STM32F427 SDRAM
Gast #4365658
Hallo Leute,
ich versuche auf dem STM32F427 den SDRAM in Betrieb zu nehmen. Jedoch
funktioniert es nicht - könnt ihr vielleicht mal über meinen
Initialisierung schauen?
Danke euch ;)
int main(void)
    /* STM32F4xx HAL library initialization:
         - Configure the Flash prefetch, instruction and Data caches
         - Configure the Systick to generate an interrupt each 1 msec
         - Set NVIC Group Priority to 4
         - Global MSP (MCU Support Package) initialization
    HAL_Init(); //OK
    //Configure the System clock to have a frequency of 180 MHz
    SystemClock_Config();
    /*##-1- Configure the SDRAM device*/
    /* SDRAM device configuration */
    hsdram.Instance = FMC_SDRAM_DEVICE;
    SDRAM_Timing.LoadToActiveDelay    = 2;
    SDRAM_Timing.ExitSelfRefreshDelay = 7;
    SDRAM_Timing.SelfRefreshTime      = 4;
    SDRAM_Timing.RowCycleDelay        = 7;
    SDRAM_Timing.WriteRecoveryTime    = 2;
    SDRAM_Timing.RPDelay              = 2;
23
    SDRAM_Timing.RCDDelay             = 2;
24
25
    hsdram.Init.SDBank             = FMC_SDRAM_BANK2;
26
    hsdram.Init.ColumnBitsNumber   = FMC_SDRAM_COLUMN_BITS_NUM_8;
27
    hsdram.Init.RowBitsNumber      = FMC_SDRAM_ROW_BITS_NUM_12;
28
    hsdram.Init.MemoryDataWidth    = FMC_SDRAM_MEM_BUS_WIDTH_32;
29
    hsdram.Init.InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4;
30
    hsdram.Init.CASLatency         = FMC_SDRAM_CAS_LATENCY_3;
31
    hsdram.Init.WriteProtection    = FMC_SDRAM_WRITE_PROTECTION_DISABLE;
32
    hsdram.Init.SDClockPeriod      = FMC_SDRAM_CLOCK_PERIOD_3;
33
    hsdram.Init.ReadBurst          = FMC_SDRAM_RBURST_DISABLE;
34
    hsdram.Init.ReadPipeDelay      = FMC_SDRAM_RPIPE_DELAY_1;
35
36
37
    if(HAL_SDRAM_Init(&hsdram,&SDRAM_Timing)!=HAL_OK){
38
      Error_Handler();
39
40
41
    SDRAM_Initialization_Sequence(&hsdram,&cmd);
42
43
44
    for(i=0;i<100;i++){
45
      buffi[i]=i;
46
47
48
    /* Write data to the SDRAM memory */
49
    for (i = 0; i < 100; i++)
50
51
      *(__IO uint32_t*) (SDRAM_BANK_ADDR + 4*i) = buffi[i];
52
53
54
Letzte Möglichkeit für einen Fehler wäre hier:
static void SDRAM_Initialization_Sequence(SDRAM_HandleTypeDef *hsdram, FMC_SDRAM_CommandTypeDef *Command)
  __IO uint32_t tmpmrd =0;
  /* Step 3:  Configure a clock configuration enable command */
  Command->CommandMode        = FMC_SDRAM_CMD_CLK_ENABLE;
  Command->CommandTarget      = FMC_SDRAM_CMD_TARGET_BANK2;
  Command->AutoRefreshNumber    = 1;
  Command->ModeRegisterDefinition = 0;
  /* Send the command */
  HAL_SDRAM_SendCommand(hsdram, Command, 0x1000);
  /* Step 4: Insert 100 ms delay */
  HAL_Delay(100);
  /* Step 5: Configure a PALL (precharge all) command */
  Command->CommandMode        = FMC_SDRAM_CMD_PALL;
23
24
25
  /* Step 6 : Configure a Auto-Refresh command */
26
  Command->CommandMode        = FMC_SDRAM_CMD_AUTOREFRESH_MODE;
27
28
  Command->AutoRefreshNumber    = 4;
29
30
31
32
33
34
  /* Step 7: Program the external memory mode register */
35
  tmpmrd = (uint32_t)SDRAM_MODEREG_BURST_LENGTH_2          |
36
                     SDRAM_MODEREG_BURST_TYPE_SEQUENTIAL   |
37
                     SDRAM_MODEREG_CAS_LATENCY_3           |
38
                     SDRAM_MODEREG_OPERATING_MODE_STANDARD |
39
                     SDRAM_MODEREG_WRITEBURST_MODE_SINGLE;
40
41
  Command->CommandMode = FMC_SDRAM_CMD_LOAD_MODE;
42
43
44
  Command->ModeRegisterDefinition = tmpmrd;
45
46
47
48
49
  /* Step 8: Set the refresh rate counter */
50
  /* (15.62 us x Freq) - 20 */
51
  /* Set the device refresh counter */
52
  HAL_SDRAM_ProgramRefreshRate(hsdram, REFRESH_COUNT);
53
Hier seht ihr meine Msp-Init Methode - ist hier vielleicht was falsch?
__weak void HAL_SDRAM_MspInit(SDRAM_HandleTypeDef *hsdram)
  /* NOTE: This function Should not be modified, when the callback is needed,
            the HAL_SDRAM_MspInit could be implemented in the user file
  GPIO_InitTypeDef  GPIO_Init_Structure;
  /*##-1- Enable peripherals and GPIO Clocks #################################*/
  /* Enable GPIO clocks */
  __HAL_RCC_GPIOD_CLK_ENABLE();
  __HAL_RCC_GPIOE_CLK_ENABLE();
  __HAL_RCC_GPIOF_CLK_ENABLE();
  __HAL_RCC_GPIOG_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOI_CLK_ENABLE();
  __HAL_RCC_FMC_CLK_ENABLE();
  /*##-2- Configure peripheral GPIO ##########################################*/
/*-- GPIOs Configuration -----------------------------------------------------*/
 +                       SDRAM pins assignment                                      +
23
24
 | PD0  <-> FMC_D2  +OK | PE0  <-> FMC_NBL0 +OK | PF0  <-> FMC_A0  +ok    | PG0  <-> FMC_A10   +ok|
25
 | PD1  <-> FMC_D3  +OK | PE1  <-> FMC_NBL1 +OK | PF1  <-> FMC_A1  +ok    | PG1  <-> FMC_A11   +ok|
26
 | PD8  <-> FMC_D13 +OK | PE7  <-> FMC_D4  +ok  | PF2  <-> FMC_A2  +ok    | PG8  <-> FMC_SDCLK +ok|
27
 | PD9  <-> FMC_D14 +OK | PE8  <-> FMC_D5  +ok  | PF3  <-> FMC_A3  +ok    | PG15 <-> FMC_NCAS  +ok|
28
 | PD10 <-> FMC_D15 +OK | PE9  <-> FMC_D6  +ok  | PF4  <-> FMC_A4  +ok    | PG4 <-> FMC_BA0    +ok|
29
 | PD14 <-> FMC_D0  +OK | PE10 <-> FMC_D7  +ok  | PF5  <-> FMC_A5  +ok    | PG5 <-> FMC_BA1    +ok|
30
 | PD15 <-> FMC_D1  +OK | PE11 <-> FMC_D8  +ok  | PF11 <-> FMC_NRAS +ok   |
31
 +----------------------| PE12 <-> FMC_D9  +ok    | PF12 <-> FMC_A6   +ok |
32
                        | PE13 <-> FMC_D10 +ok    | PF13 <-> FMC_A7   +ok |
33
                        | PE14 <-> FMC_D11 +ok    | PF14 <-> FMC_A8   +ok |
34
                        | PE15 <-> FMC_D12 +ok    | PF15 <-> FMC_A9   +ok |
35
36
37
38
 //NEW INIT STUFF
39
40
 | PH2  <-> FMC_SDCKE0 | PI0  <-> FMC_D24
41
 | PH3  <-> FMC_SDNE0  | PI1  <-> FMC_D25
42
 | PH5  <-> FMC_SDNWE  | PI2  <-> FMC_D26
43
 | PH8  <-> FMC_D16    | PI3  <-> FMC_D27
44
 | PH9  <-> FMC_D17    | PI4  <-> FMC_SDNDQM2
45
 | PH10 <-> FMC_D18    | PI5  <-> FMC_SDNDQM3
46
 | PH11 <-> FMC_D19    | PI6  <-> FMC_D28
47
 | PH12 <-> FMC_D20    | PI7  <-> FMC_D29
48
 | PH13 <-> FMC_D21    | PI9  <-> FMC_D30
49
 | PH14 <-> FMC_D22    | PI10 <-> FMC_D31
50
 | PH15 <-> FMC_D23    |
51
52
53
54
  /* Common GPIO configuration */
55
  GPIO_Init_Structure.Mode  = GPIO_MODE_AF_PP;
56
  GPIO_Init_Structure.Speed = GPIO_SPEED_FAST;
57
  GPIO_Init_Structure.Pull  = GPIO_NOPULL;
58
  GPIO_Init_Structure.Alternate = GPIO_AF12_FMC;
59
60
  /* GPIOB configuration */
61
//  GPIO_Init_Structure.Pin = GPIO_PIN_5 | GPIO_PIN_6;
62
//  HAL_GPIO_Init(GPIOB, &GPIO_Init_Structure);
63
64
  /* GPIOC configuration */
65
//  GPIO_Init_Structure.Pin = GPIO_PIN_0;
66
//  HAL_GPIO_Init(GPIOC, &GPIO_Init_Structure);
67
68
  /* GPIOD configuration */
69
  GPIO_Init_Structure.Pin = GPIO_PIN_0 | GPIO_PIN_1  | GPIO_PIN_8 |
70
                                GPIO_PIN_9 | GPIO_PIN_10 | GPIO_PIN_14 |
71
                                GPIO_PIN_15;
72
  HAL_GPIO_Init(GPIOD, &GPIO_Init_Structure);
73
74
  /* GPIOE configuration */
75
  GPIO_Init_Structure.Pin = GPIO_PIN_0  | GPIO_PIN_1  | GPIO_PIN_7 |
76
                                GPIO_PIN_8  | GPIO_PIN_9  | GPIO_PIN_10 |
77
                                GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_13 |
78
                                GPIO_PIN_14 | GPIO_PIN_15;
79
  HAL_GPIO_Init(GPIOE, &GPIO_Init_Structure);
80
81
  /* GPIOF configuration */
82
  GPIO_Init_Structure.Pin = GPIO_PIN_0  | GPIO_PIN_1 | GPIO_PIN_2 |
83
                                GPIO_PIN_3  | GPIO_PIN_4 | GPIO_PIN_5 |
84
85
86
  HAL_GPIO_Init(GPIOF, &GPIO_Init_Structure);
87
88
  /* GPIOG configuration */
89
  GPIO_Init_Structure.Pin = GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_4 |
90
                                GPIO_PIN_5 | GPIO_PIN_8 | GPIO_PIN_15;
91
  HAL_GPIO_Init(GPIOG, &GPIO_Init_Structure);
92
93
  /*GPIOH configuration */
94
  GPIO_Init_Structure.Pin = GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_5 | GPIO_PIN_8 | GPIO_PIN_9 |
95
                              GPIO_PIN_10 | GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_13 | GPIO_PIN_14 | GPIO_PIN_15;
96
  HAL_GPIO_Init(GPIOH,&GPIO_Init_Structure);
97
98
  /*GPIOI configuration */
99
  GPIO_Init_Structure.Pin = GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5 |
100
                              GPIO_PIN_6 | GPIO_PIN_7 | GPIO_PIN_9 | GPIO_PIN_10;
101
  HAL_GPIO_Init(GPIOI, &GPIO_Init_Structure);
102
103
104
Oder ist aber meine Clock falsch gesetzt?
static void SystemClock_Config(void)
    RCC_ClkInitTypeDef RCC_ClkInitStruct; //OK
    RCC_OscInitTypeDef RCC_OscInitStruct; //OK
    /* Enable Power Control clock */
    __PWR_CLK_ENABLE(); //OK
    /* The voltage scaling allows optimizing the power consumption when the device is
     clocked below the maximum system frequency, to update the voltage scaling value
     regarding system frequency refer to product datasheet.  */
    __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1); //OK
    /* Enable HSE Oscillator and activate PLL with HSE as source */
    RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;  //OK
    RCC_OscInitStruct.HSEState = RCC_HSE_ON; //OK
    RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; //OK
    RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;  //OK
    RCC_OscInitStruct.PLL.PLLM = 16; // NOT -> WHY 16? -> Demoboard is 8
    RCC_OscInitStruct.PLL.PLLN = 360; //OK
    RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2; //OK
    RCC_OscInitStruct.PLL.PLLQ = 7; //OK
23
    if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) //OK
24
25
        /* Initialization Error */
26
        Error_Handler();
27
28
29
30
    if(HAL_PWREx_ActivateOverDrive() != HAL_OK) //OK
31
32
33
        Error_Handler();
34
35
36
    /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
37
     clocks dividers */
38
    RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2); //OK
39
    RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; //OK
40
    RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; //OK
41
    RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4; //OK
42
    RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2; //OK
43
    if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK) //OK
44
45
46
        Error_Handler();
47
48
Ich hoffe ihr könnt mir weiter helfen. Ich habe als SDRAM folgenden auf
dem Board:
IS42S32400F
-> Danke schonmal.
