Xilinx bitgen Fehler
Gast #3028850
ich habe ein Problem mit ISE 14.1, Spartan 6
Bitgen bricht mit folgender aussagekräftiger Fehlermeldung ab:
Started : "Generate Programming File".
Running bitgen...
Command Line: bitgen -intstyle ise -f FPGA.ut FPGA.ncd
Process "Generate Programming File" failed
Im Bitgen-Report steht noch nicht mal eine Fehlermeldung:
Release 14.1 - Bitgen P.15xf (nt)
Copyright (c) 1995-2012 Xilinx, Inc.  All rights reserved.
Loading device for application Rf_Device from file '6slx75.nph' in environment
C:\Xilinx\14.1\ISE_DS\ISE\.
   "FPGA" is an NCD, version 3.2, device xc6slx75, package fgg484, speed -3
Opened constraints file FPGA.pcf.
Mon Feb 04 07:38:21 2013
C:\Xilinx\14.1\ISE_DS\ISE\bin\nt\unwrapped\bitgen.exe -intstyle ise -w -g DebugBitstream:No -g Binary:no -g CRC:Enable -g Reset_on_err:No -g ConfigRate:2 -g ProgPin:PullUp -g TckPin:PullUp -g TdiPin:PullUp -g TdoPin:PullUp -g TmsPin:PullUp -g UnusedPin:PullDown -g UserID:0xFFFFFFFF -g ExtMasterCclk_en:No -g SPI_buswidth:1 -g TIMER_CFG:0xFFFF -g multipin_wakeup:No -g StartUpClk:CClk -g DONE_cycle:4 -g GTS_cycle:5 -g GWE_cycle:6 -g LCK_cycle:NoWait -g Security:None -g DonePipe:Yes -g DriveDone:No -g Encrypt:No -g en_sw_gsr:No -g drive_awake:No -g sw_clk:Startupclk -g sw_gwe_cycle:5 -g sw_gts_cycle:4 FPGA.ncd
Summary of Bitgen Options:
| Option Name          | Current Setting      |
| Compress             | (Not Specified)*     |
| Readback             | (Not Specified)*     |
| CRC                  | Enable**             |
| DebugBitstream       | No**                 |
23
24
| ConfigRate           | 2**                  |
25
26
| StartupClk           | Cclk**               |
27
28
| DonePin              | Pullup*              |
29
30
| ProgPin              | Pullup**             |
31
32
| TckPin               | Pullup**             |
33
34
| TdiPin               | Pullup**             |
35
36
| TdoPin               | Pullup**             |
37
38
| TmsPin               | Pullup**             |
39
40
| UnusedPin            | Pulldown**           |
41
42
| GWE_cycle            | 6**                  |
43
44
| GTS_cycle            | 5**                  |
45
46
| LCK_cycle            | NoWait**             |
47
48
| DONE_cycle           | 4**                  |
49
50
| Persist              | No*                  |
51
52
| DriveDone            | No**                 |
53
54
| DonePipe             | Yes                  |
55
56
| Security             | None**               |
57
58
| UserID               | 0xFFFFFFFF**         |
59
60
| ActiveReconfig       | No*                  |
61
62
| Partial              | (Not Specified)*     |
63
64
| Encrypt              | No**                 |
65
66
| Key0                 | pick*                |
67
68
| StartCBC             | pick*                |
69
70
| KeyFile              | (Not Specified)*     |
71
72
| drive_awake          | No**                 |
73
74
| Reset_on_err         | No**                 |
75
76
| suspend_filter       | Yes*                 |
77
78
| en_sw_gsr            | No**                 |
79
80
| en_suspend           | No*                  |
81
82
| sw_clk               | Startupclk**         |
83
84
| sw_gwe_cycle         | 5**                  |
85
86
| sw_gts_cycle         | 4**                  |
87
88
| multipin_wakeup      | No**                 |
89
90
| wakeup_mask          | 0x00*                |
91
92
| ExtMasterCclk_en     | No**                 |
93
94
| ExtMasterCclk_divide | 1*                   |
95
96
| MaskVectorFile       | No*                  |
97
98
| CrcCoverage          | No*                  |
99
100
| glutmask             | Yes*                 |
101
102
| next_config_addr     | 0x00000000*          |
103
104
| next_config_new_mode | No*                  |
105
106
| next_config_boot_mode | 001*                 |
107
108
| next_config_register_write | Enable*              |
109
110
| next_config_reboot   | Enable*              |
111
112
| golden_config_addr   | 0x00000000*          |
113
114
| failsafe_user        | 0x0000*              |
115
116
| TIMER_CFG            | 0xFFFF               |
117
118
| spi_buswidth         | 1**                  |
119
120
| IEEE1532             | No*                  |
121
122
| Binary               | No**                 |
123
124
 *  Default setting.
125
 ** The specified setting matches the default setting.
126
127
There were 0 CONFIG constraint(s) processed from FPGA.pcf.
Kennt jemand das Problem?
Gruß Philip
