MSP430 I2C funktioniert nicht
OP #3714820
Ich versuche  die I2C Kommunikation mit MSP430F2013  programmieren
hier ist mein assembler  Code:
#include "msp430.h"  ;
       ADDR:   EQU 0x40     ; address ADDR1 and ADDR0 to GND
       P_Vol:  EQU 0x00; Pointer to Vobj
       P_Temp: EQU 0x01;  Pointer to ambient Temp
       P_Conf: EQU 0x02 ; Pointer to configuration
        RSEG    CSTACK                  ; pre-declaration of segment
        RSEG    CODE                    ; place program in 'CODE' segment
 Reset:
        mov.w #SFE(CSTACK), SP        ; set up stack
        mov.w #WDTPW|WDTHOLD,&WDTCTL  ; Stop watchdog timer
        bis.b #0, &DCOCTL;
        bic.b #RSEL0|RSEL1|RSEL2,&BCSCTL1;
        mov.b #SELM_3|SELS,&BCSCTL2; VCO as SMCLK,DCO as MCLK
        mov.b #LFXT1S_2,&BCSCTL3; USE VCO as LFXT (ACLK)
        mov.b #0, &P1OUT;
        mov.b #0, &P2OUT; low
        mov.b #0xFF, &P2DIR;
        mov.b #0xFF, &P1DIR; output
        mov.w #MC_0|TACLR, &TACTL; stop and clear timer
23
        bis.w #TASSEL0|TAIE, &TACTL;  CLOCK ACLK
24
        ;----------------------IIC configuation---------------------;
25
26
        bis.b #USISSEL_1|USICKPL,&USICKCTL; ACLK,  IdleState=Low
27
        bis.b #USII2C, USICTL1; I2C mode
28
        mov.b #USIPE7|USIPE6|USIMST, &USICTL0; Enable SDO/SDI/SCLK etc, master mode
29
        bis.w #MC0, &TACTL;
30
        mov.w #0x0fff, &TACCR0;
31
32
33
  Main:
34
       bis.w #GIE,SR; enable interrupts ,LPM3
35
       jmp Main;
36
  Timer:
37
       bis.w #MC_0|TACLR, &TACTL; stop and clear timer
38
       bic.w #TAIFG, &TACTL;clear flag
39
       bic.b #BIT1, &P1OUT;
40
       call #I2C_SendAddress
41
       bis.w #MC0,&TACTL; start timer
42
       reti
43
;--------------------------------------I2C procedures------------------------------------------------;
44
  I2C_SendAddress:   ; send address 1st
45
       bic.b #USI16B,&USICNT; 8 bit  shift register
46
       mov.b #0,&USISRH
47
       bis.b #BIT1, &P1OUT; Trigger signal
48
       mov.w #ADDR, &USISR; load I2C address
49
       bis.b #USIOE,&USICTL0; I2C output enable
50
       bis.b #0x8, &USICNT; output 8 Bits
51
       ret
52
53
RSEG RESET
54
DW Reset
55
RSEG INTVEC
56
ORG TIMER0_A1_VECTOR;
57
      DW Timer
58
59
60
        END
Der  Triggersignal kommt, aber die SCL und SDA schweigen.
Was mache ich falsch?
