CAN-BUS shield + arduino, different buttons but same message
Gast #4228304
Hello,
I have the volvo s80 car 2008, i trying to capture steering wheel button
presses, the problem is when i press the two different buttons i receive
the same can-bus message, for example:
1. When i press "Exit" button i receive:
canId = 0x7A, message =  0x0 9F 80 0 0 0 0 21 0
2. When i press "Enter" button i receive the same message:
If i press other buttons(for example "cruise control start" on steering
wheel or some button on radio) i receive uniqueness messages and last
bytes changes for each other button presses.
I'm using arduino and can-bus shield(elecfreaks), maybe somebody can
help me and explain what can be wrong, here is my arduino sketch:
#include <SPI.h>
#include "mcp_can.h"
const int SPI_CS_PIN = 10;
MCP_CAN CAN(SPI_CS_PIN);                                    // Set CS
pin
void setup()
    Serial.begin(115200);
START_INIT:
    if(CAN_OK == CAN.begin(CAN_125KBPS))
        Serial.println("CAN BUS Shield init ok!");
    else
        Serial.println("CAN BUS Shield init fail");
        Serial.println("Init CAN BUS Shield again");
        delay(100);
        goto START_INIT;
void loop()
    unsigned char len = 0;
    unsigned char buf[8];
    if(CAN_MSGAVAIL == CAN.checkReceive())            // check if data
coming
        CAN.readMsgBuf(&len, buf);    // read data,  len: data length,
buf: data buf
        unsigned char canId = CAN.getCanId();
        Serial.println("-----------------------------");
        Serial.println("get data from ID: ");
        Serial.println(canId);
        for(int i = 0; i<len; i++)    // print the data
            Serial.print(buf[i]);
            Serial.print("\t");
        Serial.println();
#4228354
I cannot see, that you release the one read message. I'm the meaning you
read everytime the same one.
In other case, if readMsgBuf() release automatically the message, you
would read the CAN Id from a new message, that at the moment is not
available.
I don't know the arduino API. Please check which case is the right one
depend you documentation of the API.
Gast #4228586
Looks like reading happens fine, first arduino read canID and after he
read the message and this happenes in a loop. About the buffer i will
try to increase the buffer size.
