STM32f3 ADC injected Conversion
OP #4296484
Moin,
ich versuche gerade den ADC auf meinem STM32f3 discovery board zum
laufen zu bekommen. Leider klappt es nicht so ganz. Die Conversion soll
über T1 CC4 getriggert werden. ich wollte ADC1 & 2 nutzen. es muss
jeweils nur ein kanal umgesetzt werden. hier ist mein code, der leider
noch nicht funktioniert. es wäre toll, wenn jemand mal einen blick drauf
werfen könnte:
    RCC_ADCCLKConfig(RCC_ADC12PLLCLK_Div2);
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_ADC12, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    ADC_InitStructure.ADC_ContinuousConvMode = ADC_ContinuousConvMode_Disable;
    ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
    ADC_InitStructure.ADC_ExternalTrigConvEvent = ADC_ExternalTrigConvEvent_0;
    ADC_InitStructure.ADC_ExternalTrigEventEdge = ADC_ExternalTrigEventEdge_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_OverrunMode = ADC_OverrunMode_Disable;
    ADC_InitStructure.ADC_AutoInjMode = ADC_AutoInjec_Disable;
    ADC_InitStructure.ADC_NbrOfRegChannel = 1;
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_Init(ADC2, &ADC_InitStructure);
    ADC_InjectedInitStructure.ADC_ExternalTrigInjecConvEvent = ADC_ExternalTrigInjecConvEvent_1;
23
    ADC_InjectedInitStructure.ADC_ExternalTrigInjecEventEdge = ADC_ExternalTrigInjecEventEdge_RisingEdge;
24
    ADC_InjectedInitStructure.ADC_NbrOfInjecChannel = 1;
25
    ADC_InjectedInitStructure.ADC_InjecSequence1 = ADC_InjectedChannel_2;
26
27
    ADC_InjectedInit(ADC1, &ADC_InjectedInitStructure);
28
29
30
31
32
    ADC_InjectedInitStructure.ADC_InjecSequence1 = ADC_InjectedChannel_3;
33
34
    ADC_InjectedInit(ADC2, &ADC_InjectedInitStructure);
35
36
    ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
37
    ADC_CommonInitStructure.ADC_Clock = ADC_Clock_AsynClkMode;
38
    ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
39
      ADC_CommonInitStructure.ADC_DMAMode = ADC_DMAMode_OneShot;
40
    ADC_CommonInitStructure.ADC_TwoSamplingDelay = 0;
41
42
    ADC_CommonInit(ADC1, &ADC_CommonInitStructure);
43
    ADC_CommonInit(ADC2, &ADC_CommonInitStructure);
44
45
    ADC_InjectedChannelSampleTimeConfig(ADC1, ADC_InjectedChannel_2, ADC_SampleTime_1Cycles5);
46
    ADC_InjectedChannelSampleTimeConfig(ADC2, ADC_InjectedChannel_3, ADC_SampleTime_1Cycles5);
47
48
    ADC_Cmd(ADC1, ENABLE);
49
    ADC_Cmd(ADC2, ENABLE);
OP
Hey,
da hast du wohl recht. inzwischen bin ich auch weg von der injected
group. leider klappt es immernoch nicht, der DMA IT TC wird nur einmal
aufgerufen und es wird auch nur der erste ADC wert übertragen, der
zweite teil bleibt leer.
void ADC_DMA_Config(void){
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 ;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 ;
24
25
26
27
    ADC_CommonInitStructure.ADC_TwoSamplingDelay = 10;
28
29
30
31
32
33
34
35
36
37
38
    ADC_InitStructure.ADC_NbrOfRegChannel = 2;
39
40
41
    /* ADC1 regular channel7 configuration */
42
    ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 1, ADC_SampleTime_7Cycles5);
43
    ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 2, ADC_SampleTime_7Cycles5);
44
45
46
    DMA_StructInit(&DMA_InitStructure);
47
    DMA_InitStructure.DMA_PeripheralBaseAddr  = (uint32_t)&(ADC1->DR);
48
    DMA_InitStructure.DMA_MemoryBaseAddr  = (uint32_t)&ADCBuffer;
49
    DMA_InitStructure.DMA_DIR  = DMA_DIR_PeripheralSRC;
50
    DMA_InitStructure.DMA_BufferSize  = 2;
51
    DMA_InitStructure.DMA_PeripheralInc  = DMA_PeripheralInc_Disable;
52
    DMA_InitStructure.DMA_MemoryInc  = DMA_MemoryInc_Enable;
53
    DMA_InitStructure.DMA_PeripheralDataSize  = DMA_PeripheralDataSize_HalfWord;
54
    DMA_InitStructure.DMA_MemoryDataSize  = DMA_MemoryDataSize_HalfWord;
55
    DMA_InitStructure.DMA_Mode  = DMA_Mode_Normal;
56
    DMA_InitStructure.DMA_Priority  = DMA_Priority_Medium;
57
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
58
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
59
    DMA_ClearITPendingBit(DMA1_IT_TC1);
60
    DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, ENABLE);
61
62
63
    NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;
64
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
65
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
66
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
67
    NVIC_Init(&NVIC_InitStructure);
68
69
70
    ADC_DMAConfig( ADC1, ADC_DMAMode_OneShot);
71
    ADC_DMACmd(ADC1, ENABLE);
72
73
Über
DMA_SetCurrDataCounter(DMA1_Channel1, 2);
DMA_Cmd(DMA1_Channel1, ENABLE);
ADC_StartConversion(ADC1);
soll das ganze über ein TImer CC ausgelöst werden.
LG Alex
hast Du auch den Timer im Mastermodus konfiguriert?
Bei mir (STM32f4) sieht das für das Update-Event als Trigger mit
HAL-Treibern folgendermaßen aus:
sMasterConfig.MasterOutputTrigger = TIM_TRGO_UPDATE;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_ENABLE;
Dein ADC scheint nicht im Triggermodus konfiguriert zu sein. Bei mir
wäre das:
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_RISING;
hadc1.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T2_TRGO;
Es müssen zudem kontinuierlich DMA-Requests generiert werden, sonst wird
eben nur einmalig ein Wert übertragen (nicht verwechseln mit
ContinuousConvMode):
hadc1.Init.DMAContinuousRequests = ENABLE;
Hoffe es hilft weiter!
Christof
Ok. Dennoch produziert dein ADC keine kontinuierlichen Requests. Beim f3
wird's etwas anders als bei meinem f4 gemacht:
> DMA one shot mode (DMACFG=0)
> In this mode, the ADC generates a DMA transfer request each time a new
> conversion data is available and stops generating DMA requests once
> the DMA has reached the last DMA transfer (when DMA_EOT interrupt occurs
> - refer to DMA paragraph) even if a conversion has been started again.
Also musst Du den DMA circular mode (DMACFG=1) benutzen, damit nach
jeder Wandlungsfolge ein Request ausgelöst wird.
