USART+DMA STM32F3
OP #3694784
Hallo!
ich versuche USART über DMA auf STM32F303 Discovery Board hinzukriegen.
ich habe ein Beispiel genohmen.
Beitrag "STM32F4 USART und DMA"
Beim Kompilieren habe ich keine Fehlermeldung. Leider sendet der µCont.
keine Daten. Ich weiss nicht genau, wo ich Fehler gemacht habe.
hier ist die code.
/*  Systemtakt = 72000000  AHB Prescaler */
// init.c
#include "init.h"
void RCC_Enable(void);
void init_all(void);
void USART2_Config(void);
void DMA2_Config(void);
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_Initialisation;
DMA_InitTypeDef   DMA_InitStructure;
extern unsigned char  buffer[129];
void RCC_Enable(void){
    /* Enable GPIO clock */
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
    /* Enable USART clock */
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
23
    /* Enable DMA2 clock -------------------------------------------------------*/
24
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
25
26
27
28
void init_all(void) {
29
30
    RCC_Enable();
31
    /* USART2 initialisieren PA2=TX PA3=RX*/
32
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_7);
33
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_7);
34
35
    /* Configure USART Tx as alternate function push-pull */
36
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;
37
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
38
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
39
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
40
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
41
    GPIO_Init(GPIOA, &GPIO_InitStructure);
42
43
    USART2_Config();
44
    DMA2_Config();
45
    USART_DMACmd(USART2, USART_DMAReq_Tx, ENABLE);
46
        /* Enable DMA2 Channel3 */
47
    DMA_Cmd(DMA2_Channel3, ENABLE);
48
49
50
void USART2_Config(void){
51
    USART_Initialisation.USART_BaudRate = 9600;
52
    USART_Initialisation.USART_WordLength = USART_WordLength_8b;
53
    USART_Initialisation.USART_StopBits = USART_StopBits_1;
54
    USART_Initialisation.USART_Parity = USART_Parity_No;
55
    USART_Initialisation.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
56
    USART_Initialisation.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
57
    /* USART configuration */
58
    USART_Init(USART2, &USART_Initialisation);
59
    /* Enable USART */
60
    USART_Cmd(USART2, ENABLE);
61
62
void DMA2_Config(void){
63
    DMA_DeInit(DMA2_Channel3);
64
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&(USART2->TDR);
65
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&buffer;
66
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
67
    DMA_InitStructure.DMA_BufferSize = 129;
68
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
69
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
70
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
71
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
72
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
73
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
74
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
75
    DMA_Init(DMA2_Channel3, &DMA_InitStructure);
76
Im init.c wird die ganze erstmal konfiguriert, im main.c wird init_all()
aufgerufen.
#ifndef INIT_H
#define INIT_H
#endif /* INIT_H*/
main.c
#include "stm32f30x.h"
#include "stm32f3_discovery.h"
#include "init.h"
/* Private variables ---------------------------------------------------------*/
  RCC_ClocksTypeDef RCC_Clocks;
__IO uint32_t TimingDelay = 0;
/* Private function prototypes -----------------------------------------------*/
void TimingDelay_Decrement(void);
void Delay(__IO uint32_t nTime);
unsigned char buffer[129] = {"Hello World! \n"};
/* Private functions ---------------------------------------------------------*/
  * @brief  This function handles SysTick Handler.
  * @param  None
  * @retval None
void SysTick_Handler(void)
  TimingDelay_Decrement();
23
24
25
26
  * @brief  Main program.
27
  * @param  None
28
  * @retval None
29
30
int main(void)
31
32
  /* SysTick end of count event each 10ms */
33
  RCC_GetClocksFreq(&RCC_Clocks);
34
  SysTick_Config(RCC_Clocks.HCLK_Frequency / 100);
35
36
  /* Initialize LEDs and User Button available on STM32F3-Discovery board */
37
  STM_EVAL_LEDInit(LED3);
38
  STM_EVAL_LEDInit(LED4);
39
  STM_EVAL_LEDInit(LED5);
40
  STM_EVAL_LEDInit(LED6);
41
  STM_EVAL_LEDInit(LED7);
42
  STM_EVAL_LEDInit(LED8);
43
  STM_EVAL_LEDInit(LED9);
44
  STM_EVAL_LEDInit(LED10);
45
46
  init_all();
47
  /* Infinite loop */
48
  while (1)
49
50
    /* LEDs Off */
51
    STM_EVAL_LEDOff(LED3);
52
    STM_EVAL_LEDOff(LED6);
53
    STM_EVAL_LEDOff(LED7);
54
    STM_EVAL_LEDOff(LED4);
55
    STM_EVAL_LEDOff(LED10);
56
    STM_EVAL_LEDOff(LED8);
57
    STM_EVAL_LEDOff(LED9);
58
    STM_EVAL_LEDOff(LED5);
59
60
    GPIO_ResetBits(GPIOE, GPIO_Pin_14);
61
    GPIO_ResetBits(GPIOE, GPIO_Pin_15);
62
63
    Delay(100); /*500ms - half second*/
64
65
    /* LEDs Off */
66
    STM_EVAL_LEDOn(LED3);
67
    STM_EVAL_LEDOn(LED6);
68
    STM_EVAL_LEDOn(LED7);
69
    STM_EVAL_LEDOn(LED4);
70
    STM_EVAL_LEDOn(LED10);
71
    STM_EVAL_LEDOn(LED8);
72
    STM_EVAL_LEDOn(LED9);
73
    STM_EVAL_LEDOn(LED5);
74
75
    //GPIO_SetBits(GPIOE, GPIO_Pin_14);
76
    //GPIO_SetBits(GPIOE, GPIO_Pin_15);
77
78
79
80
81
82
  * @brief  Inserts a delay time.
83
  * @param  nTime: specifies the delay time length, in 10 ms.
84
  * @retval None
85
86
87
88
  TimingDelay = nTime;
89
90
  while(TimingDelay != 0);
91
92
93
94
  * @brief  Decrements the TimingDelay variable.
95
  * @param  None
96
  * @retval None
97
98
99
100
  if (TimingDelay != 0x00)
101
102
    TimingDelay--;
103
104
105
106
#ifdef  USE_FULL_ASSERT
107
108
109
  * @brief  Reports the name of the source file and the source line number
110
  *         where the assert_param error has occurred.
111
  * @param  file: pointer to the source file name
112
  * @param  line: assert_param error line source number
113
  * @retval None
114
115
void assert_failed(uint8_t* file, uint32_t line)
116
117
  /* User can add his own implementation to report the file name and line number,
118
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
119
120
  /* Infinite loop */
121
  while (1)
122
123
124
125
#endif
ich feue mich sehr über Antworten.
PS. ich schreibe deutsch als Fremdsprache. Bitte entschuldigen Sie über
schlecht formulierte Sätze
Also bei mir heißt das Datenregister DR und nicht TDR.
Anstatt:
verwende mal:
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&(USART2->DR);
Sonst ist es eig. genauso, wie ich es auch habe.
Müsste hier nicht anstatt
sowas stehen
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
Steht im anderen Beitrag auch so. Du versendest mit dem USART ja nur ein
Byte jedesmal und kein WORD (4 Bytes).
Sehr gut.
Für Rx musst du den passenden Channel auswählen und dann folgende Zeilen
ändern:
zu
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
USART_DMACmd(USART2, USART_DMAReq_Rx, ENABLE);
Das müsste es dann gewesen sein.
