warum brauchen wir microblaze zu erfüllen?
Gast #2969400
ich habe eine Frage,
kann jemand erklaren, warum brauchen wir microblaze zu erfüllen, können
wir  die Arbeit mit fpga nicht machen, ohne microblaze zu erfüllen?
in case my german is not good enough,
could someone tell me, why we need to design microblaze? are there
things that we cant do it with fpga, without designing a microblaze?
danke schön
Gast #2969403
There are some benefits using a microprocessor implemented on a FPGA.
The one most named is the flexibility during run-time while having
constant resource requirements. Changing the program is easily done
while a new FPGA structure may need more resources.
This argument isn't undisputed. One may say that a new configuration (as
far as it fits into the FPGA) is mostly more efficient than doing the
same thing with the CPU.
In reality its a matter of weighing pros and cons.
If you read the microblaze or picoblaze documents, namely the sheets
targeted to management, you may get even more elaborated points.
Gast #2969458
And some drawbacks and obstacles too.
The article here in this forum has some information about this, when to
use an OS and a softcore in general.
My favorite "con" regarding Xilinx:  This company has such a weired
documentation and faulty examples, that it is best to do as much as
possible on your own, instead of beeing dependent of the EDK and all
this.
There is much more work to do and to learn in order to get a processor
run in an FPGA, if you need more than just some easy controls. As soon
as it becomes difficult and complex, using a microprocessor is even
worse!
When once you are familiar with it, and you passed all the obstacles,
then using it might be effective.
It is up to you!
When to use a softcore:
http://www.mikrocontroller.net/articles/FPGA#Implementierung_von_Steuerfunktionen
  • [vhdl]VHDL-Code[/vhdl]
