Enable Monitor Mode on Arm Cortex M4 | Execution of breakpoint instrcution CPU halts
Gast #4557850
I am working in a monitor for MK64f12 an ARM Cortex M4.
I have followed the tips in your tutorial to develop my monitor using a
serial interface. The problem I cannot enable the Monitor Debug Mode and
the exception is not handled.
I am using J-Link to load the monitor and debug.
My monitor is able to load an application to RAM and _Read and Write
memory. Set software breakpoint is working.
The problem is when the breakpoint instruction is executed the CPU
halts. It should not halt but execute the Monitor Exception.
Here is a description of my settings:
1- Vector Table:
_vectors:
    .long   0x20000000                  /* Top of Stack
    .long   ResetHandler                /* Reset Handler
    .long   ResetHandler                /* NMI Handler
    .long   myHandler                   /* Hard Fault Handler
    .long   AbortEntry                  /* MPU Fault Handler
    .long   AbortEntry                  /* Bus Fault Handler
    .long   AbortEntry                  /* Usage Fault Handler
    .long   0                           /* Reserved
    .long   0                           /* Reserved
    .long   0                           /* Reserved
    .long   0                           /* Reserved
    .long   IsrDefault                  /* SVCall Handler
    .long   BreakEntry                  /* Debug Monitor Handler
    .long   IsrDefault                  /* Reserved
    .long   IsrDefault                  /* PendSV Handler
    .long   IsrDefault                  /* SysTick Handler
................... b _IntCtrlInit ...................
2- Copy the vector table from ROM to RAM Copy to the physical start
address of the RAM (0x1FFF0000).
3- Enable the Monitor Debug Mode _IntCtrlInit is called from the stratup
code
void _IntCtrlInit(void)
   //* disable HALT Debug mode; enable DEBUG Monitor exception */
    DHCSR_Write = DBGKEY;  //Debug key should be written to be able to
write this register
     //DHCSR_Write &= C_DEBUGEN;
    DEMCR = MON_EN ; // Enable Monitor mode
   // Enable FPB unit
     FP_CTRL = 3;
4- My Application is buit for RAM with monitor (Monitor variant)
5- The Monitor is loaded using the J-TAG
6- The monitor is initialized and I use t R232
7- Software breakpoint are set in the right position.
8- The breakpoint is hit, I got in Eclipse:
Program received signal SIGTRAP, Trace/breakpoint trap.
0x1fff1618 in ?? ()
9- I also tried without the J-TAG but resetting the board and
disconnecting the J-Link. I add my breakpoint in the application code
after some output (in RootTask function for example). The program
execution stops at the desired place but I do not enter the Monitor
Exception, and CPU halts.
The problem is the MonitorHandler (BreakEntry) is never reached. The CPU
seems to halt which is not desired. As I enable the Monitor Debug Mode,
this should be reached.
I want to reach the BreakEntry (Monitor Exception handler). Do you have
an idea?
Best tegards
Gast #4557868
1- Vector Table:
_vectors:
    .long   0x20000000                  /* Top of Stack                 */
    .long   ResetHandler                /* Reset Handler                */
    .long   ResetHandler                /* NMI Handler                  */
    .long   myHandler                   /* Hard Fault Handler           */
    .long   AbortEntry                  /* MPU Fault Handler            */
    .long   AbortEntry                  /* Bus Fault Handler            */
    .long   AbortEntry                  /* Usage Fault Handler          */
    .long   0                           /* Reserved                     */
    .long   IsrDefault                  /* SVCall Handler               */
    .long   BreakEntry                  /* Debug Monitor Handler        */
    .long   IsrDefault                  /* Reserved                     */
    .long   IsrDefault                  /* PendSV Handler               */
    .long   IsrDefault                  /* SysTick Handler              */
code
    DHCSR_Write = DBGKEY;  //Debug key should be written to be able to write this register
   // Enable FPB unit
     FP_CTRL = 3;
0x1fff1618 in ?? ()
an idea?
Best tegards
