Sekundenzeiger läuft zu schnell
Gast #3728347
wieso läuft meine Uhr zu schnell? Atmega328P mit externen 16MHz Quarz.
Die Daten werden viel zu schnell geschickt.
BODLEVEL = 2V7
RSTDISBL = [ ]
DWEN = [ ]
SPIEN = [X]
WDTON = [ ]
EESAVE = [ ]
BOOTSZ = 1024W_3C00
BOOTRST = [X]
CKDIV8 = [ ]
CKOUT = [ ]
SUT_CKSEL = EXTXOSC_8MHZ_XX_16KCK_14CK_65MS
EXTENDED = 0xFD (valid)
HIGH = 0xDA (valid)
LOW = 0xFF (valid)
* USART.c
* Erstellt: 17.07.2014 03:08:12
*   Author: sschultewolter
#define F_CPU 16000000UL
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <stdlib.h>
#define BAUDRATE 9600
#define BAUD_PRESCALLER (((F_CPU/(BAUDRATE*16UL)))-1)
volatile unsigned int ms;
volatile unsigned int s;
volatile unsigned int min;
volatile unsigned int h;
void USART_init(void);
24
unsigned char USART_receive(void);
25
void USART_send( unsigned char data);
26
void USART_putstring(char* StringPtr);
27
28
void TIMER_init(void);
29
30
char String[] = "Hello world\n\r";
31
32
int main(void)
33
34
  USART_init();
35
  TIMER_init();
36
37
  while(1)
38
39
    if(s%2 == 0)
40
41
      USART_putstring(String);
42
43
44
45
46
47
48
  UBRR0H = (uint8_t)(BAUD_PRESCALLER>>8);
49
  UBRR0L = (uint8_t)(BAUD_PRESCALLER);
50
  UCSR0B = (1<<RXEN0)|(1<<TXEN0);
51
  UCSR0C = (3<<UCSZ00);
52
53
54
55
56
  while(!(UCSR0A & (1<<RXC0)));
57
  return UDR0;
58
59
60
61
62
  while(!(UCSR0A & (1<<UDRE0)));
63
  UDR0 = data;
64
65
66
67
68
  while(*StringPtr != 0x00)
69
70
    USART_send(*StringPtr);
71
    StringPtr++;
72
73
74
75
76
77
  TCCR0A = (1<<WGM01);
78
  TCCR0B |= (1<<CS01);
79
  OCR0A = 125-1;
80
  TIMSK0 |= (1<<OCIE0A);
81
  sei();
82
83
84
ISR (TIMER0_COMPA_vect)
85
86
  ms++;
87
  if(ms == 1000)
88
89
    s++;
90
    ms = 0;
91
    if(s == 60)
92
93
      min++;
94
      s = 0;
95
96
    if(min == 60)
97
98
      h++;
99
      min = 0;
100
101
    if(h == 24) h = 0;
102
103
Gast #3728367
Hi
Du hast dich verrechnet.
>  OCR0A = 125-1;
ergibt einen Timerinterrupt alle 62,5µs
Die 1ms bekommst du mit Prescaler=64 und OCR0A=249.
MfG Spess
