UART interface FPGA - uC
Gast #4193864
Hi guys!
I am trying to interface a FPGA and PIC18FL4520 through an UART. Both
chips has the same power supply: 3v3 and there is a direct connection
between the FPGA and uc using 2 pcb tracks.
Is it necessary to place a level translataor or some kind of pull up
resistor in these lines (TX and RX)? As I told previously, I don't have
anything and by default the uC and the FPGA is driving to high level
both lines. Then when the communication starts, the pulses are
generated, but at the endof the comunication, one of the line (RX_in
input to the FPGA) is driving to low level by the FPGA while th uC is
driving to high level. It is like the FPGA pin is hang up...But the it
is srtange because this interface has been used in other boards with the
same FPGA and uC and exactly the same pin connections (2 direct tracks
btwen chips) and it was working always...
Any suggestion?
Thanks.
