bitmanipulation zu kompliziert?
Gast #3985296
ich bin grade dabei folgende Aufgabe zu loesen:
Write a C Program that will read a two-bit value via Port 2.0, 2.1 when
a push button is momentarily pressed.  The push button is connected to
Port 1.1   LEDs are connected to Port 1 bits 6 and 7.
a. The routine should send a high output to Port 2 bit 6 if the value
read in is greater than the last value read in.  The value should remain
high for approx 1 second.
b. The routine should add one to a memory location SAME, when the value
is equal to the previous value read in.
c. The routine should send a low output to Port 1 bit 7 if it is less
than the previous value read in.  The light should extinguish for
approximately 1 second.
The routine should be initialised with the last value read in as 0, port
1.6 low and port 1.7 high.
Ich habe etwas geschrieben und wuerde gerne wissen ob es einen
einfacheren weg gibt. Es geht mir im wesentlichen um den kommentierten
Teil. Wir benutzen microC und einen At89S8253. Der Compiler bringt keine
Fehlermeldung. Leider habe ich erst wieder naechste Woche die
moeglichkeit es am Board zu testen. Gibt es einen besseren weg z.B. ohne
die Variable "buffer"?
sbit lowbit at P2.B0;
sbit highbit at P2.B1;
sbit button_0 at P1.B1;
sbit led_1 at P1.B6;
sbit led_2 at P1.B7;
void main() {
unsigned char buffer = 0x00;
unsigned char val_new = 0x00;
unsigned char val_old = 0x00;
unsigned char same;
lowbit = 1;         //input
highbit = 1;        //input
button_0 = 1;       //input
led_1 = 0;          //output
led_2 = 0;          //output
     while(1){
     if (button_0 == 0){                  //is the button pressed?
23
        while (button_0 == 0);            //is the button still pressed?
24
25
        buffer = highbit;               // if highbit 1 --> buffer = 00000001
26
        buffer <<= 1;                   // buffer = 00000010
27
28
        val_new = buffer;               // val_new = 00000010
29
30
        buffer = lowbit;                // if lowbit 1 --> buffer = 00000001
31
32
        val_new |= buffer;              // val_new = 00000011
33
34
        if (val_new > val_old){
35
           led_1 = 1;
36
           delay_ms (1000);
37
           led_1 = 0;
38
39
           else if (val_new < val_old){
40
           led_2 = 0;
41
           delay_ms (1000);
42
           led_2 = 1;
43
44
           else {
45
           same++;
46
47
48
        val_old = val_new;
49
50
51
52
53
#3985308
Das
erscheint mir ein wenig kompliziert.
Nichts gegen Zwischenvariablen, aber man darf ruhig auch in einem
einfachen Ausdruck ruhig ein wenig rechnen ...
    val_new  = ( highbit << 1 ) + lowbit;
... und muss nicht alles in x Zeilen auseinanderdröseln. Irgendwann
dröselt man dann nämlich alles so weit auseinander, dass man überhaupt
nichts mehr sieht, weil man sich die 'Absicht' des Programmierers über
viele Codezeilen hinweg erst mal mühsam zusammensuchen muss.
Eine alternative Schreibweise wäre
    val_new = ( 2 * highbit ) + lowbit;
die meiner Meinung nach die Wertigkeit der beiden Bits etwas besser
rausbringt. Jeder halbwegs vernünftige Compiler wird allerdings sowieso
beides in gleichen Code umsetzen, so dass die Multiplikation jetzt erst
mal schlimmer aussieht, als es tatsächlich ist.
Gast #3985331
Wenn du die Ports als Bytes betrachtest und die gewünschten Bits mit
Logischen Operatoren herausfilterst, wird der Code sicher deutlich
kürzer und vermutlich auch effizienter.
