5x5x5 LED Cube interrupt not working
OP #4298152
Hello folks,
I am building a LED Cube so far I've finished my 3x3x3 led cube and
programmed it I had just 1 problem with the LED Cube... the 2kb Memory
was just not enough for me it worked with 1 or 2 patterns but than it
would be full after programming to about 98%. Anyways, it worked and now
I wanted to build a 5x5x5 led cube I finished the schematic, the layout,
etched and assembled it, but now I have just one problem with my
program. I used the program for my 3x3x3 LED cube and just changed a few
things. I get an error from terminal which tells me some weird things I
think it has a problem with the interrupt but it is the same as the last
one I used. I hope you guys can help me.
Thanks for the help :D
HERE IS MY PROGRAM
//  main.c
//  AT-Mega 16/32
//  LED Cube
//  Created by Nikan on 2015-10-01.
//#####[00][01][02][03][04]#####
//#####[05][06][07][08][09]##### => LED_Layer_x = 0b[24]-[0]
//#####[10][11][12][13][14]#####
//#####[15][16][17][18][19]#####
//#####[20][21][22][23][24]#####
#include <interrupt.h>
#include <io.h>
#define Layer0 0b00000001
#define Layer1 0b00000010
#define Layer2 0b00000100
#define Layer3 0b00001000
#define Layer4 0b00010000
unsigned long layer_pattern = 0b00000001;   // Definiert das Pattern
muss mit Layer0 anfangen
unsigned short cntr = 0;                    // Stellt counter auf 0
volatile long LED_Layer_0=0x00;             // Stellt alle bits in
Layer0 auf 0
volatile long LED_Layer_1=0x00;             // Stellt alle bits in
Layer1 auf 0
volatile long LED_Layer_2=0x00;             // Stellt alle bits in
Layer2 auf 0
volatile long LED_Layer_3=0x00;             // Stellt alle bits in
Layer3 auf 0
volatile long LED_Layer_4=0x00;             // Stellt alle bits in
Layer4 auf 0
//Interrupt
ISR(TIMER0_COMPA_vect){
    if(layer_pattern == Layer0){
        //Layer0
        PORTA = ((LED_Layer_0 << 6) & 0b00000001) | ((LED_Layer_0 << 4)
& 0b00000010) | ((LED_Layer_0 << 12) & 0b00000100) | ((LED_Layer_0 <<
10) & 0b00001000) | ((LED_Layer_0 << 8) & 0b00010000) | ((LED_Layer_0 <<
6) & 0b00100000) | ((LED_Layer_0 << 4) & 0b01000000) | ((LED_Layer_0 <<
12) & 0b10000000);
        PORTB = ((LED_Layer_0 << 0) & 0b00000001) | ((LED_Layer_0 << 0)
& 0b00000010) | ((LED_Layer_0 << 0) & 0b00000100) | ((LED_Layer_0 << 0)
& 0b00001000) | ((LED_Layer_0 << 0) & 0b00010000) | ((LED_Layer_0 << 4)
& 0b00100000) | ((LED_Layer_0 << 2) & 0b01000000) | ((LED_Layer_0 << 0)
& 0b10000000);
        PORTC = ((LED_Layer_0 << 11) & 0b00000001) | ((LED_Layer_0 <<
11) & 0b00000010) | ((LED_Layer_0 << 11) & 0b00000100) | ((LED_Layer_0
<< 11) & 0b00001000) | ((LED_Layer_0 << 21) & 0b00010000) |
((LED_Layer_0 << 21) & 0b00100000) | ((LED_Layer_0 << 21) & 0b01000000)
| ((LED_Layer_0 << 21) & 0b10000000);
        PORTD = ((LED_Layer_0 << 13) & 0b10000000);
        layer_pattern = layer_pattern <<1;
    else if(layer_pattern == Layer1){
        //Layer1
12) & 0b10000000);
& 0b10000000);
        layer_pattern = layer_pattern << 1;
    else if(layer_pattern == Layer2){
        //Layer2
12) & 0b10000000);
& 0b10000000);
    else if(layer_pattern == Layer3){
        //Layer3
12) & 0b10000000);
& 0b10000000);
    else{
        //Layer4
12) & 0b10000000);
& 0b10000000);
        layer_pattern = Layer0;
    PORTD = PORTD & 0b01111100;         // Alle bits auf 1 stellen außer
die Layer bits, die müssen auf 1 sein.
    PORTD = PORTD | layer_pattern;      // Bestimmt das es nur auf den
layern wechseln soll und nirgendwo anders
    //Initialising
    void init (void){
        DDRA =  0b11111111;  //  (Output +) All Pins
        DDRB =  0b11111111;  //  (Output +) All Pins
        DDRC =  0b11111111;  //  (Output +) All Pins
        DDRD =  0b11111100;  //  (Output +) Pins 2-7 / Pins 0-1 Are Set
As Input
    // Configure Timer 0
    TCCR0A = (1<<WGM01); // CTC Modus
    TCCR0B |= (1<<CS02) | (1 << CS00);
    OCR0A = 20;
    // Allow Compare Interrupt
    TIMSK |= (1<<OCIE0A);
    // Activate Global Interrupts
    sei();
//  Main
int main(void){
    init();
    while(1){
        for(cntr=0;cntr<60000;cntr++){
            LED_Layer_0 = 0b0000000000000000000000000;
            LED_Layer_1 = 0b0000000000000000000000000;
            LED_Layer_2 = 0b0000000000000000000000000;
            LED_Layer_3 = 0b0000000000000000000000000;
            LED_Layer_4 = 0b0000000000000000000000000;
HERE IS TERMINALS STATEMENT
-------- begin --------
avr-gcc (GCC) 4.8.1
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Compiling C: main.c
avr-gcc -c -mmcu=atmega16 -I. -gdwarf-2 -DF_CPU=1000000UL -Os
-funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall
-Wstrict-prototypes -Wa,-adhlns=./main.lst  -std=gnu99 -MMD -MP -MF
.dep/main.o.d main.c -o main.o
In file included from main.c:9:0:
main.c: In function 'TIMER0_COMPA_vect':
main.c:29:5: warning: 'TIMER0_COMPA_vect' appears to be a misspelled
signal handler [enabled by default]
./interrupt.h:126:10: note: in definition of macro 'ISR'
     void vector (void)
main.c: In function 'init':
main.c:132:5: error: 'TCCR0A' undeclared (first use in this function)
main.c:132:5: note: each undeclared identifier is reported only once for
each function it appears in
main.c:133:5: error: 'TCCR0B' undeclared (first use in this function)
main.c:134:5: error: 'OCR0A' undeclared (first use in this function)
     OCR0A = 20;
main.c:137:18: error: 'OCIE0A' undeclared (first use in this function)
make: *** [main.o] Error 1
Dein io.h kommt nicht aus avr/
Das Programm ist ungefähr 20 mal so lang  wie nötig.
Du solltest vielleicht mal kernen, was ein Array ist und eie man es
indiziert.
Hoffen wir, dass die 6000er Schleife bloss ein Platzhalter ist.
