place
  // ok, we've received the data in the buffer
  putsUART2("\r\nReceived the character string. Now echoing it
back...\r\n\r\n");
  // now the TX part
  // reconfigure the channel
  // set the events: now the start event is the UART tx being empty
  // we maintain the pattern match mode
DMA_EV_START_IRQ_EN|DMA_EV_MATCH_EN|DMA_EV_START_IRQ(_UART2_TX_IRQ));
and cell size
  DmaChnSetTxfer(chn, dmaBuff, (void*)&U2TXREG, sizeof(dmaBuff), 1, 1);
  DmaChnStartTxfer(chn, DMA_WAIT_NOT, 0);  // force the DMA transfer:
the UART2 tx flag it's already been active
  // wait for data to be output
  // DMA Echo is complete
  INTEnable(INT_SOURCE_DMA(chn), INT_DISABLED);    // disable further
interrupts from the DMA controller
  putsUART2("\r\nEcho back completed...\r\n\r\n");
// handler for the DMA channel 1 interrupt
void __ISR(_DMA1_VECTOR, ipl5) DmaHandler1(void)
  int  evFlags;        // event flags when getting the interrupt
  INTClearFlag(INT_SOURCE_DMA(DMA_CHANNEL1));  // release the interrupt
in the INT controller, we're servicing int
  evFlags=DmaChnGetEvFlags(DMA_CHANNEL1);  // get the event flags
    if(evFlags&DMA_EV_BLOCK_DONE)
    { // just a sanity check. we enabled just the DMA_EV_BLOCK_DONE
    DmaIntFlag=1;
    DmaChnClrEvFlags(DMA_CHANNEL1, DMA_EV_BLOCK_DONE);
Welchen Compiler nutzt Ihr denn?
Der neue XC32 ist noch nicht ganz ausgereift. Besser den alten C32
benutzten.
Der XC32 zeigt errors wo der C32 alles ok findet.
hello,
I am using the C32 compiler and have set up the variable :
DmaChannel chn=0; and also evFlags=DmaChnGetEvFlags(DMA_CHANNEL0); like
this .. and now, the debugger is halted every time I run the program.
What do you suggest ? any idea more ?
I decided to leave a message here on your
PIC32_DMA_CodeExample/uart_echo.c von Microchip PIC32 -
Mikrocontroller.net page instead of calling you. Do you need more likes
for your Facebook Fan Page? The more people that LIKE your website and
fanpage on Facebook, the more credibility you will have with new
visitors. It works the same for Twitter, Instagram and Youtube. When
people visit your page and see that you have a lot of followers, they
now want to follow you too. They too want to know what all the hype is
and why all those people are following you. Get some free likes,
followers, and views just for trying this service I found:
http://lathundar.se/Url/a9
This is a memo to the admin. I discovered your
Mikrocontroller.net page by searching on Google but it was hard to find
as you were not on the front page of search results. I know you could
have more traffic to your website. I have found a site which offers to
dramatically improve your rankings and traffic to your website:
http://lis.ovh/h9 I managed to get close to 500 visitors/day using their
services, you can also get a lot more targeted visitors from search
engines than you have now. Their service brought significantly more
visitors to my website. I hope this helps!
I was just looking at your PIC32_DMA_CodeExample/uart_echo.c von
Microchip PIC32 - Mikrocontroller.net website and see that your site has
the potential to get a lot of visitors. I just want to tell you, In case
you don't already know... There is a website service which already has
more than 16 million users, and the majority of the users are interested
in websites like yours. By getting your website on this network you have
a chance to get your site more popular than you can imagine. It is free
to sign up and you can find out more about it here:
http://www.inflightvideo.tv/a/9q - Now, let me ask you... Do you need
your site to be successful to maintain your business? Do you need
targeted visitors who are interested in the services and products you
offer? Are looking for exposure, to increase sales, and to quickly
develop awareness for your website? If your answer is YES, you can
achieve these things only if you get your site on the service I am
talking about. This traffic service advertises you to thousands, while
also giving you a chance to test the service before paying anything. All
the popular sites are using this service to boost their traffic and ad
revenue! Why aren’t you? And what is better than traffic? It’s recurring
traffic! That's how running a successful website works... Here's to your
success! Find out more here: http://v-doc.co/nm/bat6h
