1 | ----------------------------------------------------------------------------------
2 | -- Company:
3 | -- Engineer:
4 | --
5 | -- Create Date: 14:35:25 06/11/2015
6 | -- Design Name:
7 | -- Module Name: Binary2bcd - Behavioral
8 | -- Project Name:
9 | -- Target Devices:
10 | -- Tool versions:
11 | -- Description:
12 | --
13 | -- Dependencies:
14 | --
15 | -- Revision:
16 | -- Revision 0.01 - File Created
17 | -- Additional Comments:
18 | --
19 | ----------------------------------------------------------------------------------
20 | library IEEE;
21 | use IEEE.STD_LOGIC_1164.ALL;
22 | use ieee.std_logic_unsigned.all;
23 | entity Binary2bcd is
24 | Port ( binary_in : in STD_LOGIC_VECTOR (7 downto 0);
25 | sela : in STD_LOGIC;
26 | selb : in STD_LOGIC;
27 | segment7 : out STD_LOGIC_VECTOR (6 downto 0));
28 | end Binary2bcd;
29 |
30 | architecture Behavioral of Binary2bcd is
31 | begin
32 |
33 | p1: process (sela, selb, binary_in) is
34 | variable hex_src : std_logic_vector (4 downto 0) ;
35 | variable bcd : std_logic_vector (11 downto 0) ;
36 | variable act : STD_LOGIC_VECTOR (3 downto 0);
37 | variable ones : STD_LOGIC_VECTOR (3 downto 0);
38 | variable tens : STD_LOGIC_VECTOR (3 downto 0);
39 | variable huns : STD_LOGIC_VECTOR (3 downto 0);
40 | variable sel : STD_LOGIC_VECTOR (1 downto 0);
41 |
42 | begin
43 |
44 | bcd := (others => '0') ;
45 | bcd(2 downto 0) := binary_in(7 downto 5) ;
46 | hex_src := binary_in(4 downto 0) ;
47 | sel := sela & selb;
48 |
49 | for i in hex_src'range loop
50 | if bcd(3 downto 0) > "0100" then
51 | bcd(3 downto 0) := bcd(3 downto 0) + "0011" ;
52 | end if ;
53 | if bcd(7 downto 4) > "0100" then
54 | bcd(7 downto 4) := bcd(7 downto 4) + "0011" ;
55 | end if ;
56 | -- No roll over for hundred digit, since in 0 .. 2
57 |
58 | bcd := bcd(10 downto 0) & hex_src(hex_src'left) ; -- shift bcd + 1
59 | new entry
60 | hex_src := hex_src(hex_src'left - 1 downto hex_src'right) & '0' ;
61 | -- shift src + pad with 0
62 | end loop ;
63 |
64 | huns := bcd(11 downto 8);
65 | tens := bcd(7 downto 4);
66 | ones := bcd(3 downto 0);
67 |
68 | case sel is
69 | when "00" => act := huns;
70 | when "01" => act := tens;
71 | when "10" => act := ones;
72 | when "11" => act := ones;
73 | when others => act := ones;
74 | end case;
75 | case act is
76 | when "0000"=> segment7 <="0000001"; -- '0'
77 | when "0001"=> segment7 <="1001111"; -- '1'
78 | when "0010"=> segment7 <="0010010"; -- '2'
79 | when "0011"=> segment7 <="0000110"; -- '3'
80 | when "0100"=> segment7 <="1001100"; -- '4'
81 | when "0101"=> segment7 <="0100100"; -- '5'
82 | when "0110"=> segment7 <="0100000"; -- '6'
83 | when "0111"=> segment7 <="0001111"; -- '7'
84 | when "1000"=> segment7 <="0000000"; -- '8'
85 | when "1001"=> segment7 <="0000100"; -- '9'
86 | when others=> segment7 <="1111111";
87 | end case;
88 | ---segment7 <= bcd(6 downto 0);
89 | end process;
90 | end Behavioral;
