operation timing of single shot mode
OP #3963206
kann jemand hier mir helfen bei programmierung da ads1015 in single shot
mode statt in countiousl mode programmieren will.
ads1015 datashett lautet;
the ADS1015 wait until the OS bit is set high. Once asserted, the bit is
set to '0', indicating that a conversion is currently in progress. Once
conversion data are ready, the OS bit reasserts and the device powers
down. Writing a '1'to the OS bit during a conversion has no effect.
in single-shot  mode:
uint16 read_ads( uint8 address )
uint16 analog_val ;
  analog_val = (int16)i2c_read( I2C_ADS1015, address, 1, ADSREG_CONV, 0,
0 );
  if( analog_val < 0 )
    analog_val = 0 ;
  return( analog_val );
uint16 read_status(void)
tp_ads1015_config config_str;
uint16 config_reg ;
  return(config_str.os,0x0000);   // OS_RDY =1 WHEN CONVERSION  IN
PROGRESS
void hal_adc_tick(void)
#ifdef I2C_ADC
static uint8  ad_ch ;
#endif
delay_10us(50);
  ADC12CTL0 |= ADC12SC;             // restart conversion
#ifdef I2C_ADC
start_ads( 0, 0 ) ;  // START CONVERSION
  while( ad_ch < (LENGTH( hal_adc ) -1 ))
    hal_adc[ad_ch+1] = read_status( ad_ch >> 2 ) ;
  ad_ch++ ;
return read_status(ad_ch >> 2 );        // Read out conversion result
  //if( ad_ch >= I2C_ADC )
    //ad_ch = 0 ;
  //start_ads( ad_ch >> 2, ad_ch ) ;
#endif
