GNU-Plot: Zwei Plots mit unterschiedicher Farbe ins selbe Fenster
Gast #2701886
ich möchte ein polar-Plot mit GNUPlot machen.
Leider bekomme ich es nicht hin, die beiden Plots ins selbe Fenster mit
unterschiedlicher Farbe zu setzen. Es klappt immer das eine oder das
andere.
Weiß jemand warum GNUPlot die Labels übereinander setzt?
GNU-Code:
unset border
set polar
set angles degrees #set gnuplot on degrees instead of radians
set style line 10 lt 1 lc 0 lw 0.3 #redefine a new line style for the grid
set grid polar 60 #set the grid to be displayed every 60 degrees
set grid ls 10
set xrange [-60:60] #make gnuplot to go until 6000
set yrange [-60:60]
set xtics axis #disply the xtics on the axis instead of on the border
set ytics axis
set xtics scale 0 #"remove" the tics so that only the y tics are displayed
#set xtics ("" 10, "" 20, "" 30, "" 40, "" 50, "" 60) #set the xtics only go from 0 to 6000 with increment of1000 but do not display anything. This has to be done otherwise the grid will not be displayed correctly.
set ytics 0, 10, 60 #make the ytics go from the center (0) to 6000 with incrment of 1000
set size square
set key lmargin
23
24
set_label(x, text) = sprintf("set label '%s' at (65*cos(%f)), (65*sin(%f))     center", text, x, x) #this places a label on the outside
25
26
#here all labels are created
27
#eval set_label(0, "0")
28
#eval set_label(60, "60")
29
#eval set_label(120, "120")
30
#eval set_label(180, "180")
31
#eval set_label(240, "240")
32
#eval set_label(330, "300")
33
34
set multiplot
35
36
set style line 11 lt 3 lw 2 pt 2 ps 2 #set the line style for the plot
37
38
#and finally the plot
39
plot "-" u 1:2 t "X-Axis" w lp ls 11
40
0 54
41
30 46,8
42
45 34,7
43
60 22,5
44
90 2,8
45
120 28,5
46
135 37,9
47
150 47,4
48
180 57,3
49
210 51,6
50
225 43,3
51
240 30,2
52
270 3
53
300 25,5
54
315 39,7
55
330 55,7
56
360 54
57
e
58
59
60
#set style line 11 lt 1 lw 2 pt 2 ps 2 #set the line style for the plot
61
62
plot "-" u 1:2 t "Y-Axis" w lp ls 11
63
0 2,75
64
30 30,3
65
45 41,2
66
60 52,5
67
90 55,8
68
120 55,7
69
135 43,1
70
150 30,4
71
180 2,74
72
210 24,8
73
225 35,9
74
240 49,3
75
270 59,7
76
300 50,7
77
315 38,9
78
330 26,3
79
360 2,75
80
e
