Frage zu SQL Datenbank
OP #2868904
ich hab hier ne SQL Lite Datenbank-Datei kommt man mit irgendeinem
Programm an die Daten die in der Datei drinn sind, so das man Sie
weiterverwenden kann.
Ich bräuchte aus der Datei paar Werte in ner Excel Datei.
Kann mir einer ein Tip geben, wie man das bewerkstellingen könnte ?
gruß,
Björn
#2868911
z.B.hier: http://www.sqlite.org/sqlite.html
Auszug:
Writing results to a file
By default, sqlite3 sends query results to standard output. You can
change this using the ".output" command. Just put the name of an output
file as an argument to the .output command and all subsequent query
results will be written to that file. Use ".output stdout" to begin
writing to standard output again. For example:
    sqlite> .mode list
    sqlite> .separator |
    sqlite> .output test_file_1.txt
    sqlite> select * from tbl1;
    sqlite> .exit
    $ cat test_file_1.txt
    hello|10
    goodbye|20
Oder:
Converting An Entire Database To An ASCII Text File
Use the ".dump" command to convert the entire contents of a database
into a single ASCII text file. This file can be converted back into a
database by piping it back into sqlite3.
A good way to make an archival copy of a database is this:
    $ echo '.dump' | sqlite3 ex1 | gzip -c >ex1.dump.gz
This generates a file named ex1.dump.gz that contains everything you
need to reconstruct the database at a later time, or on another machine.
To reconstruct the database, just type:
    $ zcat ex1.dump.gz | sqlite3 ex2
The text format is pure SQL so you can also use the .dump command to
export an SQLite database into other popular SQL database engines. Like
this:
    $ createdb ex2
    $ sqlite3 ex1 .dump | psql ex2
Hilft Dir das?
