I2C Problem wahrscheinlich Code fehler!?
OP #3820264
Ich habe einen ATMega128A mit einem EDIPTFT Touch Display via I2C
verbunden. 2 Pullup widerstände von 4,7k pullen die I2C Leitungen.
Für das Display habe ich mir zwei funktionen erstellt. Das Senden
funktioniert. Das Lesen nicht.
display.h
unsigned char SendDisplayData(char *buf);
unsigned char ReadDisplayData(void);
void DisplayReset(void);
unsigned char ReadDisplayBufferStatus(void);
void DisplayInit(void);
unsigned char *buf;
display.c
#include <stdint.h>
#include <string.h>
#include <i2c.h>
#include <util/delay.h>
#include <stdlib.h>
#include <display.h>
#include <avr/io.h>
  // Reset Pin
  DDRD |= (1<<PD3);
  PORTD &= ~(1<<PD3);
  // SBUF Pin
  DDRD &= ~(1<<PD2);
  PORTD &= ~(1<<PD2);
    unsigned int len = strlen(buf);
    unsigned char i, bcc, ret;
23
  int daten = 0;
24
    ret = i2c_start(DISPLAY_I2C_ADDR+I2C_WRITE);       // set device address and write mode
25
    if ( ret ) {
26
        /* failed to issue start condition, possibly no device found */
27
        i2c_stop();
28
        /* do some error reporting.. led or whatever */
29
    } else {
30
        /* issuing start condition ok, device accessible */
31
        i2c_write(0x11);                            // send DC1
32
        bcc = 0x11;
33
        i2c_write(len);
34
        bcc = bcc + len;
35
        for(i=0; i < len; i++) // Send buf
36
37
            i2c_write(buf[i]);
38
            bcc = bcc + buf[i];
39
40
        i2c_write(bcc); // Send checksum
41
        i2c_start(DISPLAY_I2C_ADDR+I2C_READ);       // set device address and read mode
42
        ret = i2c_readNak();                        // read one byte
43
        if (ret == DISPLAY_I2C_ACK)
44
45
            daten = 1;
46
        } else {
47
            daten = 0;
48
49
        i2c_stop();
50
51
  return daten;
52
53
54
55
56
57
58
        unsigned char bcc, ret, rettemp;
59
        unsigned char len = 2;
60
61
        if ( ret ) {
62
63
            i2c_stop();
64
65
        } else {
66
67
            i2c_write(DISPLAY_I2C_DC2); // send DC2
68
            i2c_write(0x01);            // send 1
69
            i2c_write(0x53);            // send S
70
            bcc = DISPLAY_I2C_DC2 + 0x01 + 0x53;                // Set checksum
71
72
            bcc = 0;
73
74
            ret = i2c_readAck();                        // read ack byte
75
76
77
                rettemp = i2c_readAck();
78
                bcc = bcc + rettemp;
79
                ret = i2c_readAck();            // read len
80
                bcc = bcc+ret;
81
                unsigned char *buf = malloc(ret * sizeof(char));
82
                len += ret;
83
                for (int i = 0; i < ret; i++)
84
85
                    buf[i] = i2c_readAck(); // read data bytes
86
                    bcc = bcc + buf[i];
87
88
                ret = i2c_readNak();    // read len
89
                if (ret != len) {
90
                    // Checksum not matching
91
92
                return buf;
93
            } else {
94
                // No Ack
95
96
            i2c_stop();
97
98
99
        return 0;
100
101
102
103
104
    PORTD &= ~(1<<PD3);
105
    PORTD &= ~(1<<PD3);
106
    PORTD &= ~(1<<PD3);
107
    PORTD |= (1<<PD3);
108
109
110
111
112
113
    int DisplayBufferStatus;
114
    if ( !(PIND & (1<<PIND2)) )
115
116
        DisplayBufferStatus = 1;
117
118
      else
119
120
        DisplayBufferStatus = 0;
121
122
123
    return DisplayBufferStatus;
124
Das Display bekommt die Daten
SendDisplayData("#DL,");
in diesem format übermittelt.
Bei Touch eingaben legt das Display bei Daten im Sendebuffer einen PIN
auf LOW. Diese abfrage funktioniert ebenfalls.
Sobald ich allerdings nun daten lesen will:
 readdata = ReadDisplayData();
stürzt nun entweder der µC ab oder aber ich bekomme zwar daten, mit
denen sich allerdings nichts anfangen kann.
Ich erhalte dann z.b. Daten wie folgt: 217 1 255 1 193 1 141 1 ....
Immer eine 1 zwischen den Zahlen. Jedoch passen die Zahlen auch nicht.
Also das Display würde ebenfalls wie man sendet antworten. Also z.b. mit
#TB1,0 oder halt mit den Dezimalzahlen 23 (für Escape, #) allerdings ist
das erste zeichen eine völlig andere Zahl.
Ich verzweifel.
Kann mir da jemand weiter helfen?
#3821401
ich bin zwar nicht gerade der C-Programmierer, aber dein malloc und die
Übergabe des Puffers scheint mir etwas zweifelhaft.
Gib doch die empfangenen Werte erst mal direkt aus der Schleife z.B. per
UART aus. Da die Länge der Daten die das Display maximal zurückliefern
kann doch sicher bekannt ist ist es besser gleich einen festen Puffer zu
definieren.
Sascha
OP #3821474
Beide, also Send und Read wurden mir geschrieben, daher verstehe ich das
ganze generell nicht.
Das Send geht wie gesagt. Ich kann halt nur so das nötigste in C.
Es ging mal, dann wurde aber das ack im read nicht genommen. Dann hat er
den code nochmal für mich abgeändert, seither klappt das nicht mehr.
Da ja das Send geht und das Read auch (also der Buffer ist dann wieder
leer im Display) muss es am Code liegen.
OP #3822023
So,
ich habe jetzt mal ein wenig rumprobiert. Keine Chance. Wenn ich dich
speicher hinterher mit free wieder lösche stürzt der µC direkt ab. Keine
Chance was zu bewirken.
Und sonst bekomme ich halt nur utopische Daten.
Ich verzweifel :( Senden geht, empfangen naja, nur teilweise.
#3822083
Das
                return buf;
hast du so nie und nimmer durch den Compiler gebracht.
Ein Pointer auf unsigned char ist kein unsigned char. Die Funktion will
aber einen unsigned char zurückgeben und keinen Pointer.
