STM32F205VG CAN Bus-Off recovery problem
Gast #4606419
I have a problem with CAN after a bus-off condition.
When CAN state changes to bus-off, I set the CAN operation mode to SLEEP
mode.
After a few 100 ms I try to bring the CAN bus into NORMAL mode again and
then the Interrupts are activated again.
But it seems like the ESR register isn't cleard before CAN starts
working and so I get a bus-off interrupt immediately after a restart...
this is a never ending cycle.
1) Bus-Off Interrupt occurs
2) Disable CAN-Interrupts
3) Set Sleep-Mode (clear INRQ, set SLEEP in MCR Register)
4) Wait for SLAK bit set
5) Reset TX and RX Mailboxes/FIFOs, Clear all pending Interrupts
6) Wait for a few 100 ms
7) Enter Init-Mode (clear SLEEP, set INRQ, in MCR Register)
8) Wait for INAK Bit set
9) Enter Normal-Mode (clear SLEEP, clear INRQ in MCR Register)
10) Wait for INAK Bit cleared
11) Enable CAN-Interrupts
12) ---> SCE Interrupt --> BOFF Flag set --> Back to 1)
When I put an ASSERT((can->ESR & BOFF_BIT) == 0) immediately after 10),
the assertion fails. But if put a breakpoint at the assertion and I
check the register, all bits are cleared. And when I resume, it starts
working as expected.
The Code for changing the CAN-Mode:
static tCanStatus SetCanMode(tCAN * can, tCanMode mode)
  uint32_t timeout = TIMEOUT_VALUE;
  if (mode == CAN_MODE_INIT)
      can->MCR = (uint32_t)((can->MCR & (uint32_t)(~(uint32_t)CAN_MCR_SLEEP)) | CAN_MCR_INRQ);
      while (((can->MSR & CAN_MODE_MASK) != CAN_MSR_INAK) && (timeout != 0))
        timeout--;
      if ((can->MSR & CAN_MODE_MASK) != CAN_MSR_INAK)
        return CAN_STATUS_ERROR;
  else if (mode == CAN_MODE_NORMAL)
    can->MCR &= (uint32_t)(~(CAN_MCR_SLEEP | CAN_MCR_INRQ));
    while (((can->MSR & CAN_MODE_MASK) != 0) && (timeout != 0))
      timeout--;
    if ((can->MSR & CAN_MODE_MASK) != 0)
23
24
25
    configASSERT((can->ESR & 0x04) == 0);    // Fails after a bus-off
26
27
  else if (mode == CAN_MODE_SLEEP)
28
29
    can->MCR = (uint32_t)((can->MCR & (uint32_t)(~(uint32_t)CAN_MCR_INRQ)) | CAN_MCR_SLEEP);
30
31
    while (((can->MSR & CAN_MODE_MASK) != CAN_MSR_SLAK) && (timeout != 0))
32
      timeout--;
33
34
    if ((can->MSR & CAN_MODE_MASK) != CAN_MSR_SLAK)
35
36
37
38
  return CAN_STATUS_OK;
39
In initialization mode, bxCAN does not monitor the CANRX signal,
therefore it cannot complete the recovery sequence. To recover, bxCAN
must be in normal mode.
 (says the RM0091)
Thank you.
I figured that out already. It seems like i misinterpreted the the Notes
in the datasheet. I have to wait extra time after beeing in normal mode
until CAN is synchronized with the bus. But i thought waiting until the
CAN_MCR_INRQ bit is cleard already includes the synchronization...
