ISP Programmer
Gast #3362955
Hallo!
Ich bin Anfänger und habe ein Problem, vielleicht könnt Ihr mir helfen.
Hier mein System: WinXP, avrdude Vers. 5.11, Diamex DX-ISP an COM4;
Burn-o-Mat Vers. 2.1.1
Ich würde gerne einen ATMega8 mit einer .hex Datei bestücken, leider
gibt der Burn-o-mat immer Fehler aus:
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude.exe: Device signature = 0x1e9307
avrdude.exe: NOTE: FLASH memory has been specified, an erase cycle will be performed
             To disable this feature, specify the -D option.
avrdude.exe: current erase-rewrite cycle count is 1114113 (if being tracked)
avrdude.exe: erasing chip
avrdude.exe: reading input file "C:\wordclock_mega8.hex"
avrdude.exe: input file C:\wordclock_mega8.hex auto detected as Intel Hex
avrdude.exe: writing flash (8188 bytes):
Writing | avrdude.exe: stk500v2_command(): warning: Command timed out
#avrdude.exe: stk500v2_command(): warning: Command timed out
23
##avrdude.exe: stk500v2_command(): warning: Command timed out
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
####avrdude.exe: stk500v2_command(): warning: Command timed out
64
65
######avrdude.exe: stk500v2_command(): warning: Command timed out
66
67
#### | 100% 6.84s
68
69
avrdude.exe: 8188 bytes of flash written
70
avrdude.exe: verifying flash memory against C:\wordclock_mega8.hex:
71
avrdude.exe: load data flash data from input file C:\wordclock_mega8.hex:
72
73
avrdude.exe: input file C:\wordclock_mega8.hex contains 8188 bytes
74
avrdude.exe: reading on-chip flash data:
75
76
Reading | ################################################## | 100% 1.47s
77
78
avrdude.exe: verifying ...
79
avrdude.exe: verification error, first mismatch at byte 0x0000
80
             0x77 != 0x72
81
avrdude.exe: verification error; content mismatch
82
83
avrdude.exe done.  Thank you.
Beim  der Ausführung in der Eingabeaufforderung kommt das:
C:\>avrdude -p m8 -c stk500 -v -P COM4 -v
avrdude: Version 5.11, compiled on Aug 30 2011 at 10:24:06
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : stk500
         AVR Part                      : ATMEGA8
         Chip Erase delay              : 10000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
23
         ByteDelay                     : 0
24
         PollIndex                     : 3
25
         PollValue                     : 0x53
26
         Memory Detail                 :
27
28
                                  Block Poll               Page                       Polled
29
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
30
31
           eeprom         4    20   128    0 no        512    4      0  9000  9000 0xff 0xff
32
           flash         33    10    64    0 yes      8192   64    128  4500  4500 0xff 0x00
33
           lfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
34
           hfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
35
           lock           0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
36
           calibration    0     0     0    0 no          4    0      0     0     0 0x00 0x00
37
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
38
39
         Programmer Type : STK500V2
40
         Description     : Atmel STK500
41
         Programmer Model: STK500
42
         Hardware Version: 10
43
         Firmware Version Master : 2.10
44
avrdude: stk500v2_command(): command failed
45
avrdude: stk500v2_getparm(): failed to get parameter 0x9a
46
         Topcard         : Unknown
47
         Vtarget         : 5.0 V
48
         SCK period      : 2.2 us
49
         Varef           : 5.0 V
50
         Oscillator      : Off
51
52
avrdude: AVR device initialized and ready to accept instructions
53
54
Reading | ################################################## | 100% 0.00s
55
56
avrdude: Device signature = 0x1e9307
57
avrdude: safemode: Verify error - unable to read lfuse properly. Programmer may not be reliable.
58
avrdude: safemode: To protect your AVR the programming will be aborted
59
60
avrdude done.  Thank you.
61
62
63
C:\>
Was mache ich hier falsch?
