Problem with burstcount > 2 for Avalon MM Master to SDRAM
Gast #3082032
Hello,
I am trying to implement a burst transcation with SDRAM using Avalon MM
Interface.
The following Verilog code works fine for burstcount = 2:
module hw_det_3by3(
    clk,
    reset,
    avs_csr_addr,
    avs_csr_write,
    avs_csr_writedata,
    avs_csr_read,
    avs_csr_readdata,
    avm_sdram_addr,
    avm_sdram_burstcount,
    avm_sdram_read,
    avm_sdram_waitrequest,
    avm_sdram_readdatavalid,
    avm_sdram_readdata
input wire clk;
input wire reset;
input wire [2:0] avs_csr_addr;
input wire avs_csr_write;
23
input wire [31:0] avs_csr_writedata;
24
input wire avs_csr_read;
25
output wire [31:0] avs_csr_readdata;
26
27
output wire [31:0] avm_sdram_addr;
28
output wire [2:0] avm_sdram_burstcount;
29
output wire avm_sdram_read;
30
input wire avm_sdram_waitrequest;
31
input wire avm_sdram_readdatavalid;
32
input wire [31:0] avm_sdram_readdata;
33
34
reg [31:0] read_addr;
35
reg load_minors = 0;
36
reg count = 0;
37
reg status = 0;
38
39
reg [31:0] minor10;
40
reg [31:0] minor11;
41
reg [31:0] minor12;
42
reg [31:0] minor20;
43
reg [31:0] minor21;
44
reg [31:0] minor22;
45
46
reg sdram_read;
47
48
reg [31:0] csr_readdata;
49
50
assign avm_sdram_addr = read_addr;
51
assign avm_sdram_burstcount = 2;
52
assign avm_sdram_read = sdram_read;
53
54
assign avs_csr_readdata = csr_readdata;
55
56
always @ (posedge clk)
57
begin
58
    if (avs_csr_write == 1)
59
    begin
60
        if (avs_csr_addr == 1)
61
        begin
62
            load_minors <= 1;
63
            read_addr <= avs_csr_writedata;
64
        end
65
    end
66
    if (load_minors == 1)
67
    begin
68
        load_minors <= 0;
69
    end
70
end
71
72
73
begin
74
75
    begin
76
        sdram_read <= 1;
77
    end
78
    else
79
    begin
80
        if (avm_sdram_waitrequest == 0)
81
        begin
82
            sdram_read <= 0;
83
        end
84
    end
85
end
86
87
always @ (posedge clk or posedge reset)
88
begin
89
    if (reset == 1)
90
    begin
91
        count <= 0;
92
        status <= 0;
93
    end
94
    else if(avm_sdram_readdatavalid)
95
    begin
96
        case (count)
97
        0: begin
98
                minor10 <= avm_sdram_readdata;
99
            end
100
        1: begin
101
                minor11 <= avm_sdram_readdata;
102
                status <= 1;
103
            end
104
        endcase
105
        count <= count + 1;
106
    end
107
end
108
109
110
begin
111
    if(avs_csr_read == 1)
112
    begin
113
        case (avs_csr_addr)
114
        0: csr_readdata <= status;
115
        1: csr_readdata <= read_addr;
116
        2: csr_readdata <= minor10;
117
        3: csr_readdata <= minor11;
118
        endcase
119
    end
120
end
121
122
endmodule
Software Interface in NIOS:
#include <stdio.h>
#include "system.h"
#include <io.h>
#include <stdlib.h> /* rand(), RAND_MAX */
int main()
    float n = 1.25;
    float m = 2.5;
    printf("%x, %x\n", &n, &m);
    IOWR(HW_DET_3BY3_0_BASE, 1, &n);
    while (IORD(HW_DET_3BY3_0_BASE, 0) == 0){
        printf("%x\n", IORD(HW_DET_3BY3_0_BASE, 0));
    printf("%x\n", IORD(HW_DET_3BY3_0_BASE, 1));
    printf("%x\n", IORD(HW_DET_3BY3_0_BASE, 2));
    printf("%x\n", IORD(HW_DET_3BY3_0_BASE, 3));
  return 0;
24
However, when I make slight variations to implement the same
functionality for a burst of 3 words, then I get problems - 'status'
never changes to 1.
Does anyone have an idea why that is? I have been trying to solve this
for the past few hours now...
Also, is there are a possibility I can monitor my signals
(avm_sdram_writerequest, avm_sdram_readdatavalid etc.) during runtime?
Many thanks in advance.
Jimmy
Gast #3083997
Hello Jimmy
When I'm right then you using the Altera Quartus II Software. In this
case you can use the SignalTap to monitor the Interface inside the fpga
see here: http://www.altera.com/literature/hb/qts/qts_qii53009.pdf
>never changes to 1.
Some times ago, I had a similar task. Write values from the MM-Interface
in SRAM via Avalon. But Why would you change this signal? In my project
i Used an DMA-Core and I set the burstlength in this core.
Best Reagards
Andreas
  • [vhdl]VHDL-Code[/vhdl]
