STM32F2 ADC Dual-mode problem - libopencm3
OP #3822488
Mit dem STM32F2 möchte ich im DualMode ADC-Werte wandeln.
ADC1 und ADC2 im dual mode, jeweils zwei Kanäle, scan mode.
Aber die Werte des ADC2 überschreiben die Werte oder die Konfiguration
des ADC1.
Kann mir da jemand einen Tipp geben?
ADC1+2:
Scan-mode
Single-conversion
Dual regular simultaneous mode (ADC1 + 2)
Clock is configured, also the ports A,C:
Library: libopencm3
code-->
void init_a2d_1(void)
  /*****  Clock_init  *****/
  rcc_peripheral_enable_clock(&RCC_APB2ENR, RCC_APB2ENR_ADC1EN); /**<
Enable internal clock APB2 (60MHZ) for ADC1 */
  rcc_peripheral_enable_clock(&RCC_APB2ENR, RCC_APB2ENR_ADC2EN); /**<
Enable internal clock APB2 (60MHZ) for ADC2 */
  rcc_peripheral_enable_clock(&RCC_AHB1ENR, RCC_AHB1ENR_IOPAEN); /**<
Enable internal clock AHB1 (120MHZ) for analog-input Port A */
  rcc_peripheral_enable_clock(&RCC_AHB1ENR, RCC_AHB1ENR_IOPCEN); /**<
Enable internal clock AHB1 (120MHZ) for analog-input Port C */
  /*++++++++++++++++++++ gpio_a ++++++++++++++++++++*/
  /*****  Analog, no push/pull to HI or LOW  *****/
  gpio_mode_setup(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO5 | GPIO6
| GPIO7);
  gpio_mode_setup(GPIOC, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO0 |
GPIO4);
  /*################################# ADC1
  /********** SINGLE MODE -> ADC1 ***********/
  /*****  Make sure the ADC doesn't run during config  *****/
  adc_off(ADC1);
  adc_off(ADC2);
  /*****  Prescaler 60MHZ/By2 = 30MHZ  *****/
  adc_set_clk_prescale(ADC_CCR_ADCPRE_BY2);
  /*****  12-bit  *****/
  adc_set_resolution(ADC1, ADC_CR1_RES_12BIT);
  adc_set_resolution(ADC2, ADC_CR1_RES_12BIT);
  /***** Dual mode: regular simultaneous mode *****/
  adc_set_multi_mode(ADC_CCR_MULTI_DUAL_REGULAR_SIMUL);
  /***** single mode *****/
  adc_set_single_conversion_mode(ADC1);
  adc_set_single_conversion_mode(ADC2);
  /***** scan mode *****/
  adc_enable_scan_mode(ADC1);
  adc_enable_scan_mode(ADC2);
  /***** result is stored right-aligned *****/
  adc_set_right_aligned(ADC1); //The result is right_aligned in a 32bit
result-register
  adc_set_right_aligned(ADC2); //The result is right_aligned in a 32bit
result-register
  /***** sampling_time from ADC *****/
  adc_set_sample_time_on_all_channels(ADC1, ADC_SMPR_SMP_15CYC);
  adc_set_sample_time_on_all_channels(ADC2, ADC_SMPR_SMP_15CYC);
  /***** eoc interrupt *****/
  adc_enable_eoc_interrupt(ADC1);    //Interrupt
  adc_enable_eoc_interrupt(ADC2);
  /***** set channels to convert via ADC1+2 *****/
  uint8_t groupOfChannnels1[2];
  uint8_t groupOfChannnels2[2];
  groupOfChannnels1[0] = ADC_CHANNEL5;
  groupOfChannnels1[1] = ADC_CHANNEL6;
  groupOfChannnels2[0] = ADC_CHANNEL7;
  groupOfChannnels2[1] = ADC_CHANNEL10;
  /***** regular group (channel selection) *****/
  adc_set_regular_sequence(ADC1, 2, groupOfChannnels1);
  adc_set_regular_sequence(ADC2, 2, groupOfChannnels2);
  /***** Start ADC *****/
  adc_power_on(ADC1);
  adc_power_on(ADC2);
  adc_start_conversion_regular(ADC1);
  /***** NVIC interrupt ADC *****/
  nvic_enable_irq(NVIC_ADC_IRQ);
  nvic_set_priority(NVIC_ADC_IRQ, configMAX_SYSCALL_INTERRUPT_PRIORITY);
grüße
Jam
Gast #3822610
Hallo Jam,
wenn Du Dir von ST die "STM32F4xx_DSP_StdPeriph_Lib_V1.3.0" runterlädst
gibt es dort unter dem Ordner ADC Beispiele für einen Dual Mode ADC.
Du musst mal schauen ob die für den F4 mit dem F2 laufen. Sonst musst Du
Dir die Lib für den F2 runterladen und bei den Beispielen schauen.
Florian
OP #3825355
Hallo Florian,
Vielen Dank für deinen Tipp.
Die Beispiele haben mir aber nicht weitergeholfen.
Wenn ich mehrere Kanäle über ADC1 wandel, kann ich diese auch mit DMA
verarbeiten, was in den Beispielen auch angemerkt ist, weil ich ja
mehrere Kanäle wandeln möchte. Aber bei der Konfiguration für den
Dual_regular_sim.-Mode (oder auch Triple-Mode) komme ich nicht weiter.
Vielleicht hast du noch einen Tipp?
grüße
Jam
